08-25-2020, 02:36 PM | #3865 |
Drives: 2023 BRZ
Hey Dave, let's talk more about this. If you want to join me at HPR a week from Friday we can swap cars for a session or two.
The benefit I see with that kind of adjustability is fine-tuning handling characteristics from turn-in, through the apex, to track out. I think if you set the car up right without the two-way dampers, you don't necessarily need the extra adjustability. That said, more options never hurt, as long as you know how to use them. FWIW, I never felt the need for double-adjustables on my car. At least not yet. Abe and I have been working on doing this with his car. But turning knobs is just one way to do it. I do really like his MCSes. I guess that's what I would be inclined to do at that price point for double-adjustables. You may also want to check with Vorshlag. I think they put together a kit with Bilsteins, customs spring rates, and very nice camber plates for about that price, or maybe less. I'm partial to monotubes.
Director of Rocky Mountain 86CUP
08-25-2020, 02:54 PM | #3866 | |
Drives: RS1.0
08-25-2020, 04:05 PM | #3867 |
Drives: 2023 BRZ
Yeah, that's tricky. It would be great to not have to worry about that dip. Going through there without upsetting the car isn't easy. And setting it up to go through that well is probably going to mean you're sacrificing elsewhere. I'm sure nicer coilovers will help, but just ensure you're taking a holistic approach and not getting tunnel vision on dealing with the dip.
08-25-2020, 04:12 PM | #3868 | ||
How much track driving experience do you have? How much suspension tuning experience? People can and do make things worse with 2 ways and as others have said a good 1 way is sometimes a better fit. On the other hand, they can really help fine tune a car's corner entry and exit behavior. Quote:
- Andrew |
08-25-2020, 04:27 PM | #3869 |
Drives: 2023 BRZ
I suspect you hit the nail on the head here, Andrew.
The Following User Says Thank You to Pat For This Useful Post: | Racecomp Engineering (08-25-2020) |
08-25-2020, 05:01 PM | #3870 | |
Drives: RS1.0
I probably have around 30 OpenLapping/HPDE/TT days and 20ish AutoX days under my belt from the past 4-5 years. Last year was my first year running with a sanctioning body. Regarding suspension tuning, I usually ask my friends (scca national champs) to help me with setup. Maybe I just go with a better 1 way setup than I currently have, with higher spring rates. |
The Following 2 Users Say Thank You to Yzu For This Useful Post: | Pat (08-25-2020), Racecomp Engineering (08-25-2020) |
08-25-2020, 06:31 PM | #3871 |
08-25-2020, 09:06 PM | #3872 |
Drives: Looking to buy
Would you all recommend rce yellows + konis/bilsteins (and camber plates) for a DD/autoX car, or step up to the RCE T2 or KW V3s? I've heard camber plates are noisy for street use, but I also want to be at least marginally competitive in STX...
I think the spring + shock combo would be a good way to basically spend half as much as I would on decent coils, and I think it would still allow for decent competitiveness. The reality is I probably won't be fine tuning the car too much, so I would prioritize an out of the box solution. Thanks in advance for any help Cheers, Christopher |
08-25-2020, 09:22 PM | #3873 |
KW/RCE if you want to be marginally competitive. Don't forget you need the wheel clearance for 17x9s and at least -3 degrees of camber up front which you don't get with the lowering springs being 90mm ID.
08-25-2020, 11:08 PM | #3874 |
Yeah, that's what I figured. I guess I'm looking for minimal effort involved on my end (set it and forget it... or adjust occasionally ) so I'm ok giving up some performance. Thanks for the help. Most go with +35 offset on 17x9, right?
08-26-2020, 12:07 AM | #3875 |
Narrower car is quicker through slalom. +45s are easy to source and space out to +40 so there's no rubbing at full lock, but +35 certainly fits
08-26-2020, 07:25 AM | #3876 | ||
Do I have a buyer already??
Kyle H. - #89 STX
08-26-2020, 10:31 AM | #3877 | ||
- Andrew |
08-26-2020, 10:31 AM | #3878 |
Nah I'm cheap and headed towards being less competitive. I just like to watch
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
