go_a_way1
Old 03-05-2019, 05:36 PM   #3851
gman6974
Drives: 2018 BRZ
To the ones who have rear mud flaps installed could I ask you a question?
Wtf are you thinking? Tell me, WTF are you thinking? Take them off now. Not later, NOW! You have a nice looking ride and then you screw it all up with the mudflaps. Jesus Christ. Sick of this shit.
gman6974 is offline   Reply With Quote
Old 03-05-2019, 06:29 PM   #3852
new2subaru
Weight Weenie
Drives: 15 FR-S
Old 03-06-2019, 01:01 PM   #3853
junior-subie
Drives: 2017 Subaru BRZ Limited
Very tempted to purchase mud flaps now just for the lolz.
junior-subie is offline   Reply With Quote
Old 04-10-2019, 06:18 AM   #3854
lortto
Drives: Subaru BRZ 16'
Heres my motivation from Finland. IG: sebuzx
Front: 17x9
Rear: 18x12
lortto is offline   Reply With Quote
Old 08-11-2020, 06:23 PM   #3855
alexisv1012
Drives: lighting red
Originally Posted by wutangbrz View Post
I have -14 and I have not done any 'extensive' modification to get this far. There is a lot of ignorance surrounding this topic and i will clear the air on some of this. What I am saying has no relation to your conversation to the other guy regarding wheel fitment on widebody etc, I am just letting you know what it actually takes from a guy who has done such modifications.
extensive modification of EVERY suspension piece to get this extreme
- No. You can just purchase the Racer X rear UCA with the -14 option and you can get -14. direct swap with your OEM and max them out. -> http://racerxfabrication.com/frs-brz...r-control-arms . How do I know? Because I did this as well.
As for the fronts, I hit double digit negative camber up front with aftermarket camber plates, Racer X front LCA, and a camber bolt. Did not do any 'extensive modification' besides install new parts and adjust.
simply would not fit into the stock wheel well .. you'd rub on the inside/outside.. everywhere
For the fronts sure, this could be an issue with the clearance with your wheel to the strut. For the rear, you are only limited until you hit the frame as the coilover sits 'in between' both ends of the barrel nowhere close to the wheel where extreme camber would affect it. At -14 myself on a 10.5 +0, I'm nowhere near the frame/wall nor my coilover. No rubbing issues on the inside of the wheel well. The fender rubbing is a different story depending on what kind of fitment the person chooses to achieve.
I felt the need to address those two things.
When I had pbm rear lowers, my rears also made a small clunk noise. I never figured out what it was but I had never had issues and only ever heard it going over a bump or turning hard. My suspicions are that the endlink was binding on my pbm lca and made this clunking noise. Maybe a pair of aftermarket adjustable endlinks would solve this issue.
Now some updates on my car: wrapped the car myself and rocking a new set up and ditched the bags and I'm now static on BC coils 18kg/18kg
18x9.5 0 - 215/35 Federal SS595
18x10.5 0 - 225/35 Federal SS595
-10.5 front camber, -14 rear camber.
took my sidemarkers out as well, and now i can full lock without rubbing anything.
Sorry to bring up a really old post, but wheels were these? I can't seem to find the name of them from your old posts.
alexisv1012 is offline   Reply With Quote
Old 10-26-2020, 08:24 PM   #3856
dukem4409
Drives: Toyota
A good taste for a ride
dukem4409 is offline   Reply With Quote
Old 11-02-2020, 10:41 PM   #3857
ChazzDiss
Drives: Subaru 2014
"A good taste for a ride"
Right, you are. I particularly dig the exterior. The paint job is just sleek.
ChazzDiss is offline   Reply With Quote
Old 04-23-2021, 09:31 AM   #3858
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Revival - TE37 OG Bronze- 18x9.5 +36 on 265/35r18 Hankook Ventus Evo2 - Squared
The Following 4 Users Say Thank You to NyC Zn6 For This Useful Post:
Cedric (08-19-2021), coastwardpig (04-23-2021), KMA KiCKz (04-23-2021), ripper (04-23-2021)
Old 05-12-2021, 11:17 AM   #3859
windcaster
Drives: 2019 Chevrolet Camaro custom body
larryw, the last one is going as my wallpaper.
windcaster is offline   Reply With Quote
Old 07-13-2021, 02:20 PM   #3860
stinkypoopyshitbox
Drives: 2017 gt86
Originally Posted by Coltonscool View Post
Weds Cerberus 1's
18 x 8.5 +48 square
do you run adapters? and also is this on air? these are my dream wheels and this fitment is one of the first ones i like on the 86
stinkypoopyshitbox is offline   Reply With Quote
The Following User Says Thank You to stinkypoopyshitbox For This Useful Post:
Israel Moore (07-22-2021)
Old 07-22-2021, 01:03 AM   #3861
Israel Moore
Drives: 2015 Subaru BRZ Limited
I like how this shimmery wheel added more accent to this white car.
Israel Moore is offline   Reply With Quote
Old 08-19-2021, 05:44 AM   #3862
Cedric
Cedric's Avatar
17 x 9 +35 Wedssport TC105N with 255/40R17 Bridgestone RE71Rs
Sent from my iPhone using Tapatalk Pro
Cedric is offline   Reply With Quote
Old 01-03-2022, 09:02 PM   #3863
Coltonscool
Drives: WSP FRS, S13 240sx
Yes i ran adapters, and yes i was on air.
The car has since been totaled since i got t-boned. lol
Sorry for the late reply!
Coltonscool is offline   Reply With Quote
Old 11-07-2022, 10:45 AM   #3864
Marckussb
Drives: 2016 frs boosty boi
Front: 17x9
Rear: 18x12
What are the offsets? I have a set of 5x114 BBS LM's I'd like to adapt. These look awesome.
Marckussb is offline   Reply With Quote
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
