Old 05-27-2015, 08:32 PM   #3683
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Come do autocross with me!
It's fun!
JohnJuan is offline   Reply With Quote
Old 05-27-2015, 09:14 PM   #3684
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Originally Posted by stokeless View Post
seem like every region or state has their own yearly meeting or road trip event... do we have something similar here?
Working on a run thru the Wisconsin country side, but it will be close to an all day drive. Looking at early July, but not the 4th.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 05-27-2015, 10:08 PM   #3685
stokeless
stokeless's Avatar
Drives: 2020 BRZ PP Silver
Originally Posted by JohnJuan View Post
not sure if I can make the 7th but what are the requirement. I really want to try HPDE but my car will not be ready until next year.
stokeless is offline   Reply With Quote
Old 05-27-2015, 10:09 PM   #3686
stokeless
stokeless's Avatar
we should get a few more people and do this... sounds like fun.
Old 05-27-2015, 11:06 PM   #3687
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Thinking five, besides myself. Wish I had a video camera in order to share the great spots. Borrowing from the movie "Need for Speed", I'm thinking we call this run the "Wisconscion". Takes a while, but many tight turns.
Old 05-27-2015, 11:35 PM   #3688
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
I'd be interested in attending in whatever I wind up buying. If non 86 is welcome.
KevinK121 is offline   Reply With Quote
Old 05-28-2015, 12:36 AM   #3689
JohnJuan
JohnJuan's Avatar
Here's a Novice Guide:
http://www.mnautox.com/forums/conten...ovice-Handbook
and a flash slideshow: http://www.mnautox.com/forums/conten...w-Autocrossers
My car has a couple comfort and simple power mods, and I have the stock tires. Nothing serious is necessary to drive. There are two BRZ drivers who attend regularly and have better tires than me and set competitive times. I've posted my videos earlier in this thread.
Old 05-28-2015, 06:09 PM   #3690
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
@JohnJuan - should be able to get out there and watch some more runs. Still debating about driving this year or next.
@stokeless - Nonsense, my car is bone stock and I take her to BIR for the HPDS after Proving Grounds. They came ready for fun driving, but if competition is what your after. Yep, you'll be building yours up.
Old 05-28-2015, 11:10 PM   #3691
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I might do one or two autocrosses this summer just for kicks. On June 7th I will be at BIR instructing for the BMW club. Unfortunately, I cannot afford to properly prep my car to run this year at BIR so I will only be instructing, and perhaps driving other people's cars. I would be able to do an autocross or two, however, so maybe I'll see you out there this summer.
Old 05-28-2015, 11:26 PM   #3692
stokeless
stokeless's Avatar
What are the requirements to run at bir? I thought about running at bir. I thought the car needed to be track ready
Old 05-29-2015, 01:14 AM   #3693
Black Tire
Black Tire's Avatar
"Track ready" depends on your experience, how fast you drive and somewhat on the organization that is sponsoring the event. At a minimum, you really should invest in a set of track focused brake pads. Other than that you could run the car stock with 0W30 oil, fresh DOT 4 brake fluid and a complete brake flush and bleed. Make sure you have enough tread on your tires as well. Fresh transmission and differential fluid would be a good idea, as would torquing all of the suspension bolts to spec. If you are new to track driving, this is really all you need to do for this car if it is in good working order. Most clubs will also require a helmet, currently this is probably an M2005, M2010, SA2005 or SA2010, but it can vary with each club.
It's the brake pads and rotors that would break my budget this time. For me on the stock sized rotors, I would probably mostly use them up on a 3-day school, as well as a set of front track pads. Also, my rear shocks are completely shot, and my fronts are not great. This would make driving on a high speed track like this entertaining, but wobbly and perhaps a bit silly. When I ran the car 2 years ago, it had huge understeer into the corners. This was mostly due to the fact that I was driving faster into corners than the suspension was able to handle. I want to upgrade instead of driving slower into the corners on a stock suspension. This car does not do so well riding the bump stops into the corners; I really need higher spring rates. Also, in turn 2 at high speeds there was quite a bit of lift on the front end forcing me to slow down. While lowering the car a bit with a new suspension would probably help, I would really prefer to have a splitter to hold the front of the car down at high speeds, and while I'm at it, a diffuser in the rear as well.
Old 05-29-2015, 09:58 AM   #3694
stokeless
stokeless's Avatar
that's is my current issue... to get my car just to meet the min requirement, I would need to speed around 500.00 or so to get it done. I am new to all this and do not even have a helmet. I hope to be ready next year.
Old 05-29-2015, 10:42 AM   #3695
KevinK121
Miata traitor
KevinK121's Avatar
BIR/PG is very lax. I think they are requiring specific brake fluid this year. If I had more free computer time I'd go search the req's on the event page for ya but all the info is there.
Otherwise your car should be fine to enter if everything is in mechanical check
Old 05-29-2015, 04:38 PM   #3696
KevinK121
Miata traitor
KevinK121's Avatar
http://www.ft86club.com/forums/showthread.php?t=89118
Check in, eh? NorthFool CANADA 24 02-23-2012 07:32 AM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 05:56 PM
how do you check a site 4agze Off-Topic Lounge [WARNING: NO POLITICS] 3 11-21-2009 09:27 PM
Video of FT-86 @ TMS from Edmunds. Check out how small the car is next to people. JDMinc FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 10-25-2009 08:53 PM
