Old 05-08-2015, 02:09 PM   #351
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
So the Kumho V720s are finally available. The brand new Viper ACR was just released today and while its competitors are all rocking the Michelin Pilot Sport Cup 2s or the Pirelli P-Zero Corsas, it is coming with a set of specially designed ACR Kumho V720s. They seem to think this tire is pretty damn quick. I look forward to reading some reviews on these as I was a big fan of the Kumho XS and used them throughout my time doing HPDEs.
Old 05-08-2015, 03:35 PM   #352
scirocco78
Drives: Scion FRS
If I were ready to buy some Bridgestones right now, what size whould I get for my CS FRS?
scirocco78 is offline   Reply With Quote
Old 05-08-2015, 04:07 PM   #353
xwd
Originally Posted by renfield90 View Post
Greg Reno? Is he a contract driver for Kumho? He had them way early...
Yes he had an early set from Kuhmo. I don't think he's a "contract" driver because Kuhmo hasn't had a competitive autocross tire in many years. His results were not all that great but I don't think he got as many runs as he wanted.
I think the 720 will be a good cheap performance tire, it seemed to be on par with the Z2* and RS3, but I don't think it will be at the level of the RE-71 or Rival-S.
Old 05-08-2015, 04:10 PM   #354
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Should
Kostamojen is offline   Reply With Quote
Old 05-08-2015, 04:16 PM   #355
scirocco78
Drives: Scion FRS
An Engrish lesson wont' help me go faster.
Old 05-08-2015, 04:22 PM   #356
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Dats what the RE-71Rs are for.
Old 05-08-2015, 04:33 PM   #357
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Man you autocrossers are serious biznezz.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-08-2015, 04:36 PM   #358
Jawnathin
Drives: Toyobaru FRZ
Since no one else elected to be helpful, maybe I can be.
Stock wheel offsets = 225/45/17
+42 offsets (like RPF1s) = 245/40/17 or 235/45/17 (width vs taller gear, you pick)
I run 245/40s on my +42 RPF1s. I really want a 235/40, but they don't make it.
235/45/17 might fit on the stock wheel offset, but I'm not 100% sure if clear the spring or perches without any rubbing.
Jawnathin is offline   Reply With Quote
Old 05-08-2015, 04:59 PM   #359
rx3
Originally Posted by 7thgear
Last year i ran on R1Rs and won two sets via contingency, so I'm sitting on quite a bit of rubber...and will probably continue to run the R1R this year (still competitive enough to get another set, or maybe a 2nds place coupon towards toyo tires)
For those than ran the R1Rs in the past, how do you feel they measure up to the new Bridgestones?
FWIW, Here's one guy saying that the Yoko A048 was significantly faster than the Bridgestone: http://www.tirerack.com/tires/tires....onsumerReviews
I've been mostly running on Toyo R888 and so far none of the competitors on Yoko A048 have been faster (granted there weren't that many, since they are somewhat pricey).
I've been running on R1R too and they weren't significantly slower than the R888. So, my conclusion would be that the Bridgestone RE71 are slower than the R888 and probably not faster than the R1R.
rx3 is offline   Reply With Quote
Old 05-08-2015, 05:15 PM   #360
vroom4
I'll be benchmarking the r1r vs the stones here in a month or so. Probably in a damp environment.
vroom4 is offline   Reply With Quote
Old 05-08-2015, 05:29 PM   #361
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
That was in tracking in a corvette. In that same review he says they are great autocross tires.
Pretty much he says (its better to use an R comp for track then using the re71r)
-Jack Burton
Old 05-08-2015, 05:32 PM   #362
tahdizzle
So elite I'm 1338
What sizes are you testing?
-Jack Burton
Old 05-08-2015, 06:22 PM   #363
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
There is a comparison by Andy Hollis in the GRM June edition. There is also a Podcast where they talk about the testing.
http://classicmotorsports.com/media/...t_tiretest.mp3
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 05-08-2015, 06:26 PM   #364
scirocco78
Drives: Scion FRS
Thanks!
I'm running Kosei's with 5mm spacers and 235/45 dunlops right now. The gearing bump has been worth it at my local venue.
My only concern when playing with the numbers from the Tirerack site is the tread width difference between the stones and the Dunlops. One full inch narrower on the stones? Tirerack says they measure the tread width them selves too.
Areddi's Autocross Video Thread Areddi Mid-Atlantic 130 05-17-2015 06:19 PM
Anyone DD 200 Treadwear Tires? CraftyObeseCrunchyKitty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-09-2015 11:44 AM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
Autocross Tire Pressure on ZII's Areddi Tracking / Autocross / HPDE / Drifting 6 04-12-2013 08:37 PM
KW V3 autocross set-up thread -max- Tracking / Autocross / HPDE / Drifting 97 10-18-2012 08:02 PM
