Old 11-06-2013, 05:45 PM   #3571
Jrohit
Jrohit's Avatar
Drives: 2013 FRS 10 Series #2072 (6MT)
Originally Posted by IloveBaldEagles View Post
If and when we meet, remind me to show you my warning when I was doing a 100 and got away with a warning. I wasn't in the frs then.
Definitely! I needs to be soon though. Maybe next meet I should be able to. I don't have my morning class so I'll be good to go that evening.
If anything, I'd be caught dead smiling.
Jrohit is offline   Reply With Quote
Old 11-06-2013, 05:47 PM   #3572
OrbitalEllipses
Drives: Attitude
I don't get off with warnings too often...but last time I did, I was playing race car and apexed over the double yellow.
Old 11-06-2013, 05:49 PM   #3573
Jrohit
Jrohit's Avatar
It's hard not to play racecar.
Old 11-06-2013, 09:30 PM   #3574
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Follow @pure_automotive_performance on Instagram for all my 86 pics from SEMA #pureautomotiveperformance
Pure Automotive is offline   Reply With Quote
Old 11-07-2013, 06:38 AM   #3575
BoostinIX
Gettin SIKKY sideways
BoostinIX's Avatar
Drives: '97 S14.5 / '13 BRZ
Send a message via AIM to BoostinIX Send a message via Yahoo to BoostinIX
Instagram: BoostinIX
BoostinIX is offline   Reply With Quote
The Following User Says Thank You to BoostinIX For This Useful Post:
IloveBaldEagles (11-07-2013)
Old 11-07-2013, 11:06 AM   #3576
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
Me and @No Brakes are going to watch Thor tonight at Tyson's at 8:45. Anyone else interested in coming in hopes of breaking the awkward date?
I am very insecure. I have no friends. I want people to love me
Old 11-07-2013, 12:13 PM   #3577
camelflage
Drives: pinto power
i think i might go back to stock suspension for winter. the noises im getting even after going with the whiteline rear end links are frustrating me.
camelflage is offline   Reply With Quote
Old 11-07-2013, 02:47 PM   #3578
Byebye
Byebye's Avatar
What noises?
Byebye is offline   Reply With Quote
Old 11-07-2013, 03:20 PM   #3579
camelflage
Drives: pinto power
Originally Posted by Byebye View Post
What noises?
well, from the front drivers side i get a sound like something is loose, but ive double checked everything there, so unless its just a noise from compression on the thrust bearing i've got no clue. from the rear, ive got clunks, and either end link on lca contact or the end link joints are popping. all low speed sounds, little bumps, inclines, turns, just pop pop ping boing.. sounds like i forgot to connect my sway bars, but that's not the case.. this time
i'm on ISC N1 coils, maybe 2" drop, using the supplied end links in the front. hotchkis sways, greased up, whiteline rear end links, stock LCAs. 18x9.5 +38 rpf1's with 225/40 tires.
Old 11-07-2013, 03:25 PM   #3580
Byebye
Byebye's Avatar
Adjustable endlinks?
Old 11-07-2013, 03:37 PM   #3581
camelflage
Drives: pinto power
fronts are not. no binding though. and the real kicker is i can push down on the strut tower on that side and hear noise, but cannot find any place its coming from.
rear endlinks are adjustable, short as they can go. [ame="http://www.amazon.com/Whiteline-Rear-Endlinks-2008-Subaru/dp/B004ZZVVM2/ref=sr_1_1?ie=UTF8&qid=1383856602&sr=8-1&keywords=whiteline+sti+endlinks"]Amazon.com: Whiteline Rear Endlinks, 2008+ Subaru WRX & STI: Automotive[/ame]
Old 11-07-2013, 03:43 PM   #3582
Byebye
Byebye's Avatar
rear endlinks are adjustable, short as they can go. Amazon.com: Whiteline Rear Endlinks, 2008+ Subaru WRX & STI: Automotive
I'm assuming the roll bar is not preloaded? My fronts came with adjustable endlinks and they needed a slight adjustment from lowering in order for the roll bar to sit parallel to the ground and not preloaded.
My rears were stock and the roll bar was at 45deg under load. I used KLC182 from whiteline and now they are probaby 15deg which is still not enough but I know it's not slamming on the endlink when I go over bumps.
One thing I did notice while putting on and after a test drive of the new endlinks is the knocking may be coming from the springs compressing and uncompressed. So I need to preload them some more. I was able to wiggle them in the spring perch under load and the knocking noise sounded the same.
Not sure if these were your symptoms but maybe some more ideas for you to consider.
Old 11-07-2013, 03:46 PM   #3583
camelflage
Drives: pinto power
Yeah, the spring preload is something i have yet to try because it means measuring the height again and im lazy and its cold in the garage. maybe this weekend. thanks. sways are pretty close to parallel on the ground, but i'll check again.
interestingly, i got the klc166 over the klc182 because the endlinks that came with the hotchkis were the same style as the 182, and i was convinced they were hitting the lca under load. wanted the 166 to get the endlink up and out from the walls of the LCA.
Old 11-07-2013, 03:54 PM   #3584
Byebye
Byebye's Avatar
If you have install pics I'd like to see those endlinks.
Mid-Atlantic spotting thread OMNOM Mid-Atlantic 7404 08-27-2021 08:30 PM
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
Its The Mid Week Chat! vividracing Off-Topic Lounge [WARNING: NO POLITICS] 17 07-09-2012 01:31 AM
#ft86club chat room ayau Off-Topic Lounge [WARNING: NO POLITICS] 1 03-02-2012 10:53 PM
FT86Club IIRC Chat Zaku Off-Topic Lounge [WARNING: NO POLITICS] 2 12-12-2011 09:36 PM
