Old 08-05-2019, 10:29 AM   #3655
Racecomp Engineering
Originally Posted by rustymuffler View Post
Hi @Racecomp Engineering
I have Koni sports with OEM 2017 springs on my '13 BRZ. It has removed the harshness of the stock setup. Now I am looking for a modest ~1" drop while also reducing roll for spirited driving. Would the Racecomp Yellow, or Tarmac springs be a good fit with the Koni dampers without making the ride as harsh as the stock '13 setup?
RCE Yellow are a great fit for the Konis. They will be back in stock soooooon.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
rustymuffler (08-05-2019)
Old 08-05-2019, 05:51 PM   #3656
rustymuffler
- Andrew
Thanks Andrew, that means they will be listed on the Racecomp Engineering site once they’re in stock again?
rustymuffler is offline   Reply With Quote
Old 08-05-2019, 08:24 PM   #3657
Yup! If you want, PM me and I can have someone send you a message when they're in. No deposit or anything needed.
- Andrew
rustymuffler (08-06-2019)
Old 08-06-2019, 03:01 AM   #3658
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Hey guys, just wondering if I'm going to need a camber kit for a 1 inch drop on lowering springs? I'm I going to be way out of spec?
Drifter X is offline   Reply With Quote
Old 08-06-2019, 09:52 AM   #3659
Vital
Drives: 2015 BRZ
There is no way to really answer that. It all depends on how OCD you are about your alignment. On a 1" drop the fronts isnt gonna be affected much, but the rears will gain some natural camber from lowering. Some people have gotten away without camber kits and some people needed them. For example after lowering you could get -1.6 and -2.0 in the rear if that bothers you and you want it to be even you will need rear control arms.
Vital is offline   Reply With Quote
Old 08-06-2019, 05:33 PM   #3660
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
It actually depends on how you define "spec" and what you're going for.
From an email discussion with CSG,
"At a 1 inch drop with [coilovers], you'll have a natural rear camber of approxmately -2.1 degrees; this is totally acceptable and will not need rear lower control arms."
Whereas the extra negative camber in the front is only going to be useful, unless for some weird reason you want zero front camber (which is the manufacturer's spec btw).
See also https://www.ft86motorsports.com/wheelitfit/ for some estimates on how much natural camber you'll get with different amounts of drop.
timurrrr is offline   Reply With Quote
Old 08-06-2019, 05:38 PM   #3661
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Lowering does not add camber in the front, because we have a Mac Strut design.
I LIKE TIRES!
Old 08-06-2019, 05:40 PM   #3662
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
CSG:
What's the best place to reference for torque specs on bolts/parts that are 2017+ only?
e.g. Performance Package Brembo brakes, red intake manifold, etc.
Old 08-06-2019, 05:43 PM   #3663
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Equal length double wishbone suspension doesn't change camber on suspension travel, but MacPherson strut does.
I do however agree that the front camber changes due to lowering the car will be minimal. -0.3º for a 1" drop, according to that calculator.
Old 08-06-2019, 06:08 PM   #3664
CSG:
A service manual.
Most specs do not change.
Old 08-06-2019, 06:22 PM   #3665
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
A service manual.
You mean the 2013 one?
How do I know if a spec did change (e.g. brackets for Brembos) and to what value?
Old 08-12-2019, 04:25 AM   #3666
blown
Drives: ft86
does whiteline w63414 fit on the spc 67655
blown is offline   Reply With Quote
Old 08-29-2019, 09:28 AM   #3667
Chickeneatman
Drives: 2013 FR-S Ultramarine
Sorry if this has been asked already...
How do you set height on the RCE Tarmac 2? To me it looks like height is set by spring preload. Is there a way to set the ride height independent of preload?
Thanks!
Chickeneatman is offline   Reply With Quote
Old 08-29-2019, 11:20 AM   #3668
Thanks!
Like most higher-end european style coilovers, you're only preloading the helper spring for the most part. Our coilovers have a long stroke, so there's a lot of travel to work with. Unless you're completely slammed (2 inches ore lower) you end up with more bump AND more droop travel than most dual height adjustable coilovers. Droop travel is important, and there's a severe lack of it on a lot of those coilovers.
For reference, our T2s have more than 1.5 inches more total front stroke than a BC ER coilover. That's huge.
- Andrew
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
