08-14-2015, 10:21 AM | #365 | |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
08-14-2015, 06:43 PM | #366 | |
Drives: 2020 BRZ PP
Gotta remember this swap doesn't include clutch, gauges, fluids, brakes, and a bunch of other misc parts. It all adds up. |
08-14-2015, 07:53 PM | #367 |
Drives: Scion FR-S
Why would you need new brakes and gauges? You're not added enough weight to necessitate increased braking power and the whole point of canbus wiring is to be able to use the stock electrics and gauges. I understand clutch and fluids.
The Following User Says Thank You to djliquidsteele For This Useful Post: | Draco_PR23 (08-14-2015) |
08-14-2015, 08:13 PM | #368 |
Stig's dark passenger
Might need a little extra stopping power going from 200hp to 525.
Just sayin' |
08-14-2015, 08:40 PM | #369 |
Drives: 2015 brz
08-14-2015, 09:52 PM | #370 |
Drives: FRS Silver LS1 swapped.
Can't give a decent account as far as handling till a front sway bar/stiffer springs......right now over steering is very easy....and not by over use of throttle.....but that's always an option.
08-15-2015, 01:39 AM | #371 |
Junior
Drives: a car
in case the sway bar and springs dont work, do you think it might be your diff?
08-15-2015, 05:13 AM | #372 |
08-15-2015, 06:21 PM | #373 |
Junior
Drives: a car
depending on how the clutches are setup, your accel or decel settings might contribute to it.
08-15-2015, 06:49 PM | #374 |
08-15-2015, 08:56 PM | #375 |
Junior
Drives: a car
So the package comes with a custom driveshaft to hook up to the old diff. I wonder how long the stock diff will last.
08-16-2015, 07:35 AM | #376 |
Because compromise ®
Drives: Red Herring
Will/have the suspension spring rates change/d?
08-17-2015, 05:27 AM | #377 |
Stock differential has proven to be stout....on even higher HP/torque number cars than mine.....shouldn't be an issue. Axles are another story, but I already have that covered.
The Following 3 Users Say Thank You to cf6mech For This Useful Post: |
09-08-2015, 09:01 PM | #378 |
Drives: 2017 Camaro 1SS
So do you have the car back now? Is it complete?
Sent from my LG-D851 using Tapatalk |
Similar Threads | ||||
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates | Steeze_Its | Brakes, Suspension, Chassis | 7 | 06-27-2014 09:32 PM |
FS: Vorshlag Front Camber Plates | h4nh | Brakes, Suspension, Chassis | 1 | 03-01-2014 10:49 PM |
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) | serial gixxer | Brakes, Suspension, Chassis | 18 | 05-20-2013 08:51 PM |
WTB: Front Vorshlag Camber Plates | YDNA | Brakes, Suspension, Chassis | 0 | 05-03-2013 05:31 PM |
Maybe a repost, but have you seen the Vorshlag project car? | Bart1 | BRZ First-Gen (2012+) -- General Topics | 3 | 01-07-2013 01:19 PM |
