Old 06-11-2018, 03:07 PM   #365
jjaisli
jjaisli's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by wparsons View Post
Ah, crap. Can't make this month happen. Had the option of going on the 28th as well but had to back out because of work.
Tremblant Options...
http://www.boston-bmwcca.org/events/...px?EventID=982
It's a US group and BMW based but a great group of guys and usually a handful of twins present (including my own)
jjaisli is offline   Reply With Quote
Old 06-11-2018, 04:17 PM   #366
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Mine too!
gcranston is offline   Reply With Quote
Old 06-12-2018, 11:12 PM   #367
gcranston
Originally Posted by ZDan View Post
I'd like to be able to recommend the RE71Rs to ya, but after 3 track days and ~2000 street miles mine are DONE!
Just noticed a small blister on my front outside tire. Similar to ZDan, 4 days on track (2 under an MX5, and 2 under my BRZ) and a few thousand street miles. Bummer - I was hoping to rotate them and get another event out of them. Going to try Toyo R1R's and a little wider.
Old 06-15-2018, 10:08 AM   #368
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Re71R are prolly the fastest tire short of Hoosier R7/BFG R1 I have tried. Found them to be quicker than the Toyo RR (not a typo). But agree they wear fast!
Bimmerworld sells used Conti slicks (225/45/17) which is a touch slower than the R7 and lasts a while. For the money like $75 each, they are not bad. I got a set and now have 15 heat cycles and they are fairly consistent (not as fast but last a while for when I am doing testing/DE and not TT). Almost as fast as RR (per the data/laptimes) and hold up the entire session vs fall off towards the tail end like Re71. But RE71s are the bees knees, unreal for the cheater 200 rating
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 06-15-2018, 04:09 PM   #369
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Lutfy
Yeah RE71R not a tire worth running unless required by class rules. Fastest in class for sure but the downsides are huge!
Element Tuning is offline   Reply With Quote
Old 06-15-2018, 04:55 PM   #370
i8ur911
Drives: 17 BRZ Series.Yellow
It's the perfect TT tire....in the right situation.
For instance the club I run with gives you 2.5pts for the Conti scrub or -2.5pts for the RE71R. So, you play the points game and run the RE71R as your TT only tire and practice on something less expensive and/or something longer lasting (NT01, Conti scrub, etc).
Sent from my Pixel using Tapatalk
i8ur911 is offline   Reply With Quote
Old 06-15-2018, 05:06 PM   #371
Element Tuning
I agree and that's my point. Your class rules make it so that tire is the fastest based on the points penalty or if the class has treadwear rules. For the TT class I run there's no points, just power to weight ratio (and some other rules clearly) so my best tire is a DOT and then I have to factor in traffic. I'm going to start lapping the field on my 2nd to third lap so I need a tire that will work on lap 1 and if I mess up I can go one more lap. That tire is a Hoosier A7. A Pirelli DS is faster but because it's not DOT it's like a 50 hp penalty the A7 results in a quicker lap.
For someone who's doing an HPDE, the RE71R is a poor choice, but not because it isn't a fast tire.
Old 06-15-2018, 07:17 PM   #372
i8ur911
Very true in all aspects
Old 06-17-2018, 04:05 PM   #373
Str8Ghostin
Drives: 2014 Raven Scion FRS 6MT
Canadian Tire Motorsports Park (Mosport) DDT/1:40.3/Steven Dimovski/06/03/18/NA Crawford Performance Intake Manifold Spacers, Torque Solution Throttlebody Spacer, TRD Cold Air Intake, Gruppe S 4-2-1 UEL Header And Overpipe, BERK Technology Front Pipe w/High Flow Cat, Invidia N1 Cat-Back Exhaust, OFT Stage 2 UEL 91 Octane Tune, HSD Monopro Black Coilovers, SPC Rear Lower Control Arms, Hotchkiss Front And Rear Adjustable Sway Bars, Megan Racing Front And Rear Strut Tower Braces, Grimmspeed Brake Master Cylinder Brace, Perrin Gearbox Bushing, Whiteline Transmission Bushing, Torque Solution Shifter Extender, Mishimoto Weighted Shift Knob, RR Racing Stage 1 Big Brake Kit (Wilwood 6-Pot Superlite Calipers, Delios 13" Slotted Rotors, Goodrige Stainless Steel Front and Rear Brake Lines), Wilwood Polymatrix A Compound Front Pads, EBC Yellowstuff Rear Pads, Rota Titan Wheels 17x9+42, Bridgestone RE71-R Tires 255/40/17, IKON Motorsports Front Lip, 5axis Rear Trunk Lip, SARD LSR Rear Wing, Motul RBF600 Brake Fluid, Motul Gear 300 Oil For Transmission and Differential, -3.0 Front Camber, -2.0 Rear Camber.
Str8Ghostin is offline   Reply With Quote
Old 08-26-2018, 10:58 PM   #374
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Track Name: Road Atlanta
Track Time: 1:44.503.
Driver Name: Jerami Bailey
Date: 08/26/2018
Mods: full exhaust 1high flow cat, grimmspeed intake. Fortune auto 500 coils, front sway bar, rear subframe bushings, rear lca and toe arms, ap sprint bbk dtc 60 pads, Sparco Evo seatssolid mounted, vented hood, tiny battery Graham tune @ Boosted performance tuning. Beastronix pedal dance box
93 pump gas,
rival s tires 245/40*17
Basically a full stx build minus some bushings plus a vented hood.
Proof in picture, ironically enough I was place 86 overall.
jbailey8748 is offline   Reply With Quote
Old 09-17-2018, 05:26 PM   #375
lutfy
lutfy's Avatar
Dominion Raceway VA
NASA TTD Trim running Hoosier R7 225/40/17 on 17*9 wheels.
Stock brakes with Hawk DTC70, OS Giken custom tuned 1.5w diff, MCS Doubles 550/650lbs, APR GTC wing with front splitter, @steve99 custom tune, P Tuning header.
2850lbs with driver
1:33.6 from this last weekend.
[ame]https://www.youtube.com/watch?v=b8FiM9FZCuc&t=30s[/ame]
Lutfy
2022 LR Defender
2023 BMW M2
Old 09-28-2018, 12:33 AM   #376
Robbie
In the slipstream
2:06.44 at High Plains Raceway
245/4017 RS4’s
17x9 RPF1
MCS Singles
DTC 60 pads
Robbie is offline   Reply With Quote
Old 09-28-2018, 09:28 AM   #377
Pat
Pat's Avatar
Drives: 2023 BRZ
Nice! New best?
Old 09-29-2018, 12:51 AM   #378
Robbie
In the slipstream
Originally Posted by Pat View Post
Nice! New best?
Yep! I was surprised the old tires I have had it in them!
Can too much grip hurt track times? ayau Tracking / Autocross / HPDE / Drifting 53 04-22-2013 10:28 AM
Top Gear (UK) track times GeeTee86 AFRICA 29 02-15-2013 07:04 AM
Before/After Track Times (Sonoma Raceway) CorteXracing Tracking / Autocross / HPDE / Drifting 5 11-26-2012 10:28 PM
POST YOUR FASTEST GT5 NURBURGRING TIMES.... FT-86GOD Other Vehicles & General Automotive Discussions 96 07-15-2012 12:45 PM
GT5 - fastest Suzuka (full track) times NESW20 Other Vehicles & General Automotive Discussions 11 04-03-2011 12:20 AM
