#3851 |
I'm not smoking anything. The dip is still there. Just smaller and moved left. Just like I said in that post. Was my post too long for you to have good reading comprehension or were you smoking something?
#3852 |
Fanboy
Drives: 2013 ultramarine frs
I'm totally smoking.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#3853 |
Drives: 2013 Scion FRS
with regards to the tune
"We will have a tune available in the next 2-3 weeks hopefully, but it will be in the form of an ECUtek tune that is locked to the car, but hopefully we are able to have it be open for modification at the end user level in case you want to have a tuner tweak any settings." |
#3854 | |
So basemap from the manufacturer but unlocked for a local dyno fine tuning. Call me old fashioned but this is the right way to do things, expensive but right.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
| The Following User Says Thank You to regal For This Useful Post: | mad_sb (03-18-2014) |
#3855 |
Drives: 2014 BRZ, 08 CBR600RR
Did anybody have any fitment issues? I noticed with mine that the header isn't completely flat on the block side. When torquing it down, the 2 sides would fight each other until it bent and flattened out. I ended up using a small impact to get the flanges to touch and then torqued it to specs since originally it was leaking.
Also @Ryan@Nameless, I have your header and over/front pipe and the overpipe section is extremely close to the block like less than 1/8 inch away. I've adjusted the bolt on the tranny mount to its lowest setting and it rattles under heavy load. Just letting you know in case your jig is a little off before you start your next batch.. |
#3856 |
Drives: Pavement MT GR86
I have the header and 2.5dp and I have much more than 1/8 inch, didn't have issues with the flange either.
Just a very tight fit between the crank pulley and fan
GR86 MT premium
#3857 | |
Drives: 2013 Asphalt FR-S
Seriously though, it doesn't sound bad at all. If you can bring the other midpipe with you and swap it over for a pull after the tune is done... I'm sure the community would be greatful and it would provide a very useful data point.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Sportsguy83 (03-18-2014) |
#3858 | |
~Namaste~ |
#3859 |
So how would leaning out the car with an intake make more power? I thought the car would start pulling timing North of 13:1 under high load.
Was the 6k rpm enrichment drastic?
GR86 MT premium
#3860 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
@14BRZ I just installed the header with the 3" OP/FP and don't have any rattle.
#3861 | |
Drives: Dodge Patitas
Sent from my C6906 using Tapatalk |
#3862 | |
Drives: 2008 Civic Si
As far as if a tune is rich or lean, most stock tunes run, generally, on the rich side. Some cars might run differently than others, but there's a variety of reasons for it, usually engine longevity and catalytic converter life. They might run relatively leaner in the midrange and richen up the last 1000 to 1500 rpms. Safe afr's for all motor (not a true rule of thumb but this motor, but moreover a rule of thumb for engines in general) are between 12.5 and 13.2 at WOT. Some engines lean towards the 12.5 side to make power, while others make more and more as you lean them out past 12.8:1. Still waiting to see some dyno's from someone in here
#3863 |
So you dont think headers can shifter the peaks or valleys of power in the rpm range? Interesting theory.
#3864 | |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 03:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 11:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 05:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-19-2012 12:32 AM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 05:32 AM |
