#3515 | |
The Koyo would be the route I'd go for cost effectiveness. If you want something with more clearance, a custom radiator (that maximizes clearance, and also has a shroud built-in for aftermarket fans) or just the core portion of the JR Dual cooler are options. The extra noise from fans is subjective; I don't mind it at all since you barely hear them with the windows up, and not at all at highway speeds or with the radio on. |
#3516 |
Drives: 2015 Scion FRS
First dyno runs
Dyno results from last Friday. 2015 FRS, JRSC-C30 Kit, Delicious Flash N Go Tune, Ace 350 Header, and full exhaust. Running Clear (non-ethanol) 92 Octane fuel. Learned a lot regarding dyno's, fuel, and future upgrades. Ambient temps were 90+, so took some time to cool the car down before the 3rd... and best pull. Glad to have some numbers on paper to see where things go!!
| The Following 3 Users Say Thank You to cgjeff For This Useful Post: |
#3517 |
Drives: frs
So my power problems were a bad catalytic converter. It came loose from the shell then got compressed into the conical section of the exit of the cat. It compressed the core into a cone shape then started peeling the outer layers away. It was a high flow metallic core cat. Anyway, problem solved.
#3518 |
Drives: BRZ + Ducati M796
Anyone have a picture of the EO# badge, engraving, certificate, whatever it gets for the CARB legal tune?
#3519 | |
Drives: N/a
Sent from my SM-N910T using Tapatalk |
#3520 | |
driving smoother faster
Drives: Sold
Location of the cat? Brand of header or front pipe it was on? Was this on hw you bought new or was used by someone else before? |
#3521 |
After talking with Mike at CSG and Zach at Delicious, we have some theories on the low dyno results. Conservative Dyno, Traction Control not fully turned off, Poor fuel choice, Heat soaked system. First time experience for me, so will be better prepared next time. Data logs have been reviewed by Zach and the dyno numbers do not best represent how the car is actually running.
Ass in the seat says much more... lol. |
#3522 |
#3523 | |
Drives: N/a
#3524 | |
Quoting an e-mail sent to @cgjeff:
200 / 160 * 236 = 295 Crude, but somewhat accurate. |
#3525 |
No baseline on my car, but they do have two others that dyno'd at 160 & 161 whp.
| The Following User Says Thank You to cgjeff For This Useful Post: | Hicklinc (06-10-2016) |
#3526 |
Im hoping to get the Harrop kit once it gets CARB approved but considering the Edlebrock kit is advertised as a CARB kit even though it is CARB pending I got curious if anyone actually received a CARB sticker from either the JRSC kit or Works kit (only approved kits I'm aware of).
#3527 | |
Off topic, but Edelbrock will be mailing out CARB stickers to owners shortly. Also off topic, but the Harrop kit is also pending. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Irace86 (06-10-2016), kuczynskika (06-10-2016) |
#3528 |
As you know, 'it's common knowledge that the kit is CARB approved' type of conversation doesnt work with the popo.
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
