#365 | |
good fitment on a 6.5-7" wheel with good hook. If you hit up the strip in the spring post up before you do man, would be cool to have a few 86's out at once
#366 | |
Drives: 2015 Scion frz
Sounds good ill def keep in touch for when the tracks re-open! |
| The Following User Says Thank You to icybrzzz For This Useful Post: | Berserker (11-11-2020) |
#367 | |
has a funny hat
Drives: 2014 BRZ Limited
@Berserker do you have a steel bell housing or explosion shield? The idea of dumping a clutch at 7k+ without one scares me, but I like having feet. |
#368 | |
To grenade a clutch to the point of it coming off the flywheel is very extreme and hard to do in most cases. Driveshaft safety loop would be the first priority if you are on a full slick just for the piece of mind. If anything the shaft is coming through the tunnel before the clutch is. Again doesn’t hurt to have but personally I wouldn’t consider it until you start getting into big power or crazy 1.5-1.4 sixty foots and below.
#369 |
1/4 Mile times
Man I’m kind of surprised it’s that slow after all that weight reduction. My old 1995 Integra GS-R ran consistent 14.2s and it was mostly stock. I had Type-R pistons, Type-R header and an OEM flywheel turned down to 13lbs. At the track I would pull all the obvious stuff out but also pull the rear seats and passenger seat. I would also remove the cat so it just dumped right after the headers. Haven’t taken my FRS to the track but I was figuring it would run 14.1 or better on E85. I guess I need to get to the track. Edit: never mind I missed the part where you said it was bracket racing ant you were lifting at the end. Also the stock tires are a complete joke. Just about any 200tw tire would drop your time much less a drag radial. If anything the drag radial would give too much hookup on stock power. |
| Scion's free 2 year/25K mile maintenance plan? | whtchocla7e | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 06-06-2012 04:26 PM |
| La Times reviews BRZ | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 7 | 05-18-2012 12:11 PM |
| He lives his life 1 quarter mile at a time | ucla bruin | Other Vehicles & General Automotive Discussions | 8 | 12-21-2011 08:04 PM |
| $95 Track day at Willow Springs- Horse Thief Mile-Oct 16th | Louie | Southern California | 1 | 10-11-2011 01:31 AM |
| $85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal | Louie | Southern California | 2 | 03-20-2011 06:17 AM |
