02-24-2023, 04:48 AM | #351 |
waiting on yellow gas
Drives: 2017 BRZ Series.Yellow #247
FWIW I just got confirmation from Enkei that the TS-10 uses the same spoke profile for the 17x8 +45 and 17x9 +45 so it looks like the 17x9 should fit. Unfortunately I was asking about the TS-5.
Update: Enkei finally confirmed that the spoke profile for the TS-5 17x9 +45 is the same as the 17x8 +45 so they should clear the brembos as well
"Straight roads are for fast cars, turns are for fast drivers" - Colin McRae
04-02-2023, 11:28 PM | #352 |
Drives: 2017 Brz
Thank you for this thread. Gave me confidence in my purchase. Installed my new Konig Ampliform 17x9’s today. Fit with lots of space.
Sent from my iPad using Tapatalk |
04-03-2023, 10:44 AM | #353 |
Drives: 2020 BRZ Sport Tech RS
Looks good! What size tire are you running on your new wheels?
04-04-2023, 10:43 PM | #354 |
Drives: 2017 Brz
Pilot sport 4s in 245/45zr17.
I hadn’t had anything other than the stock primacy’s so this is a world of difference. Sent from my iPad using Tapatalk |
The Following User Says Thank You to Drafter For This Useful Post: | Tatsu333 (04-05-2023) |
05-21-2023, 08:08 PM | #355 |
Drives: 2019 BRZ Series.Gray
I just wanted to add some more info for 17x8.0 +45 Enkei RPF1s. I recently upgraded from a 2013 FR-S to a 2019 Performance Pack BRZ. I tried fitting my RPF1's to the BRZ and wheel weight clearance is an issue. The caliper to spokes clearance is fine and the tire to strut clearance is fine, but the wheel weights contact the caliper. I've included some pictures for reference.
P.S. Sorry the pictures aren't oriented correctly, I'm not sure why they are getting rotated. |
06-17-2023, 07:37 PM | #356 |
OZ Racing Hyper GT HLT 17x7.5 +35 in Star Graphite. The wheels fit with plenty of clearance, more than the stock wheels. Probably around 10mm of clearance from the caliper to the spokes. Honestly the wheel weights look like the closest point.
No spacers Suspension is 100% stock. 225/45R17 Michelin PS4S PS Please ignore the very poorly bedded rotors haha |
07-06-2023, 11:31 PM | #357 |
Drives: 17 brz limited
can anyone confirm Cr Kiwami clears brembos ? 18x9.5+38 are the specs
07-18-2023, 02:51 PM | #358 |
Drives: None
3mm clearance for stock Gen 2 BRZ 18" wheel
08-26-2023, 04:30 PM | #359 |
Drives: 2019 BRZ Sport-Tech RS
2008 Forester XT STi Enkei 17x7 +48 DO NOT FIT. Need 10mm spacer.
09-21-2023, 11:02 PM | #360 |
RTX Frost 17x7.0 ET40 fits but requires a 3mm spacer, resulting in 4mm of brake clearance.
11-25-2023, 06:03 PM | #361 | |
Drives: 18 BRZ tS, 27 GRMN 86
11-25-2023, 07:55 PM | #362 |
Wheels for Brains
11-26-2023, 07:20 AM | #363 |
Drives: '13 BRZ
11-26-2023, 11:00 PM | #364 |
I was able to test the base 17x7 wheel from the 2017-2020 facelift models and no amount of spacer will make it work.
I haven't been able to get my hands on 2013-2016 base wheels but I'm going to assume it's the same issue. I settled on 17x7 ET40 RTX Frost wheels with a 3mm spacer and it's perfect. |
The Following User Says Thank You to N_Raged For This Useful Post: | tobin (11-27-2023) |
Tags |
brz, performance package, wheels |
Similar Threads | ||||
Finding wheels to clear brembos | jojosbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-13-2018 08:46 AM |
Performance package Brembos | Ernest72 | Want-To-Buy Requests | 2 | 07-14-2018 08:06 AM |
Performance Package Brembos Freezing to Wheels? | texastwurkt3am | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-23-2018 08:31 AM |
What pads fit the Performance Package Brembos? | mistople | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-03-2018 05:15 PM |
