go_a_way1
Old 08-13-2016, 03:53 AM   #3613
I doubt it's the tune. Blaming a FNG on a JRSC is like blaming the CARB tune; this isn't rocket science, and it's not uncharted territory.
Got a log?
Old 08-13-2016, 04:17 AM   #3614
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by jainish007 View Post
No I don't. It just stalls when lets say Im driving and I see a red light. When I clutch in and go to neutral, instead of idle it just stalls.
In the mean time, try this; when you pull up to red light, quickly put it in neutral and release the clutch pedal before you stop. The flywheel will keep spinning and less likely to stall.
rb6freak is offline   Reply With Quote
Old 08-13-2016, 01:03 PM   #3615
jainish007
Drives: 2014 Monogram Scion FRS Whiteout
Got a log?
Can I bring it in for you to doble check?
jainish007 is offline   Reply With Quote
Old 08-14-2016, 12:00 AM   #3616
Email CSG and schedule an appointment. In the meantime, get a log!
Old 08-16-2016, 12:38 AM   #3617
snowdog
Drives: 2013 Scion FRS
Looking for advice. Just finished my install. When I first started it up it sounds like squealing on the driver side. Sounds like it is a bearing or belt issue. However I don't know if it is even an issue. Thoughts?
snowdog is offline   Reply With Quote
Old 08-16-2016, 03:12 PM   #3618
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Please check your Rotrex oil line connections. In the video it appears you may have hooked them up backwards, which would be catastrophic for the supercharger unit.
Also, email us at tech@jacksonracing.com.
Jackson Racing is offline   Reply With Quote
Old 08-16-2016, 03:45 PM   #3619
snowdog
Thanks for the response. I located the reservoir on the passenger side (not my picture), but still 1.125" above Rotrex reservoir clamp. So I did have to route my hoses differently, but matches the diagram.
To me, the sound does not seem to be coming from the Rotrex.
Old 08-16-2016, 04:29 PM   #3620
VABeachBRZ
How's the install guys? I just got my kit in yesterday and I plan on doing it over the weekend.
How long did it take you and what was the hardest part?
VABeachBRZ is offline   Reply With Quote
Old 08-16-2016, 04:50 PM   #3621
snowdog
Just installed mine last weekend. I would plan on about 10 hours or so depending on your expertise. Nothing really too hard, a few instructions could be clearer.
The Following User Says Thank You to snowdog For This Useful Post:
VABeachBRZ (08-16-2016)
Old 08-16-2016, 04:55 PM   #3622
Getting the bumper off is, literally, the hardest part.
Read the manual cover to cover a few times, before opening your other boxes.
Old 08-16-2016, 05:00 PM   #3623
VABeachBRZ
Will do. Just waiting on the last two packages and then taking the car to the shop to get the clutch installed then it's game time.
Thanks for your help dude. I'll be reaching out for the duel radiator/oil cooler soon probably
Old 08-16-2016, 05:02 PM   #3624
VABeachBRZ
I am by no means a expert with installing SCs or anything. I love to do the work myself so I can learn in case something goes wrong down the road
Old 08-16-2016, 05:38 PM   #3625
etc
Drives: '13 FRS
The install was pretty straight forward. As was mentioned before though be super careful about priming the rotrex before you start the car. I followed the instructions and primed it until the traction fluid started coming out of the SC inlet then closed it up. But I have been told my SC is louder than normal and is probably related to poor priming.
So if I did it again I would probably keep priming it until there was a pretty healthy flow out of the inlet as you have extra fluid and want to make sure you get all of the air out. Not sure if someone who has done more kits has any other suggestions for better priming.
etc is offline   Reply With Quote
The Following User Says Thank You to etc For This Useful Post:
Brz866 (04-26-2018)
Old 08-16-2016, 05:56 PM   #3626
snowdog
This is the best resource I found for removing the bumper and headlight.
[ame="https://www.youtube.com/watch?v=mMdIWZLUEj0"]SPECDTUNING INSTALLATION VIDEO: 2013 SCION FR-S LED PROJECTOR HEADLIGHTS - YouTube[/ame]
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
