#3851 |
Drives: 2014 WRB BRZ Limited
Thanks @AKITA . I think the hose on the passenger side that connects to SC is molded, I think at a 90 degree angle right by the supercharger connection. Are the provided hoses flexible enough to make that turn? Does that entire Edelbrock hose just get discarded?
#3852 | |
Drives: 2016 Scion FRS Halo
| The Following User Says Thank You to AKITA For This Useful Post: | BR-ZED (09-07-2020) |
#3853 | |
It just seems tough to disconnect the RH side (passenger) because getting in there with all the harnesses/ supercharger in the way will be tough with big hands. |
#3854 | |
| The Following User Says Thank You to AKITA For This Useful Post: | BR-ZED (09-09-2020) |
#3855 |
The Stig's African Cousin
Drives: 2014 wrb brz
Alright so I've recently started having really bad idle problems with my car so much so the car is practically stalling at lights. The car can't hold constant rpm's under load either. So if I try to load the engine to say 2500 rpm in neutral the rpms will bounce around from 2000 rpm to 2500 rpm. My engine is pretty old having 160k miles with about 7k of them being boosted. Tune is fine considering I've put 7k miles on it without issue until now. Car is tuned to run on 93 pump gas and I have a full exhaust system including headers.
I'm thinking my engine is starting to lose compression due to the added stress and its age. What do you guys think? I don't think I have any Vacuum leaks but its on my list of things to check come the weekend.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#3856 | |
Drives: Asphalt FR-S
Sent from my Pixel 4 XL using Tapatalk |
| The Following User Says Thank You to Mad1723 For This Useful Post: | brandonblt2 (09-09-2020) |
#3857 | |
I have the latest Edelbrock kit from Edelbrock themselves. Wasn't that fixed when they upgraded the kits? I'll still give it a shot though.
#3858 |
Comes with a new bypass? Did you verify?
#3859 | |
Yup I checked it. It came with the new one. I tested it anyway just squeezing it seemed fine no loss of pressure.
#3860 | |
![]() Fuel Injectors: after the BO valve verify, this is my first place to look @160k then changing tune and require them to spew more fuel than they've done for 150k miles.. could be drippy dirty injectors. (easy fix) Spark plugs and Coil Packs: would have changed those before SC install , but if either have significant wear.. could be (PTA) Air filter: shouldn't be that unless it's leaking somewhere but doubt it if no initial issues which you didn't have for 7k PCV valve:... sticky?? 160k miles on it?.. that's gonna be a really PTA to change now. I would isolate to test by pulling and plugging at the SC . EGR valve: the one that gets modded.. pulled off the OEM manifold.. could be but not likely if it's doing right at start up.. plus a faulty one I'd think would trigger a code. Head Gasket: doubt that's it for jumpy idle (dye test rule that out but hopefully not) Fuel pumps : could be but the demand on them shouldn't have changed much. MAF sensor: dirty or not seated well.. both? MAF sensor cleaner! O2 sensors: yeah check those( but again, I would hope significant failure would cause a code).. after the above All that good? compression test somewhere in all the above a problem will be found I would think.. hopefully it's not the compression test |
| The Following User Says Thank You to AKITA For This Useful Post: | brandonblt2 (09-09-2020) |
#3861 |
Drives: 14 BSP Edelbrock BRZ
Do you have a Dbox?
#3862 | |||||||
#3863 |
Nope. I was thinking of getting one tho. But with the rough idle and weird power loss problems I don't think it would help my situation.
#3864 |
I would not, just wondering if you did because the harness for the Dbox goes to the MAP sensor and people have had issues with it.
Can you get a log? |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
