, dpfarr
Old 07-22-2020, 01:06 PM   #3753
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
Originally Posted by BR-ZED View Post
That might explain it then.... this was middle of the band, around 4k. Will have to check my logs when i get home to see what it looks like at higher rpm.
Toast, was that on the stock pulley? 11 is a lot bigger than 9...
my bar per logs is .7 over 1 bar at 7300 rpm = 10 psi
my bar at idle averages .30 to .25 .. I'm just gonna call it .7 below standard atmospheric press.. -10 psi at idle below so that's a vacuum
Idle log below .. I'm not able to use datazap on current comp so that link may or may not work
https://datazap.me/u/scdata2?log=0&data=30
AKITA is offline   Reply With Quote
The Following User Says Thank You to AKITA For This Useful Post:
BR-ZED (07-22-2020)
Old 07-22-2020, 04:27 PM   #3754
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Hey All!
I've been a member of this thread since it popped up in 2015. I bought a BRZ limited back in 2013, and purchased the Edelbrock in February 2016. My car has been mostly garage parked for the last two years due to work, and now I'm finally getting it back in running shape. I just had the recall work done last month, and I've put about 500 miles on the engine. I've re-read the entire thread and I can't thank you all enough for the valuable information you've shared here.
After reading through, I have flagged these as the needed fixes/updates:
- v2 Coolant Surge Tank
- Upgraded bypass actuator kit
- Update Delicious Tune (currently on v21)
- Dbox firmware update potentially (purchased when first released)
Is there anything I have missed?
Silverfox is offline   Reply With Quote
Old 07-22-2020, 08:49 PM   #3755
AKITA
AKITA's Avatar
Looks like that covers it.. I don't know how they update the firmware or if that is necessary on the Dbox, call DT on that one and see if it's necessary.
Silverfox (07-22-2020)
Old 07-22-2020, 09:47 PM   #3756
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Originally Posted by toast View Post
Where in the rpm range are you measuring 6 psi of boost? At 7k I hit a little over 11psi.
Most people misunderstand how boost is created by a roots blower. It generates constant boost only in an open system. Once you attach it to an engine you get linear boost with rpm.
Last image on this post:
https://www.ft86club.com/forums/show...postcount=3357
Count me as one of the ones amongst the uneducated... I did not realize it grew linearly w/ RPM. It is misleading because when you get on the throttle the boost jumps way up, so it is hard to not think it is full boost... it definitely grows w/ RPM but does so subtly. I should have reviewed my logs instead of just going with a few datapoints i mentally grabbed off my ECU Connect dashboard.
It would be really nice if ECU Connect let you review logs in the tool. Anyone have any good tools for reviewing logs directly on your android? I also cannot find the files so have to resort to using the "share" option inside the app which is a little annoying.
Yeah that log link doesn't work... it just takes me to my datazap home page. But you will see our numbers are in line w/ each other.
The way my logs are set up makes it seem they are logged directly to PSI, which is nice I don't have to do the conversions...
First log I see
off throttle ~3 psi
idle ~5 psi
full throttle ~7400 rpm 24.3 psi
atmosphere 14.8 psi
So yeah I am at about 9.5 psi of boost, cool.
https://datazap.me/u/br-zed/sc-log-3...5-35&solo=7-35
In another log (not posted) I seem to be idling around 1000 rpm (seems a little high) at 5.6 psi. Probabyl would drop w/ a lower idle.
In this log I again see good numbers
https://datazap.me/u/br-zed/sc-log-4...g=0&data=15-35
24.9 psi @ 7388 rpm
25.4 psi @ 7204 rpm
24.7 psi @ 7348 rpm
25.1 psi @ 7356 rpm
atmosphere 14.74 psi, so boost is 10.16 psi, 10.66 psi, 9.96 psi, 10.36 psi.
So it looks like our cars are right in line w/ each other.
So I guess I am not worried as much. The supercharger is louder than you all describe (that doesn't bother me assuming there is no defect) but it appears to be working properly so that is a good sign. And I assume there are no vacuum leaks or boost leaks since it is hitting all the numbers listed above. It drives really well.
Hopefully Edelbrock will get back to me on this pulley. Doing a SC install during COVID sucks, they have a skeleton crew so everything is taking longer. But as for now the car will be garaged until I get a new pulley...
