Old 02-27-2014, 06:09 PM   #3683
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Calum View Post
Results man, where are the results?
so i switched back to 93 and the issue is gone, so i'm thinking it's something with the port injector seals still, or maybe just a bad tank of corn juice. i tested it via test tube and it showed up at e80, but who knows how accurate that was.
I'm planning on hooking it up on Sunday, though.
The Following User Says Thank You to xjohnx For This Useful Post:
Calum (02-27-2014)
Old 02-27-2014, 06:28 PM   #3684
evan
Drives: fr-s
Originally Posted by NickFRS View Post
My last blower was was replaced at 500 miles. This one only has 600 miles on it. If it doesn't have oil i'll be quite shocked.
Prob date night with the wife. Might do C&C though.
Let's talk at C&C. Is it the Tigard one.. I think?
Eat your vegetables..
evan is offline   Reply With Quote
Old 02-27-2014, 06:35 PM   #3685
Calum
That Guy
Drives: 2013 asphalt FRS MT
That's interesting. It couldn't be oxygenated fuel could it? I don't know if they do that to corn oil.
Old 02-27-2014, 06:52 PM   #3686
xjohnx
Grip>Slip
xjohnx's Avatar
not sure. i've still got some fuel left over from that same batch in a 5 gallon can that i guess i could send out for testing somewhere (blackstone maybe?). probably not worth the hassle.
At this point i think i'm just going to fog test it this weekend to be sure there are no leaks. I'll also be connecting my wideband directly to my ECU via the rear o2 input. From there i plan on running at least one more tank of 93 through her before switching back to e85 again, just to make sure everything's working as intended.
Calum (02-27-2014)
Old 02-27-2014, 07:04 PM   #3687
NickFRS
Drives: 2013 Asphalt FRS
I think it is. Have to touch bases with Kohei n Josh soon.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 02-27-2014, 10:49 PM   #3688
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Good call. I was going to ask him to check the oil but didn't want to jump to conclusions before hearing it.
You found no oil in yours.. Hmmm. Did it not come with oil or do you think it's being lost? I'm not following the 30k mile recommendation and planning to change mine every 10k for insurance. The Redline stuff is relatively cheap.
After 3000km started to hear bad rattle sound.
Checked oil could not see anything on the dip stick, drained with syringe and shocked to find 20ml in the sc.
Sprintex say supplied with oil and the distributor advises they check before shipping to me. Me thinks nonsense. I highly recommend to check oil before installation.
I now change oil every month, overkill maybe but I have the bottle Redline and the SC takes 160 ml so why not.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
evan (02-28-2014)
Old 02-27-2014, 11:54 PM   #3689
olorin
olorin's Avatar
Drives: GBS Premium
How do I shim the pulley? My 70mm pulley (its a raceseng) sticks out about 1-2mm farther than my 75mm pulley that came with the SC. I shredded about a 3-4mm strip of the belt.
olorin is offline   Reply With Quote
Old 02-28-2014, 04:49 AM   #3690
Calum
That Guy
You can shim out but not in.
Sent from my samstone
Old 02-28-2014, 06:43 AM   #3691
Ryan86
Road Warrior
Ryan86's Avatar
Both my OEM and BG belts fit 100% on the raceseng pulleys. You may have a bad pulley??? Warranty exchange?
Old 02-28-2014, 08:46 AM   #3692
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Double check that there's nothing behind it as well. May not be seated correctly. They are exactly (like, within a few thousands) as the stock pulley.
Xero-Limit is offline   Reply With Quote
Old 02-28-2014, 12:27 PM   #3693
olorin
olorin's Avatar
Drives: GBS Premium
Definitely seated correctly. For comparison I seated it on some sockets that are the same length (and swapped for comparison):
The raceseng definitely seems to stick out a small amount more.
Old 02-28-2014, 01:29 PM   #3694
Ryan86
Road Warrior
Ryan86's Avatar
I got my 80mm Sprintex and 70mm Raceseng on hand so I did a like for like picture as you have done.
I think you have a bad Raceseng pulley there.
olorin (02-28-2014)
Old 02-28-2014, 02:29 PM   #3695
xxscaxx
Drives: 2013 SWP BRZ
Intercooled people out there - any of you having an issue with the heater hose coming off the top of the bosch water pump hitting the clip on the sensor that sits right above the water pump? Mine is pressed against it..wish they didn't just give you a zip tie to use on that damn bracket.
xxscaxx is offline   Reply With Quote
Old 02-28-2014, 02:57 PM   #3696
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
@xxscaxx I used a 3" worm clamp from the intake tube instead of the zip tie. Just need to loop it though the bracket and tighten, then flex the excess back and forth till it snaps off. Much more secure and then I replaced the intake tube worm clamps with t-bolt clamps.
Hope it resolves your issue
Lawnik is offline   Reply With Quote
The Following User Says Thank You to Lawnik For This Useful Post:
xxscaxx (02-28-2014)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
