Old 05-18-2014, 05:23 PM   #365
vaderbloke
Drives: 2014 Subaru BRZ
+1 that!
vaderbloke is offline   Reply With Quote
Old 05-18-2014, 05:27 PM   #366
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by sales@delicioustuning.com View Post
Those that are claiming the intercooler is restrictive and heat soaks too quickly likely haven't figured out how to properly tune for it. It's not so much a drop in power so much as you aren't making more with it over a stock manifold and every one we've tested has had an exhaust leak that needed to be fixed. I'd go with JDL EL or UEL or the newly revised PPE setup. Fuel pump can be stock or DW65C, it's whichever you prefer. And yes, this setup is flex fuel capable as long as you have a flexfuel kit. Off the shelf. We have over a thousand hours in the Innovate setup, so much so that bringing it in for custom tuning would seriously not net you anything more and would cost much more.
Sincerely,
Zach
What kind of power are you seeing on 91 octane with the Innovate intercooled kit? Is the 70mm pulley an advantage on 91 octane?
Old 05-18-2014, 05:29 PM   #367
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Draco-REX View Post
I'll look into another header, but I'll stick with the Borla for now. The fuel pump thing is interesting. I'll stick with the stock pump if it handles the increased flow without a problem. No need to crack open the tank for no reason.
So, with an IC, 70mm pulley, and Flex Fuel kit, I only need to purchase the Stage 2 E85 tune from your website and I'm knocking on 300 rwhp (DynoJet numbers) and have full flex-fuel capability?
That's fantastic.
I picked up the pump and injectors on a recommendation from another tuner. I'm amazed by how much you are getting out of this engine with so little in fuel modifications. Frankly, hitting close to 300 rwhp on a DynoJet was beyond my hopes when I started assembling these parts. I thought I'd max out around 260.
8 months of delays and other issues, I'm finally going to be able to get this done. I can't wait.
Technically if you're using a Flex Fuel Kit it would be the Flexfuel Stage 2 tune. Same power. Just let me know when you're ready to get that tune and I'll set you up Most other tuners like to use bigger injectors, but we have a way of using both PI and DI to their fullest throughout the range. Hence why we can keep stock injectors up to around 330whp on E85.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Draco-REX (05-18-2014)
Old 05-18-2014, 05:32 PM   #368
DeliciousTuning
The 70mm pulley can be used on 91 octane but you absolutely must have the intercooler. Not safe otherwise unless you completely neuter the car timing wise. Pulling some numbers out of my rear that I'm entirely unsure of, I'd say probably 240whp ish with the stock pulley, and maybe 275-280whp with the 70mm pulley on an Intercooled 91 octane setup. Again don't quote me on that, I don't have access to all the charts from home
Sincerely,
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Calum (05-18-2014), texasbound972 (05-18-2014)
Old 05-18-2014, 05:59 PM   #369
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Sincerely,
Zach
Great! I'll let you know when I have the car together.
Old 05-18-2014, 06:45 PM   #370
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Who makes the custom cams on the Delicious NA race car that you guys are tuning, and will they be available to the public in the future? Does it have any other internal/head/engine mods besides cams and I am assuming springs/rockers? Stock lower-end/block?
I remember you were talking about it and said that you couldn't post the secret dyno results yet; but promised it will be indeed spectacular
fooddude is offline   Reply With Quote
Old 05-18-2014, 06:56 PM   #371
Calum
That Guy
Sincerely,
Zach
When you get the chance, can you confirm those numbers. Those numbers change a few things.
Old 05-18-2014, 07:29 PM   #372
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
My car with the intercooled kit, stock pulley, PPE headers and Nameless high flow cat downpipe made 56 additional whp on CA 91 octane pump gas when tuned by Delicious at HG Motosports. HG has a Dyno Dynamics dynometer, so the whp figures are low compared to a dynojet. Base run was 154.5 whp. Car was stock except for the highflow catted downpipe. After parts install and tune the car made 211 whp.
211whp isn't a big number but the kit and tune make the car run very smooth. No more torque dip and no more idle surging when trying to drive in first or second gear on a cold start (people would look at me funny when leaving a parking lot). Those are two problems that I disliked with my stock FRS.
Hope that helps, if you want I can pm you a dyno pic? I should probably post that pic on my build thread actually.
Anyway, now that I'm getting used to the extra 56whp I plan to save my pennies and upgrade to a smaller pulley and lighter flywheel and get another tune
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
The Following User Says Thank You to MINOCIN For This Useful Post:
Calum (05-18-2014)
Old 05-18-2014, 07:30 PM   #373
DeliciousTuning
Whatever I told you before was most accurate, I had Bill telling me numbers over my shoulder :P Mind sharing with the rest of us? lol
Sincerely,
Calum (05-18-2014)
Old 05-18-2014, 07:33 PM   #374
DeliciousTuning
Right, so those numbers on 91 octane and stock pulley equate to about 245whp on the local dynojet. E85 adds about 30whp (dynojet) and the smaller pulley adds another 30whp which brings you to right about 305whp on a Dynojet. There you go
Sincerely,
Old 05-19-2014, 02:40 AM   #375
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
How to order a NA flex fuel tune from you?
I have try to contact you from your website with no luck.
Mars2 is offline   Reply With Quote
Old 05-19-2014, 07:15 PM   #376
protpibe
protpibe's Avatar
Read back a page or two. They were evacuated due to wildfires a few days ago
Old 05-19-2014, 08:31 PM   #377
DeliciousTuning
We are back now, safe and sound.
We have not seen any message from you on our website, as we looked. It might have been going to our spam and we do apologize for that. But we are alive and doing well. Just working on catching back up with customers tunes and more updates.
As for the NA FlexFuel Tune, please order through this link. There are options at the bottom of the page so you can select the FlexFuel tune from options listed.
Stage 2 Pump Gas and FlexFuel / E85 Tune
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
Calum (05-19-2014), mikalem (05-19-2014), protpibe (05-19-2014)
Old 05-19-2014, 08:37 PM   #378
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Cheers,
William Knose
Glad to hear that you guys are safe!!
Sent from Samsung Galaxy Note 3
Area86 is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
