Old 09-09-2016, 09:31 PM   #3683
Originally Posted by hamlet View Post
Haven't made appt because you stopped responding to my pm's Mike. I'm free Monday at noon and Tues at 10
I make it a habit to respond to every single PM and email I get. The forum does go down intermittently...
Old 09-14-2016, 06:01 PM   #3684
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Anyone know the current estimated response time for Rotrex warranty claim reviews?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 09-14-2016, 06:12 PM   #3685
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
You can also send PM to this account and we can kick Mike's donkey into shape.
CounterSpace Garage is offline   Reply With Quote
Old 09-14-2016, 07:21 PM   #3686
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
for those with front bumper issues, what replacement/ smaller windshield wiper reservoir are you using?
Jmonty is offline   Reply With Quote
Old 09-14-2016, 09:50 PM   #3687
Bramick
Bramick's Avatar
http://www.ptuning.com/subdir/itemde...&ModelDesc=FRS
The Following 3 Users Say Thank You to Bramick For This Useful Post:
Aaronimoe (09-19-2016), dp1 (09-15-2016), Jmonty (09-15-2016)
Old 09-19-2016, 03:34 PM   #3688
jainish007
Drives: 2014 Monogram Scion FRS Whiteout
I'm still having this issue. Can anyone relate?
jainish007 is offline   Reply With Quote
Old 09-19-2016, 04:42 PM   #3689
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Who is your tuner?
JDMChris is offline   Reply With Quote
Old 09-19-2016, 04:47 PM   #3690
jainish007
Originally Posted by JDMChris View Post
Who is your tuner?
Im working with CGS and delicious tune
Old 09-19-2016, 09:05 PM   #3691
dp1
driving smoother faster
Drives: Sold
Originally Posted by Bramick View Post
Just received mine, thanks for this
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Bramick (09-19-2016)
Old 09-19-2016, 09:17 PM   #3692
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
Do check the pipe clearance on the passenger side. There may be rubbing on a couple of places...one is against the headlight housing. The other against metal on the frame.
Not an issue with the FRS as the profile of the rear headlight allows for more clearance.
You may also find routing the washer reservoir hose a lil tricky to route but you should be able to orient the hose to there's zero contact with any component (save for the spots where it's mounted).
I had to use a nut, bolt, and lock nut to prevent the mouth of the washer reservoir from moving around.
You should get an inch...inch and a half clearance between the elbow of the intercooler piping and the surface of the bumper cover. Due to the bumper cover profile, the FRS doesn't have this clearance issue.
SHWNBRZ is offline   Reply With Quote
The Following User Says Thank You to SHWNBRZ For This Useful Post:
dp1 (09-19-2016)
Old 09-20-2016, 12:54 PM   #3693
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
UPDATE on my CEL: Had the air filter cleaned and re-oiled and then cleaned off the MAF sensor. Engine code seems to be cleared and car is actually noticeably more powerful.
Turns out maintenance is important.
hamlet is offline   Reply With Quote
The Following User Says Thank You to hamlet For This Useful Post:
CSG Mike (09-20-2016)
Old 09-20-2016, 08:06 PM   #3694
JDMChris
Drives: 2016
Have you sent Logs to Delicious?
Old 09-20-2016, 08:18 PM   #3695
jainish007
I havn't sent it to delicious yet...
Old 09-25-2016, 08:12 PM   #3696
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
Been battling my install since almost the beginning (August of last year). Continue to get the issue a lot of people have which is the CEL P0172. I've done everything I've found in this thread. Make sure the connection isn't too close to the alternator, clean the MAF, make sure the MAF is as vertical as possible. Checked all connections and everything is tight. I continue to get the CEL. Sometimes I'll get it within weeks, sometimes days. When everything is working it is such a joy to drive, but when it isn't working...
I just put in an order to CSG for a new air filter since mine is a little beat up(my kit is second hand) so I'm really hoping that will fix the issue. Otherwise I'm going to look into using the delicious tune with MAP sensor instead. Prefer to drive stock carb, but even more important is driving something reliable. I don't track and don't drive super hard all the time. I just want it working reliably. I'll report back one way or the other if the replacement filter works.
phanguy is offline   Reply With Quote
The Following User Says Thank You to phanguy For This Useful Post:
CSG Mike (09-27-2016)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
