Old 09-28-2015, 04:07 PM   #351
G-awesome
Drives: 2015 Firestorm Scion FRS
WILL BUY! payday can't come soon enough!
G-awesome is offline
Old 09-29-2015, 08:48 PM   #352
HATED1
HATED1's Avatar
Drives: 86
@FT-86 SpeedFactory just wondering when these will be shipping out? It says "shipfactory" I'm just excited to get it put on #400001828 Thanks for any info!
86 SESSIONS on Facebook!
HATED1 is offline
Old 09-30-2015, 03:26 AM   #353
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Originally Posted by HATED1 View Post
@FT-86 SpeedFactory just wondering when these will be shipping out? It says "shipfactory" I'm just excited to get it put on Thanks for any info!
Mine arrives this Friday
|| My Build Thread ||
ck-GT86 is offline
Old 09-30-2015, 01:46 PM   #354
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
The non-aggressive units are in stock. The aggressive units are out of stock currently. There website confirms this as well. Hope this helps some.
VerusEric is offline
Old 09-30-2015, 02:14 PM   #355
HATED1
HATED1's Avatar
Drives: 86
Thank you, Jeremy at FT-86 SpeedFactory contacted me today and let me know my status on my order!
HATED1 is offline
Old 09-30-2015, 02:39 PM   #356
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Originally Posted by jdnguyen View Post
Hopefully I'll have some time today to bust out the cutting wheel or plasma cutter to modify the rear diffuser to get the tomei type 80 to fit. Looks like a section towards the front of the car will need to be removed on the diffuser. Hopefully that's it.
Stay tuned...
If possible, pictures of the area you are planning to cut for the type-80
Bach415 is offline
Old 10-01-2015, 03:39 PM   #357
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Okay installed pics of each unit on the same car in the same setting so you can compare. Picture overload time.
Non Aggressive
Aggressive
FT-86 SpeedFactory is offline
Old 10-04-2015, 02:28 PM   #358
FT-86 SpeedFactory
Video time
[ame="https://www.youtube.com/watch?v=54ynNLxkp-s"]FT86SpeedFactory - Rear Diffuser Install - YouTube[/ame]
Old 10-04-2015, 05:04 PM   #359
VerusEric
VerusEric's Avatar
Well, we have some exciting news. We have some real life data showing that these along with our front splitter work on a race track.
G-speed shared their log data from their track car build with us and we were able to discern some changes from before and after the aero pieces. We can't thank PST enough for this opportunity and data.
The person who did this data analysis, Ryan, moonlights for Velox Motorsports and is a good friend of mine. For his day job, he is a suspension engineer for one of the biggest racing names in the world and currently works on their IndyCar team. The conclusions we came results from comparing the session 1 and session 2 fastest laps.
As Paul and I expected, we were not able to see a change in ride height data. We estimate 160 pounds of downforce at 100 MPH with our kit through our CFD analysis. This load however, is spread out on all 4 wheels, which ultimately is not that high of a load on each corner. Ryan did say he would likely not be able to see this downforce change on an IndyCar either.
What we are able to discern from the data is that the driver used less brake pressure and had higher entry speeds into the corners. Both of these signify an increase in driver confidence. This coupled with a 0.5 second decrease in lap time points to a reduction in lift from the aero components.
Thanks,
Eric
Old 10-04-2015, 10:11 PM   #360
ck-GT86
ck-GT86's Avatar
For reference, I installed the Tame version underneath my Perrin 3" without using any of the supplied (black) extensions. Anyone else?
|| My Build Thread ||
ck-GT86 is offline
Old 10-04-2015, 10:18 PM   #361
ck-GT86
ck-GT86's Avatar
FT-86 SpeedFactory Diffuser by Velox - Complete Aero Solution
Also, this diffuser could use some matching rear spats, I have the Bayson-R spats and they don't flow that well @NotEric6
|| My Build Thread ||
ck-GT86 is offline
Old 10-05-2015, 03:08 AM   #362
HATED1
HATED1's Avatar
Drives: 86
Can you post pics? I have the same exhaust and am wondering how close it will sit to the exhaust, I get mine on Tuesday
Any pics with the spats on?
Thanks!
HATED1 is offline
Old 10-05-2015, 11:58 AM   #363
Thanks,
Eric
A G-force plot would reveal if the diffuser actually added more cornering capability (grip). Even the most basic dataloggers all have one; is that something you guys are willing to post?
Your data and conclusion is anecdotal at best; a G-force plot is the best way to show an increase in cornering grip.
CSG Mike is offline
Old 10-05-2015, 12:04 PM   #364
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
No, it wouldn't. The amount of grip you gain from an additional (theoretical) 160lb unevenly distributed across the wheels would disappear in the noise. There's too much variability in temperature, line adjustment due to traffic, inconsistency, etc.
The effects of minor street car aero aren't as easy to detect with dataq as you might be led to believe. Even a mph vs. ride height plot doesn't show any perceptible change, due to the noise inherent to the system.
GSpeed is offline
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
Single-Exit Exhaust Diffuser/Hole Problem... Solution! Anthony Cosmetic Modification (Interior/Exterior/Lighting) 75 10-13-2016 07:40 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
DriveWay Labs Rear Diffuser - FT-86 SpeedFactory FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 435 01-15-2015 07:20 AM
