Old 11-19-2019, 12:56 PM   #3683
toast
Drives: 14 BSP Edelbrock BRZ
I just installed a set of RCE SS1's and had my alignment done. I asked them not to touch the camber adjustment on the tophat and max out what the could using the crash bolt in the upper position as long as left and right were even. They were able to get almost -3 degrees. This is a bit more than I expected. That too much for a daily driver? Toe is at zero in the front.
If I wanted to reduce it could I use the tophat adjustment and push it out? How much is each hash mark?
Edit: Also, a shoutout to these coilovers. Even in the 'comfort' setting on the dampers the car feels brand new. Tons of grip and more comfort than stock shocks with RCE yellow springs.
toast is offline   Reply With Quote
The Following 2 Users Say Thank You to toast For This Useful Post:
bhmax (11-19-2019), Racecomp Engineering (11-19-2019)
Old 11-19-2019, 02:06 PM   #3684
Originally Posted by HaXx View Post
Hey CSG and RCE. I know many are on air when doing overfenders, but i want to go coils. Can you school me on what coils to get so i can get the right ones the first time? Tracking is not in the equation for me.
How low do you want to go?
- Andrew
Old 11-19-2019, 02:09 PM   #3685
Are your plates definitely in the 0 position?
I'm in another country at the moment, but send me a pic if you like. If your car is strictly a daily driver then -3 is more than necessary.
- Andrew
Old 11-19-2019, 02:36 PM   #3686
i8ur911
Drives: 17 BRZ Series.Yellow
Just a friendly reminder that adjusting your camber is also going to change your toe.
I run -3* on my BRZ with zero toe as well (don't consider it a daily, but is driven regularly). I've had very good tire wear. Using 245/40/17 Conti ECS for reference. Cold tire psi is 35.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 11-19-2019, 02:48 PM   #3687
HaXx
Drives: jrsc_brz
- Andrew
not sure, im imagining 1inch? as its going to be static, i do not wanting to slam it to the ground.
im not looking for fender to lip fit, im looking for rideability, so im leaning toward $1500 coils, not $500 used BC's
i do a trackday a year, but its purely for fun, im not looking to improve my driving, just having a blast at the track for a day.
HaXx is offline   Reply With Quote
Old 11-19-2019, 04:22 PM   #3688
toast
- Andrew
Yes. What would I send you a pic of, the tophat?
Old 11-19-2019, 04:23 PM   #3689
toast
Thanks. That's all I'm worried about, don't want to kill my tires. I know that toe is more responsible for wear but most people that say that talk about camber of -2 not -3.
Old 11-19-2019, 04:25 PM   #3690
i8ur911
If I could throw my $0.02 in here....
If you're looking for a slightly more performance oriented ride while still being very comfortable, I'd recommend KW's V2 coilovers. These will accomplish what you're looking for. They have rebound damping adjustability which will allow you to dial in your ride/feel.
If you want to go with a less expensive (not necessarily less quality), Tein's Flex Z or ISC's N1 (both with upgraded springs - not the standard springs) would also be a good fit and accomplish what you're looking for.
The Following User Says Thank You to i8ur911 For This Useful Post:
HaXx (11-19-2019)
Old 11-19-2019, 06:44 PM   #3691
Gotcha, and not slamming the car makes things easier. For $1500 you can grab a set of the RCE SS1 coilovers that we released last year. CSG Teins are also a popular choice in that price range.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
HaXx (11-19-2019)
Old 11-19-2019, 06:44 PM   #3692
Yup, just pop the hood. If you pm I can give you my email.
- Andrew
Old 11-19-2019, 06:46 PM   #3693
KW V2 aren't available for this car. RCE SS1 coilovers would be along the same lines and are built by KW for us.
- Andrew
i8ur911 (11-19-2019)
Old 11-23-2019, 06:02 PM   #3694
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Current Setup: Koni Struts, OEM 2013 Springs, Crash bolts set to -1.9*
New Setup: KW V3 with 6k7/k springs, Verus Camber Plates.
I Daily My Car about 12k miles a year, with 2-3 autocross events.
I love the way the car handles, but not a fan of the bounce i got when i added Eibach Springs, so i went to stock springs.
I'd like it to drop about 3/4" and still be comfortable enough for the street, increased handling is always a plus.
Should I stick with the Verus Top Hats, or goto a Group N tophat for less noise/more comfort? I have no plans of running anything more than -2*
-B
HeresMyMind is offline   Reply With Quote
Old 11-23-2019, 06:18 PM   #3695
norcalpb
norcalpb's Avatar
- Andrew
Which of these 2 setups do you think is the best for DD (25k miles/year) and 6 track days a year?
Old 11-24-2019, 05:07 AM   #3696
DeaconRoc
Drives: GT86
@Racecomp Engineering @CSG Mike @CSG David I'm looking to change my spring set up on my Motons as I have been running a more street friendly set up with occasional track but am now using the car more for track with occasional street. Currently I have a 200mm 4kg rear spring with no helper and a 150mm 5kg front spring with a 2kg 50mm helper. I'm looking at a 7kg 140mm front spring with a 40mm 3kg helper and on the rear a 170mm 8kg main spring with a 40mm helper. Can you see any problems I'm missing with this set up change?
Sent from my ONEPLUS A3003 using Tapatalk
DeaconRoc is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
