Old 02-07-2016, 02:54 PM   #365
evan_gt86
evan_gt86's Avatar
Drives: 2013 Scion FRS
I've had these installled in my car for about 2 weeks now, and I've got mixed feelings about them. I was able to drop my car to the perfect height, and it looks great, however, the car feels like it handles worse than stock. It's been aligned, my preload is set to "snug" on all 4 corners, and I've tried several different damping settings, and the car still feels worse. It feels floaty and more unstable on high speed corners, and body roll feels way increased.
Anyone else feel like it made the handling worse? The ride is pretty good, better than stock, ill admit that.
Is the increased body roll due to the spring rate being the same front and rear? Do I need a stiffer front sway bar, or possibly rear?
Here's my current alignment specs, top is before, bottom is after alignment.
evan_gt86 is offline   Reply With Quote
Old 02-07-2016, 03:16 PM   #366
nickg
Drives: 2014 Whiteout FR-S Manual
The roll geometry in the suspension actually increases body roll the lower you go. I'm pretty sure white line has a kit to correct this.
Sent from my XT1575 using Tapatalk
nickg is offline   Reply With Quote
The Following User Says Thank You to nickg For This Useful Post:
evan_gt86 (02-08-2016)
Old 02-07-2016, 03:58 PM   #367
Well you lowered your car; your roll center has dropped so you *did* increase your body roll. Not only that, you also deleted all your front camber; you have less front grip.
evan_gt86 (02-08-2016), strat61caster (02-07-2016)
Old 02-07-2016, 05:28 PM   #368
WRBrzRX
Drives: runs&drives
I'd get that front camber to -1.5 asap, you went the wrong way with it
WRBrzRX is offline   Reply With Quote
The Following User Says Thank You to WRBrzRX For This Useful Post:
Old 02-07-2016, 10:50 PM   #369
shattered_memory
Drives: Satin White BRZ Limited
You should do some research on suspension bro. First of all, if you lower your frs more than 1.5 inches on these coilover, you are messing with your geometry. This means that you will get more body roll because the angle of the LCA is pointed at a higher location than stock. Sure the flex zs have a higher spring rate, but you are also on stock crap tires. Stiffer suspension plus all season tires will make handling horrible. Plus your alignment is wack. Plus you are running rear spacers, which also contribute to more roll in the rear. It's not the suspension that's at fault, it's the way you tuned your car. What I recommend is better tires. Michelin pss at the minimum. Then raise the car up a little. I recommend 1.2 inches drop in front and 1 inch rear. Then get a new alignment. - 1.5 front and - 1 camber rear. Then you will see how much better your car will handle. Also set front shocks 7 clicks from stiff and 8 from stiff in the rear. I have my flex zs for 2 months now. They are fantastic! You need to learn to set your car up.
shattered_memory is offline   Reply With Quote
The Following 7 Users Say Thank You to shattered_memory For This Useful Post:
CSG Mike (02-08-2016), CxG (05-24-2016), evan_gt86 (02-08-2016), Kris86 (09-13-2016), SmartedPanda (02-09-2016), Spechtre (11-16-2016), stock (06-24-2016)
Old 02-07-2016, 11:59 PM   #370
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by tracerit View Post
I do have a box in there that appears to slide around but I put on what I thought were protective enough homemade caps from some tubing. I only got two caps and placed those in the front, already lost one too.
I'll look into putting the box in the back seat and leaving the trunk empty to see what's going on. That night be the issue. Thanks guys
i have the subaru trunk liner in my trunk, and it covers up the rear damper adjustment knobs; protecting them from anything moving around in the trunk. no trimming needed.
shiumai is offline   Reply With Quote
Old 02-08-2016, 12:12 AM   #371
tyler_win_photo
tyler_win_photo's Avatar
You should consider some rear lcas to adjust camber in the rear. -3 in the rear is an awful lot to be running on a street car if you're aiming for performance.
tyler_win_photo is offline   Reply With Quote
Old 02-08-2016, 01:13 AM   #372
evan_gt86
evan_gt86's Avatar
Thanks for the input, I'll look into that.
Thanks Mike, your input is much appreciated. Sounds like I need to dial in a little negative camber in the front.
I see, my guess is the alignment shop geared the alignment towards tire life, instead of performance. Unfortunately I don't have any performance oriented shops in my area. May have to dial it in myself.
Thanks for the input. I understand it's the not the coilovers fault, and I know it's my suspension being tuned improperly. This is why I came looking for advice in this thread. I am inexperienced when it comes to suspension tuning, however I do install all my own stuff, so I have that going for me at least. I'll take your advice and start with the ride height, and camber adjustment.
Yeah I agree, the alignment shop told me this as well. I'll look into some adjustable LCA's. I'm aiming for a good daily driver setup, with an occasional autocross event during the summer months.
The Following User Says Thank You to evan_gt86 For This Useful Post:
Old 02-10-2016, 03:52 PM   #373
shellslinger
Drives: Whiteout FRS
Everything work out for you? @evan_gt86
shellslinger is offline   Reply With Quote
Old 02-10-2016, 09:06 PM   #374
Tor
Tor's Avatar
Drives: Toyota GT86
..or just tell the shop what you want. They dial it as close to stock specs as they can (green) if you don't explicitly tell them otherwise. You don't want stock specs, because your car isn't stock anymore.
In addition to what's already been said:
If you raise the car a bit as suggested, it will not only correct your geometry as explained (and make the Whiteline roll center correction kit redundant).
It will also reduce the negative camber in the rear (more low = more negative camber).
Also, I second the need for rear lower control arms in any case. They should be mandatory on any lowered car. They are not that expensive all things considered. You can get a set for around $200.
Tor is offline   Reply With Quote
Old 02-11-2016, 12:46 AM   #375
evan_gt86
evan_gt86's Avatar
I haven't made any changes yet, hopefully this weekend.
Thank you for your input, I really appreciate it. I'll start by ordering some rear LCA's and raising the car a tad, then go back for an alignment, and specify the specs I'd like.
Thanks everyone for the help!
Old 02-13-2016, 04:28 AM   #376
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
@CSG Mike in terms of durability for a supercharged car running 2 or less track days a year would you go with the Flex Z, RSR Sport I, Bilstein B8/Swift Spec R, or something else?
Looking for a good mix of comfort driving 20k miles a year. I have some bushings (rear subframe and rear uca) and on Feal 441s right now. Love how it handles but its a bit rough for DD. Tempted to dump my autox build for a better DD canyon experiance since thats what I do more.
Old 04-20-2016, 11:49 PM   #377
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
What LCAs can you get for ~$200?
gkubed is offline   Reply With Quote
Old 04-20-2016, 11:52 PM   #378
mtblackfrs
mtblackfrs's Avatar
Drives: 2014 black Scion FR-S
Mine. Currently selling my PBM for $150.
mtblackfrs is offline   Reply With Quote
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 04:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 04:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 04:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 05:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
