Old 06-03-2013, 06:31 PM   #351
DJCarbine
Thupercharged
DJCarbine's Avatar
I hope if this issue comes up with my car, they will not try to blame the supercharger on it.
2013 FRS
Vortech V3 11psi
Old 06-03-2013, 06:34 PM   #352
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Also, another piece of the puzzle that I remembered last night at work. When I dyno'd my car completely stock, (btw it put down 172 whp, 143 wtq on 94, on a dynojet) the operator noticed that A/F went super rich in the last 500 rpms down to 10:1! He said this is very unheard of even in his built supercharged or turbo'd mustangs. So to me this maybe suggest that toyabaru knew about this and simply tried to hide the detonation by giving more fuel. If anyone else can chime in on this.
Gords_zenith is offline   Reply With Quote
Old 06-03-2013, 06:36 PM   #353
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
just my opinion, but it seems like a fluke; they could fix the detonation if they knew about it just as easily as they could add fuel to the upper RPM range.
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
civdaddy (06-03-2013)
Old 06-03-2013, 06:42 PM   #354
Gords_zenith
Maybe but I got my car in July 2012, with no ecu updates. Also the A/F ratio was completely repeatable in the 4 runs I did.
Old 06-03-2013, 07:06 PM   #355
Along with a complete nosedive in torque/hp over 7k rpm. Our dynos when we baselined the car showed the same.
Old 06-03-2013, 07:34 PM   #356
Mikem53
Drives: FR-S 6MT
I thought most cars run rich at WOT and high rpms to avoid detonation?
The OEM is trying to keep EGTs lower by running rich to protect the engine and warranty..
Which is also why you get that drop off in power near the rpm limit. Most tuners lean it out for more power at the risk of detonation.. That's how it worked on my other cars.. I know 10:1 is a bit extreme.. But it should cool things down and keep detonation at bay.. Did you notice any detonation on ur dyno runs?
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Fast_Freddy (06-04-2013)
Old 06-03-2013, 07:48 PM   #357
Carwhisperer
Drives: A lot of supercars.
So we're not the only one to have this happen twice...
Injectors going out yes. Somehow the same motor is still running. My car has only seen streets though, just DD to and fro work.
Carwhisperer is offline   Reply With Quote
Old 06-03-2013, 07:50 PM   #358
xjohnx
Grip>Slip
xjohnx's Avatar
Mike's first motor was still running too, subaru yanked it for research.
Old 06-03-2013, 07:50 PM   #359
Carwhisperer
Same month I got mine. Interesting.
Old 06-03-2013, 08:00 PM   #360
Ours is also a July car (June production). Although, our 2nd motor obviously isn't from the same time....
Old 06-03-2013, 08:03 PM   #361
Gords_zenith
Agreed. But the point I was trying to make that it seems to be an extreme example of running rich in the last few hundred or so RPMs, and that the developers new about the detonation casued by improper transient ignition table values, so they tried to eliminate it by adding more gas than necessary. Only speculation based on some knowledge of how these engines seem to be designed, based from reading on these forums and my own auto back ground.
Last edited by Gords_zenith; 06-03-2013 at 08:06 PM. Reason: Edit: or they simply thought it wouldn't be a problem.
Old 06-03-2013, 08:05 PM   #362
Carwhisperer
Coincidence? At this point I Just want my DD back, the security guards at my work don't like it when my R8 enters the parking garage.. I tend to use more throttle than necessary.
The Following 4 Users Say Thank You to Carwhisperer For This Useful Post:
CSG Mike (06-03-2013), DAMotorsports (06-19-2013), HunterGreene (06-04-2013), SkullWorks (06-04-2013)
Old 06-03-2013, 08:09 PM   #363
Mikem53
Drives: FR-S 6MT
Ah... Ok.. Thanks for clarifying..
Old 06-03-2013, 08:10 PM   #364
Gords_zenith
Haha at least you have a decent back up ride.
But I've been running 94 pretty much as soon as I got it as the 91 was proving to be knock prone and caused the ecu to pull timing in the heat of summer last year. Btw I haven't tracked my car but have drove it hard on the back roads plenty of times.
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 09:55 PM
Denied service... Chen Northwest 37 09-13-2013 09:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 12:17 PM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 09:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-08-2012 12:57 AM
