Old 04-09-2016, 08:52 PM   #3697
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Originally Posted by Superstar View Post
Anyone have experience with running an aftermarket front grill (such as grillcraft) with an oil cooler? Could you share some temp data (with and w/out grill) if possible?
Literally makes no difference
ScionOfHorus is offline   Reply With Quote
Old 04-10-2016, 04:49 PM   #3698
dp1
driving smoother faster
Drives: Sold
I ran stock and grillcraft grills, didn't notice any difference. Look into CSG louvers to help manage temps under the hood, mine are getting installed next week.
dp1 is offline   Reply With Quote
Old 04-11-2016, 08:30 AM   #3699
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
On the street I'm currently running:
18x8.5 Rota Grid - Flat Black (5x100/e44/73) on 235/40ZR-18 MICHELIN PILOT SUPER SPORT XL (Fatty setup)
I'd like to pick up a track set of wheels/tires. The plan is to trailer and swap at the track while keeping my alignment and suspension setup the same, with the exception of tightening the dampeners (Tein Flex Z). Perhaps one day I'll update the suspension and convert this car to a dedicated tracker.
Quick note. I'm running a JRSC.
For now I'm looking at the
ENKEI RPF1
or
JR 949Racing 6UL (leaning towards this)
What width and backspacing do you recommend? I'm open to staggered sizing.
Any tires suggestions to research?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 04-11-2016, 08:52 AM   #3700
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
ENKEI RPF1
or
My choice for the same setup will be :
949 17x9
Yokohama a005 230/610/17
If you need stock gearing, you can use 625mm diameter.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 04-11-2016, 02:07 PM   #3701
ENKEI RPF1
or
What tire do you want to run? That'll determine the wheel.
Old 04-11-2016, 10:13 PM   #3702
Bramick
Bramick's Avatar
No idea. I was going to focus on the wheels then the tires. Apparently I'm approaching my research backwards
Old 04-11-2016, 10:42 PM   #3703
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
For a track-only set of wheels for a mildly experienced driver such as yourself, I'd consider Hoosier R7s. Keep in mind they generally run a little wider than some DOT tires, so a 245/45R17 would be a LOT of tire. I would recommend a square setup, staggered tires aren't necessary for these cars. There are many other setup changes you can make to adjust the balance before running a skinnier front tire, that's just leaving grip on the table.
GSpeed is offline   Reply With Quote
Old 04-12-2016, 09:34 AM   #3704
Bramick
Bramick's Avatar
949 Racing 17x9 will work for this?
Old 04-12-2016, 09:43 AM   #3705
MaximeT
MaximeT's Avatar
The spec says it works from 8 to 9.5in wheels (page 23) :
https://www.hoosiertire.com/pdfs/speccat.pdf
From the spec too, it's 261mm wide (10.3in). dunno if it fits. Looks like a lot of tire.
Old 04-12-2016, 09:51 AM   #3706
OkieSnuffBox
Drives: '23 BRZ Limited
Yes, is absolutely no reason to run on purple crack (Hoosiers) if you aren't doing TT. Too expensive and wear too fast.
On of the 200TW Extreme Performance summer tires, 245/40/17 on the 17x9 of your choice will be an excellent setup.
Old 04-12-2016, 10:01 AM   #3707
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
RE71r and Rival S not good enough anymore
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 04-12-2016, 03:03 PM   #3708
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
RE71Rs don't last near as long on track. Hoosiers are the most popular tire at Texas race tracks (observation, not statistics) for a reason.
You think Hoosiers are "purple crack," you should price out Michelin slicks.
Old 04-12-2016, 03:07 PM   #3709
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
I just went and measured our 245/40R17 RE71Rs on 17x9 RPF1s. They're almost exactly 10.3" at the bead, but they narrow at the tread. Hoosiers tend to have a little more square profile, so you may have issues with the fenders depending on offset (assuming you had no issues, or were close with 245/40R17 RE71Rs).
The 245/45R17 Hoosiers would be a tad bit taller, as well.
Old 04-12-2016, 11:56 PM   #3710
Bramick
Bramick's Avatar
The 949s in 17x9 are a +40 offset.