BR-ZED is offline   Reply With Quote
Old 07-22-2020, 10:41 PM   #3757
AKITA
AKITA's Avatar
24.9 psi @ 7388 rpm
25.4 psi @ 7204 rpm
24.7 psi @ 7348 rpm
25.1 psi @ 7356 rpm
I think there was just a little conversion/communication error since you say your logging reports direct psi.. so 14.7 - 5.6 = -9.1 vacuum which is very close to mine I idle.. I also idle at 900-950 not quite 1000 ... I'll repost that link but don't think I need to.. and look over the ones you posted.. but yeah that sounds better
29.50 idle
https://datazap.me/u/akita/scdata2?log=0&data=30
29.54 final WOT
https://datazap.me/u/akita/sc-6th-da...1&zoom=112-274
Old 07-22-2020, 11:53 PM   #3758
Silverfox
Silverfox's Avatar
No need for the dbox with current tuning techniques.
Could you elaborate on this statement? Currently shopping around for a tune or just going with an update to my current Delicious Tune and Dbox. I trust your guys' word considering I bought all my mods from you.
The Following User Says Thank You to Silverfox For This Useful Post:
AKITA (07-22-2020)
Old 07-23-2020, 12:08 AM   #3759
AKITA
AKITA's Avatar
Kind of curious myself now, as if you check my above logs.. in final WOT.. I've got a MAP voltage flutter between 6-7k.. and I got a brand new Dbox setup with DT tune.. you have to wonder what that would look like without.. would it? just gonna throw that out there and see what responses that gets. maybe it's nothing
Old 07-23-2020, 01:04 AM   #3760
The function of the dbox can effectively be performed by Ecutek with the current CSG Edelbrock tunes, thus eliminating the need for the dbox.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
AKITA (07-23-2020), Side (07-23-2020), Silverfox (07-23-2020)
Old 07-23-2020, 01:23 AM   #3761
Silverfox
Silverfox's Avatar
Thanks for the clarification!
Follow up question (and for anyone else who can answer as well): with delicious recommending SN Plus oils to prevent LSPI, what are you guys recommending for oil these days? (Previously I ran Motul 300V 5w30)
Cheers
Old 07-23-2020, 02:30 AM   #3762
Cheers
LSPI was never an issue before to begin with
AKITA (07-23-2020), Silverfox (07-23-2020)
Old 07-23-2020, 01:28 PM   #3763
ArrrBussiere
ArrrBussiere's Avatar
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
Cheers
I'm also in for oil recommendations for the supercharged engines - have some outstanding credit on a website and they sell the Motul oils for engine and diff and whatnot, might use up a chunk of that credit and get some
ArrrBussiere is offline   Reply With Quote
Old 07-23-2020, 02:19 PM   #3764
MaxTurbo
Drives: Scion FRS
Interesting, can you explain why some boosted 86's are very picky in low RPM + boost?... I'm going through remote log revisions due to low RPM, high gear IAM drop when I hit boost (pressure over ambient). Pretty much highway passing and such. I experienced it very badly with the Edelbrock ROM and the initial ROM's from Delicious. I thought it was a mechanical issue. After a few revisions we have almost eliminated it. In the process I have removed some of the mechanical variables: Replaced plugs, checked coils, cleaned/checked/new seals for the DI injectors and checked compression. The engine has 40K miles and aside from that IAM drop/knock at low RPM the car runs beautifully.
MaxTurbo is offline   Reply With Quote
Old 07-23-2020, 03:38 PM   #3765
apatel471
apatel471's Avatar
Drives: 2017 World Rally Blue BRZ
I'm looking to buy an Edelbrock kit but was wondering if any of the owners have done an e-tune with Openflash through an OFT? I know ECUTEK is better for this application, but I just don't know if I want to be locked in with ECUTEK especially with its relatively steep entry cost(Cable + License cost).
Btw I created a post asking the same thing in the software tuning section but I'm asking the same thing here just cause this is a little more specific and could probably get a faster response.
Thanks
apatel471 is offline   Reply With Quote
Old 07-23-2020, 04:39 PM   #3766
AKITA
AKITA's Avatar
Thanks
Nobody will likely recommend this with some limitations that exist with OFT in this application (tuners can't protect their intellectual property). You pay $500 plus you will pay OFT another $300 to write /make another applicable tune (this is if you can get them to respond, I've never heard from them about a request I made regarding a popular FI solution OFT is used for, never heard from them) and I don't think it will be anywhere near what you can get with Ecutek. So total for tuning (which outside of solid install and sound working machine) is very important, from Ecutek 1500-1800 compared to OFT at around 800 call it an extra 1000, while you have thousands invested in the hardware installing... most will tell you OFT is not a smart route unless you know enough to do it yourself. (not even sure it would be the smartest then, most economical maybe)
apatel471 (07-23-2020)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
