02-12-2014, 07:37 AM | #3543 |
Drives: WR Blue BRZ, 240Z
There is no reason for the Phantom ESC not to sustain any prolonged period of use as long as you are able to provide the 8:1 (or 4:1 for the dual charger) charge:discharge ratio.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
02-12-2014, 07:48 AM | #3544 | |
I was planning to use boost on the straights only (15-20 secs out of a 90 second lap). While in DR mode WOT, would it be possible to use a spring-loaded switch or pushbutton to activate boost? |
02-12-2014, 10:05 AM | #3545 | |
Drives: 2013 Scion FRS
To pile on this - I have an upcoming HPDE at California Speedway - road track configuration. While 1/2 of the time will be spent on the in-field, the other half is spent on the banked oval. 20 minute sessions. I'm hoping I will have sustained power with the ESC on the outside and will have enough partial throttle time on the inside for recharge. Thoughts? Is it bad to run the battery down then keep asking for more? If the battery is below a certain amount will it go into a DR only mode? Might be nice to have a way to switch between DR only and full. I could run a few laps in full then switch to DR only for a few laps to ensure a good recharge then go back full. Maybe I'm off-base here but just thinking out loud...
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
02-12-2014, 11:07 AM | #3546 | |
DR mode is not free...the form of DR that is currently deployed will spin the compressor up to 100 percent if you are close to redline and actually adds about 20hp over stock. Yes it uses less than going flat out but on a track I suspect that you could still burn through it. Point I'm trying to make is that if you are on DR all the time you will not overcome the recharge rate of the batteries. Auto x or something like that which is only a minute or so is going to be fine. If you are asking for 20 minutes of boost this system will not provide it in its current forum. What you would be best to do in your case is disconnect the DR so it doesnt kick in so that you can use full WOT on the straights and recharge everywhere else.... Yes you will be down 10hp or so but good braking and smooth turns and transitions more than make up for the difference of 10hp... This is what thatruth did because he didnt have DR when on track. That being said no one has tried it yet(with Dr) and it may be okay depending on your driving style. I just know that the current DR actually boosts performance significantly which is awesome for daily driving. Sent from my HTC One using Tapatalk |
02-12-2014, 11:10 AM | #3547 | |
You can see that my tires did let loose when i went WOT but it was very managable. Remember again that we arent adding 150ft/lbs of tq like some turbo's do. We are adding a nice 80 to 30 depending on where you are in the rpm band. The turn is right at the start of the vid. There is another turn at 3:00 that is full throttle in second gear and you can see that i fought it a little to keep it straight. [ame="http://www.youtube.com/watch?v=Hs3s4lQ9a74"]FRS BRZ Electric Supercharger - Casual drive - YouTube[/ame] |
The Following User Says Thank You to fenton For This Useful Post: | normancw (02-12-2014) |
02-12-2014, 11:10 AM | #3548 |
Drives: 2013 FR-S whiteout
I just emailed Rob with the same question but thought I'd put this out there in case someone already knows the answer:
My ESC's pedal switch and digital readout both are wired in insulation. I'm ready to solder in a relay but don't know what to expect if/when I cut into this soft insulation. I noticed these soft-insulated wires are soldered together into a harness a few inches from the controller box under-hood. Basically I don't want to go cutting into things unnecessarily. |
02-12-2014, 11:15 AM | #3549 |
again at 340 i intentionally go WOT in 1st gear at mid corner
02-12-2014, 11:25 AM | #3550 |
Drives: FR-S,GTI
I just finished installing the kit. Very impressed with the way everything goes together. It looks real professional like it was factory installed. Took it for a run and I immediately got a P0108 fault code (something to do with the MAF out of whack) which I guess is something I should expect without the proper tune. I have the OFT and am currently running the Stg 1 A01C.bin that came preloaded on the tablet. Does anyone know if Shiv has released an OTS tune for the ESC on 93 octane? The only performance mods I have right now are a drop-in K&N filter and a Manzo cat-back. Once I finally get the OFH, I will go for the custom tune option. (I've been waiting so long for the header I think Shiv should throw in the custom tune for free!)
I want to thank Rob and all the beta testers for a wonderful product. I hope Rob has a patent on this thing. I think Toyota should seriously think about offering it at least as a factory option. |
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post: |
02-12-2014, 11:29 AM | #3551 | |
Drives: 2013 FRS
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post: |
02-12-2014, 12:22 PM | #3552 |
02-12-2014, 12:26 PM | #3553 |
Drives: VW
For track testing guys I will have a simple DIY to enable/disable WOT operation. Stand by....
Playing off @Sojhinn theme it will be called 'Super Pursuit Mode'. It will be a simple switch which allows you to activate SPM (Just like F1 detection zone for KERS) then use it on the straight, then switch the SPM off to use just DR mode. Only testing will tell how long using only DR will last. It consumes 100-300 watts @ higher engine rpms and can be sustained using little to no dump battery capacity. On the bench, 200 Watts can be maintained for 20 minutes straight. Soon I will have a 'plug and play' aux charger upgrade which provides ~5:1 rob |
02-12-2014, 12:30 PM | #3554 |
Drives: FR-S,GTI
Just went out and took some more runs and noticed something really weird.
When under boost at about 6000 RPMs the traction control light comes on. You know, the light that comes on when your wheels are spinning. This is in third and forth gear! I doubt that my wheels are spinning in forth gear on dry pavement. This happens every time I hit about 6000 RPM. Has anybody else noticed this? Also I have a question for Rob: What is that two conductor connector for that comes out of the motor controller? |
02-12-2014, 12:38 PM | #3555 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
I had the same issue without a tune.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
02-12-2014, 12:59 PM | #3556 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
Edit: I should note that I am talking about on e85. I am probably making around 185+ whp if I had to guess. |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
