Sam Strano
Old 08-20-2015, 02:02 PM   #3655
veloscaraptor
Drives: '15 fr-s
Harnesses are open, just don't cut the seat or remove the original belts
p.73 solo rules: 13.2.H
Driver restraints as outlined in Section 3.3.1 are allowed. Seats may not be cut to allow for the installation of alternate seat belts or harnesses. Passive restraint systems may disabled but may not be removed. Removeable seat headrests may be repositioned using the original mounting hardware only if the OE components permit it with no modifications. This includes removing a headrest and reinstalling it backwards. A horizontal “harness bar” may be used as part of the installation hardware for allowed driver restraints provided it has no more than 2 attachment points to the chassis and is bolted at those locations. A C-type harness bar may also be used. It may have 4
veloscaraptor is offline   Reply With Quote
The Following User Says Thank You to veloscaraptor For This Useful Post:
TMF (08-20-2015)
Old 08-20-2015, 02:53 PM   #3656
TMF
TMF's Avatar
Drives: '14 FRS TT5
Thanks, that's what I thought, just wanted to triple check to make sure I didn't miss some odd scenario.
TMF is offline   Reply With Quote
Old 08-20-2015, 02:57 PM   #3657
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
Originally Posted by TMF View Post
Quick question...no issue with running a harness (like the Schroth Rallye 3) in Street class, correct? Is anyone running a harness? I've had harnesses in my last two cars and I kind of miss it.
I am running one of these in my FR-S (autox only).
https://www.schrothracing.com/tuning...e/rallye-cross
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
The Following User Says Thank You to YawMomentRacing For This Useful Post:
TMF (08-20-2015)
Old 08-20-2015, 03:34 PM   #3658
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
What mounting points are you using? Just curious.
VADERR is offline   Reply With Quote
Old 08-20-2015, 04:07 PM   #3659
YawMomentRacing
I bolted the shoulder straps to the driver-side lower rear seat belt attachments (in an X). The shoulder straps come through the factory head rest. I bolted the lap belts in the factory seat belt attachment points for the driver seat. It's been a while since I installed the belt but I followed the safety recommendations from the Schroth install manual (angle of belts, where to attach, etc.). The factory seat belts are all in place and when I street drive (daily driver) the shoulder belts lay out of the way in the rear seat.
The right-side (from driver's position) lap belt attachment is bit tough to get to - hard to fit your hand between the seat and the center tunnel. For the rear, you need to remove the seat cushion and the driver-side b-pillar paneling like in the picture below.
IMG_20150517_162427679 by Dave, on Flickr
Some of these links helped:
http://www.ft86club.com/forums/showthread.php?t=54181
http://www.ft86club.com/forums/showthread.php?t=87215
YouTube Channel
VADERR (08-20-2015)
Old 08-20-2015, 04:43 PM   #3660
TMF
TMF's Avatar
Drives: '14 FRS TT5
Here's another good thread for the Rallye 3 version: http://www.ft86club.com/forums/showthread.php?t=15051
The Following User Says Thank You to TMF For This Useful Post:
VADERR (08-20-2015)
Old 08-20-2015, 07:25 PM   #3661
YawMomentRacing
Photo should actually work now.
YouTube Channel
VADERR (08-21-2015)
Old 08-20-2015, 11:02 PM   #3662
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
**Big Picture you don't need to see again***
How strange is that speaker mount? It's just like hanging in there.
DylanFRS is offline   Reply With Quote
Old 08-20-2015, 11:16 PM   #3663
solort
Drives: Series 10 FRS
Originally Posted by renfield90 View Post
If that's working for you guys, great. But when we dyno'd my Konis we started at full soft, and after seeing the graph at halfway to full stiff we said "yep, we've seen enough here" and took it off the dyno. I've ran them in that range ever since.
Ae your Koni yellows OTS or degassed custom valved?
solort is offline   Reply With Quote
Old 08-21-2015, 10:53 PM   #3664
VADERR
Completely Lost
VADERR's Avatar
Well.... There are 2 2016 miatas registered for CS this weekend in Texas. This will be the ultimate test assuming they're on good tires! Gunna be fun.
The Following User Says Thank You to VADERR For This Useful Post:
Rampage (08-21-2015)
Old 08-21-2015, 11:38 PM   #3665
markw
Drives: 2014 FR-S
Currently the ND is classed in Super Street (SS). Page 161 of the rule book.
All unclassified cars will compete in Super Street (SS) until classified by the SEB, unless covered by a "Catch-all Description."
markw is offline   Reply With Quote
Old 08-22-2015, 10:12 AM   #3666
VADERR
Completely Lost
VADERR's Avatar
Yeah true but I am not going to protest at a regional. Plus I want to see how they do lol since the SEB will probably class them CS after nats.
Old 08-22-2015, 01:45 PM   #3667
renfield90
The Stig's German cousin
They're OTS.
Old 08-25-2015, 03:15 PM   #3668
TMF
TMF's Avatar
Drives: '14 FRS TT5
So...any more thoughts on 235's vs 225's for nats? I'm still debating going staggered...or perhaps I just need to stop worrying and show up and drive
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
