#3753 | |
Drives: '23 BRZ Limited
#3754 |
Drives: 2013 Subaru BRZ Limited (WRB)
#3755 |
#3757 |
I'm really just looking for answers on the Essex kit here from Mike.
![]() But here's the setup if you guys really want to analyze it. Not really getting fade technically, but I did melt/overheat the XP10 pads I used last year going down into turn 5 at RA (also using Pedal Dance). I stepped it up to XP12's this year all around. If that doesn't do it, I don't really want to juggle pads again (I realize pads like Endless and PMu99's will be better). I'll just step it up to the BBK like I should have done from the start. Bridgestone RE-71R Speigler Stainless Lines KNS Titanium Shims DBA T3 Rotors TF Brake Ducting Carbotech XP12 (Front/Rear) Motul RBF600 |
#3758 | |
Drives: 2015 BRZ
#3759 | |
Drives: Fr-s
#3760 |
#3761 |
#3762 |
Thanks
Shoulda bought the kit before you spent all that on replacement hardware but the answer to your questions is "get a BBK"
I ran stock with XP10 once I got "track rubber", not even serious rubber, RE11A. I saw a dramatic increase in pad wear. Bought the kit after that. If you are melting XP10 it is a no brainer. Not sure on the wheel fitment but there is a thread on AP sprint wheel fitment and you can print the template and check yourself. If not fit you can do extended studs and spacer or obviously buy new wheels. Thread: http://www.ft86club.com/forums/showthread.php?t=64282 Template: http://www.essexparts.com/storage/wy...l_template.pdf
#3763 | |
driving smoother faster
Drives: Sold
If you have the funds, if you enjoy pushing the car on track, if you want to stop thinking about brakes on track, just get it. Doubt you need ducts, I don't have them. I'm on JRSC/Ohlins/Slicks/AP Sprint/XP12/Torque RT700 - slicks chirp in braking zones but brakes don't fade. I use 12mm aluminum spacer to fit +45 enkei rpf1, just follow instructions above. Get them through CSG to help them help us
#3764 | |
Lower temps = lower wear, and it also helps with heat in the hubs/bearings as well. |
#3765 | ||
Thanks for the template info, forgot about that! I'll make one soon and pull the wheels to see if it'll fit. |
#3766 |
Thanks
If you end up having to buy new wheels take a look at the Endurance kit it has an adapter for brake ducts.
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
