Old 04-22-2019, 12:49 PM   #365
JD001
JD001's Avatar
Drives: Subaru BRZ
When will the owners of MY '13, '14 and '15 get a similar letter about the shite Subaru head unit that is found in our cars? I can't believe they went to the trouble of installing a circa 1972 unit...
Old 04-22-2019, 01:02 PM   #366
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Forget it, manufacturers don't give a fuuuuuk about the radio once the car leaves the factory, the 17+ cars are getting fixes because the radio handles the backup camera and that's considered safety equipment.
Old 08-26-2019, 03:39 PM   #367
Scourge
Agent 86
Drives: 2017 Toyota 86
Just wanted to mention I completely forgot about this thread because I haven't gotten any codes since I had this fix done.
Originally Posted by Scourge View Post
Here's a link to a copy of the TOYOTA (not Scion) TSB (T-SB-0154-18) for the Toyota 86's P119F/P219A issue...
https://static.nhtsa.gov/odi/tsbs/20...53203-9999.pdf
Source:
https://www.nhtsa.gov/vehicle/2017/T...Communications (Dec 10, 2018 Engine)
Can someone save this PDF and attach it to main page?
Scourge is offline   Reply With Quote
Old 10-08-2019, 01:55 PM   #368
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Added:
NHTSA Campaign Number: 18V772000
Manufacturer Subaru of America, Inc.
Components ENGINE AND ENGINE COOLING
Potential Number of Units Affected 165,534
Engine Valve Spring Failure may cause Engine Stall
Old 11-09-2019, 01:46 PM   #369
Ragin Gti
Drives: '15 Subaru BRZ
There’s a new TSB for ‘17-20 BRZ, automatic transmission only. It’s an ECM update to prevent a false P0300 code setting and turning the check engine light on. TSB 11-193-19. It involves an ECM software update.
Ragin Gti is offline   Reply With Quote
Old 12-15-2019, 10:23 AM   #370
immortal_suby
Drives: 2015 BRZ Limited 6MT
Subaru TSB 05-61-16 Suspension mounts
Manufacturer: Subaru of America, Inc.
Components: suspension mounts
Number: 05-61-16
I didn't see this TSB in here. I am having this problem of popping noise from the strut mount and searched the forum but did not see anything from subaru about it. There are several threads on suspension noise that point to the top mounts but no mention of a TSB.
I was very close to buying the parts and doing it myself based on the how-to's I've seen here for suspension and then stumbled upon the TSB.
Maybe I'm the only one over 60k still running the stock suspension....
@ichitaka05
File Type: pdf Subaru TSB 05-61-16 Suspension mounts.pdf (310.8 KB, 182 views)
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
Last edited by immortal_suby; 12-15-2019 at 10:31 AM. Reason: add mention of ichitaka05
immortal_suby is offline   Reply With Quote
Old 04-09-2020, 07:55 AM   #371
knucklehead
Drives: FRS
I can't seem to find the proper link for the valve spring recall. Is that only limited to the 2013 engines or does it also include the 2014 to 2016 engines?
knucklehead is offline   Reply With Quote
Old 04-09-2020, 09:22 AM   #372
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
2013 only.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 04-09-2020, 09:24 AM   #373
Opie
Opie's Avatar
Number: 05-61-16
@ichitaka05
If you are at 60k you are out of warranty for the strut mounts, they are only covered under the 3/36. TSB's do not extend warranty coverage.
2023 GR Cup Car
Old 04-09-2020, 09:31 AM   #374
Originally Posted by Opie View Post
2013 only.
Not even all of the 13s. You need to check the VIN.
https://www.toyota.com/recall
Old 04-09-2020, 01:02 PM   #375
knucklehead
Drives: FRS
2013 only.
Thanks Opie
Old 04-09-2020, 01:04 PM   #376
knucklehead
Drives: FRS
Thanks Tcoat. I was looking into probable issues with 2014-2016 motors as I am looking for a used one. And those that I am finding are from wreckers who more often than not has the motor already out of the car so I am unable to verify the VIN.
Old 04-09-2020, 02:00 PM   #377
There are very few issues reported with the post 13 engines.
Old 04-09-2020, 07:10 PM   #378
knucklehead
Drives: FRS
Thanks Tcoat!
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 12:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 07:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 10:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-04-2012 11:45 PM
