01-24-2020, 09:37 AM | #351 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
I may have to ask them. Im more or less hoping I could compare/measure up to the stock dimensions and just install them exactly as the stock ones measure up. Not messing with my current alignment settings which are just fine. |
01-27-2020, 11:02 AM | #352 |
Drives: 2016 White Pearl BRZ Premium
The Following User Says Thank You to Joesurf79 For This Useful Post: | Takumi788 (01-27-2020) |
02-06-2020, 04:21 PM | #353 |
Door Hinges .75lbs each
Wish I could find someone to make them out of aluminum for me since I have CF Doors I did drill a big hole out of one of them. Only lost .2oz left the rest of them alone |
02-10-2020, 03:15 PM | #354 |
Drives: 13 White MT FR-S
Just cut 3.5 lbs out of the dash support brace and 7lbs with taking the wipers out.
02-11-2020, 11:46 AM | #355 |
Shaving pounds
Gutted lights and fogged the inside of the lenses black, gutted the e-brake shoes, brackets, cables, etc. Ditched the hood latch stuff. Trimming down the splitter frame some for a lighter strategy. Pulled the calipers for a rebuild.
Up next - trim dash, new airdam and a fresh splitter. Then build a ballast box so I can add just enough weight back, but where I want it to be |
02-11-2020, 12:27 PM | #356 | |
Any pics of your dash brace? I attempted this last year and ended up taking too much off the "pole" that runs across, making it too easy to bend. Im guessing leave the pole alone and take some of the steel around the steering column attachment area? |
02-11-2020, 12:29 PM | #357 | |
Wish I could delete my ebrake, But I park on a steep hill. I guess I could keep a wheel chock with me |
02-11-2020, 12:31 PM | #358 | |
Borrowed some scales from a friend. will weight it tonight and get a feelz for how much ballast I'll need to run TT5. Then weld up a ballast box accordingly |
The Following User Says Thank You to Joesurf79 For This Useful Post: | why? (02-13-2020) |
02-11-2020, 12:37 PM | #359 |
Posted this in my build thread but Ill add it here since its about weight.
Swiss cheesed all the steel up front (not connect to suspension) -Fender rails, Headlight buckets, Radiator/Hood T Only got out a 1lb though after a lot of drilling. Before After Also took off the 2 black covers for the airbag sensors and just mounted the sensor. My airbags are gone so eventually I will take out the wiring. Removed bracket for outside temp sensor and pushed it into radiator slot And went down to one horn that saved 1.25lb |
The Following User Says Thank You to SuperTom For This Useful Post: | why? (02-13-2020) |
02-11-2020, 12:44 PM | #360 |
Country Boy 4 Life
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | SuperTom (02-11-2020) |
02-11-2020, 03:17 PM | #361 | |
The Following 2 Users Say Thank You to ML For This Useful Post: | new2subaru (02-16-2020), SuperTom (02-11-2020) |
02-12-2020, 10:58 PM | #362 |
replaced the third brake light with a led strip. probably good for a pound or so haha
02-18-2020, 04:52 PM | #363 |
1 lb
The Following User Says Thank You to ML For This Useful Post: | SuperTom (02-19-2020) |
02-18-2020, 05:11 PM | #364 |
Drives: '15 BRZ RA
Are you guys sure that you don't sacrifice on chassis rigidity with all this drilling?
Tags |
diet, heavy, light, reduction, weight |
Similar Threads | ||||
So what is the official weight? | brillo | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 05-03-2020 05:11 PM |
Official Weight Reduction Thread - Sort of... | merlin2111 | Off-Topic Lounge [WARNING: NO POLITICS] | 77 | 10-07-2012 05:09 PM |
2012 Geneva - Toyota GT86 in Black, Blue, White, Orange. Official weight & 0-60 Shown | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 124 | 05-28-2012 12:20 PM |
Official JDM BRZ weight and MPG | ayau | BRZ First-Gen (2012+) -- General Topics | 50 | 02-08-2012 02:04 AM |
Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
