#3599 |
Drives: 15 Impreza
Changing the bushings is definitely a next season project. I don't want any disputable parts on the car. I have RCE SS1 / KW based strut mounts, camber adjustment only. I need tons more seat time before I go making big changes to the car, again. I did notice quite a few cars at the Finger Lakes tour with ground control strut top mounts with way lower ride heights than my car.
#3600 | |
Drives: 4 wheels
#3601 |
Drives: 15BRZ
stx setup question
Unless i missed it, any body do a suspension setup using Koni shock/spring setup for STX? i didn't see any.
#3602 |
Drives: 2017 BRZ PP , 2005 Saab 97X
#3603 |
Drives: 2013 FRS
Has anyone in STX tried the Yokos out yet? I just got a set of Stones but now I'm second guessing that decision. Yokos are killing it in lincoln this weekend.
#3604 |
Drives: 2022 GR86
I think it's a little premature to say they are "killing it." You'll still be fine on the Bridgestone's.
#3605 |
Drives: 2013 FRS
I just said they were killing it at that one event. And sure, that evaluation may still be ambitious considering it's just a few cars. My point was just to ask if anyone had tried them yet to get some feedback first hand.
#3606 |
Drives: 4 wheels
Which class is it killing?
#3607 |
Drives: 2013 FRS
Let me rephrase. They are not killing any class. I waa incorrect. They merely won the pro in STR. Spurious at best, of course. Obviously nobody in STX has tried them that would like to provide feedback so my question and entire post about Yokohamas should just be disregarded.
#3608 | |
Drives: 4 wheels
#3609 |
Drives: 2013 FRS
I'm thinking the same thing. It may just end up being one of three tires that can potentially be competitive.
#3610 |
Drives: 2015 CWP BRZ
The people running the Yokos are already national champions so it’s difficult to say how much was tire and how much was driver.
#3611 |
Drives: 2013 FRS
#3612 |
Drives: 2013 FRS
Here's a question for those more familiar with interpreting the rules than I am. "Subframe position may not be changed." I imagine that subframe "collars" or "inserts" would theoretically change the position by spacing it down by a hair. There is material between the subframe and the body that wasn't there before. Am I correct here? Would the upper bushing inserts be prohibited? I can't imagine the lower inserts would be an issue but I am hesitant to put these in at all after checking the rules.
I'm curious because I just put the differential inserts in and I am really impressed with the result so the subframe inserts came to mind but I am not sure if they are legal. |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
