Old 08-24-2013, 11:35 PM   #365
Yruyur
Yruyur's Avatar
One of the guys here did color match it with his asphalt. Looked amazing. Headlight just looked like a seamless part of the car.
Sent from a Motorola DynaTAC 8000X
Old 08-25-2013, 12:24 AM   #366
mxsled
mxsled's Avatar
Drives: Audi A3 2012
Originally Posted by retrosmiths View Post
I've heard of plastidip melting on really high temps..plus I read somewhere that when you remove the dip layer, you'll take off the chrome too..
yes,the chrome come off when you try to remove the plastidip...don't use plastidip for blackhousing
pic of last year when I've removed the plastidip of my old tail lights
Moto east Ecutek /JDL UEL Header/Nameless Performance axleback exhaust-Motiv overpipe/Full Perrin CAI/BC Racing Coilover/Traklite angle 18x9/Federal 595 RS-R (245-35-18)/Blackhousing,hid 4300k headlights/Crystal eyes taillight/Anarchy Motive Heavy ShiftKnob/Cusco Sport pedals/Jpm Coachworks alcantara dash panel,cluster,shift boot,
mxsled is offline   Reply With Quote
Old 08-26-2013, 10:09 AM   #367
Diode Dynamics
Diode Dynamics's Avatar
Yeah...I would definitely avoid using plastidip on the headlights, I don't think it holds up to the heat very well and paint looks a thousand times better IMO.
Just my .02
Nick C.
John C.
Diode Dynamics
Old 09-09-2013, 02:03 PM   #368
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Talking
Did this over the weekend following the DIY tutorial by @DarrenDriven
In total, took me about 8 hours.
A few notes/tips:
1. Materials: VHT Epoxy Satin Black spray paint (1 can), 320 grit sanding block, dish washer soap and Grease Grizzly Degreaser
2. Sidemarkers - there's a notch along the bottom you press up on first, then stick the screwdriver in behind the other notch and pry outwards
3. ORGANIZE ALL OF THE CLIPS, maybe it's because I like to think I have A.D.D. There are a lot of clips and bolts that need to come off, EVERYONE hates it when you're missing or ending up with an extra bolt. (see 2nd attachment)
4. Oven heat - I baked my lights at 220 degrees for 14 minutes. Took some effort to pry apart the housings, but it saved the risk of melting anything
5. BE PATIENT, this takes a lot of time. Don't even think about skipping any of the steps, do it right, and do it 100%
6. The highbeam rubber seal does not simply pull off like the lowbeam rubber seal, you need to remove the 3 screws, pull off the plate, then twist the seal until it "clicks" off.
Clip Organization
I really like the finish of the VHT Epoxy satin black, can withstand up to 250 degrees, plus it doesn't require a primer. I'd suggest you sand off the chrome coating using 320 grit sandpaper, it'll help with the spray-on paint. Once done, I sprayed on the Grease Grizzly Degreaser, then washed again with dish washing soap; hang-dry and wipe off with a cloth. Go easy on the first few coats, I waited about 10 minutes between coats out in the sun. Once done, I followed all the steps in reverse order and applied some Permatex Black Silicon adhesive sealant around the edges as a "just in case"
ck-GT86 is offline   Reply With Quote
Old 09-09-2013, 11:10 PM   #369
Charky
Charky's Avatar
Drives: Fr-s 2013 Hot Lava
Originally Posted by DarrenDriven View Post
Oops, yeah, my bad.
Darren how is the light output off your headlights with the hid 55w kit throw time??? Is it the same as the first time you intalled them.
Charky is offline   Reply With Quote
Old 09-10-2013, 01:48 AM   #370
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Originally Posted by ghost86 View Post
Anyone done a color besides black? I'd love it on one of the lighter colors but still want some contast on my Ultramarine. Just want the chrome gone. Thinking about trying Krylon Fusion Satin Pewter Gray.
I did mine color matched, a whit out color matched and a color matched black.. Paint was bought from here
http://Automotivetouchup.com
Results
Best pic I have of mine in asphalt
Best picture of the black
The white out
Again, these are all perfect color match paint.. The black and the asphalt have the perfect amount of metallic
Also a customer asked me to do his headlights in plastidip
Then later decided to go quad projectors, because of the epoxy the halos tear the plastidip and I had to peal it all off both lights.. I never took a picture after but the lights came out like they never had anything on them. Chrome and everything came out great
I've never touched the chrome with anything but fresh gloves.. I don't clean, sand, wipe, anything to the chrome housings.. I use krylon paint, usually satin black and in over a year have not had one problem..
My first retrofit, after sanding and cleaning I always had fish eyes or other problems.. Since then I've just sprayed them how they come out of the assembly and have not had a issue yet
Gixxersixxerman is offline   Reply With Quote
Old 09-10-2013, 11:37 AM   #371
retrosmiths
Drives: Scion FR-S Whiteout
What projectors did you use for the retrofit?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 09-11-2013, 01:14 PM   #372
Gixxersixxerman
I used the new morimoto 6.0 mini H1..
And for the quads I use the morimoto matchbox projectors
Old 09-11-2013, 02:30 PM   #373
retrosmiths
So TRS now includes 6.0's instead of 5.0's in the FR-S Retroquick Kit?
2013 Scion FR-S
Old 09-11-2013, 05:33 PM   #374
Gixxersixxerman
No, I got those kits from headlightsquick.com, those FRS on there I did.. I got with TRS to see if they would take my template to have them all cut the same.. Then a 5.0 or 6.0 would work
Old 09-11-2013, 05:36 PM   #375
Gixxersixxerman
Blacked out BRZ lights I did yesterday
Old 09-12-2013, 12:11 AM   #376
retrosmiths
Can you post said template?
I always thought the mounting points/screw holes are the same for both 5.0 and 6.0..
2013 Scion FR-S
Old 09-12-2013, 02:31 AM   #377
Gixxersixxerman
They are the exact same, the problem is the 6.0 is wider and taller, so some minor trimming is required, problem is the metal is so think I have to use a dremel with a cutoff wheel. Yeah, I'll get a picture and post it.. The template is one of the brackets I haven't used, I just traced off of it for awhile, I've done so many since the group buy Vegas86 did that I don't need it any more, I know the cuts by heart now
Old 09-12-2013, 06:59 PM   #378
retrosmiths
Cool man, let me know, I'm planning to upgrade to 6.0.
2013 Scion FR-S
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 10:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) — General Topics 23 04-21-2012 09:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 04:20 PM
