Old 01-12-2022, 04:24 PM   #3515
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I am using a Logitech G920 right now. I have a Fanatec CSL DD on order but I won't see it till mid to late March. For a seat I have been using a Playseat since it folts up nice. It doesn't allow good options for a shifter or e-brake though, and you need to calibrate your brake pedal so that 100% is a bit light or you will lift the front of it up under hard braking. Once I have the space I will be using the stock driver seat out of my car to build a proper setup with a PC and multiple monitors.
https://shop.playseatstore.com/produ...lack-alcantara
Whatcha got for pedals?
Old 01-12-2022, 04:26 PM   #3516
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The ones that come with the Logitech, they are meh. Serviceable but not great. I heard the Thrustmaster TH300 with pedals is a better option.
I have also noticed the G920 has gotten a bit sloppy on center but it has endured about 3 years of use.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Spuds (01-12-2022)
Old 01-12-2022, 06:32 PM   #3517
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
This was on Jalopnik this morning. No personal experience.
https://jalopnik.com/the-fanatec-csl...tch-1848338523
The Following 2 Users Say Thank You to bcj For This Useful Post:
NoHaveMSG (01-12-2022), Spuds (01-12-2022)
Old 01-12-2022, 06:51 PM   #3518
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Ok, I know you all have discussed your driving sim setups before, but now I'm actually paying attention lol. What does everyone use hardware-wise? Controller, wheel on desk, sim rig, etc?
Seriously considering building a sim rig and a new gaming PC once GPUs are available again. Hopefully soon.
Logitech G29 which is more than enough for most sims. 6 SP shifter is sold separately. The wheel comes with 3 pedals. My wheel setup is mounted to the desk while I acquire a better mount setup. Gotta remove the wheels from your chair because you’ll move a lot unless you have an actual rig.
Most sims are not too demanding graphics wise, u less you are into Forza but that isn’t much of a simulator. A 1080ti/1660 2000 series or even a 3060 would be more than enough to enjoy 1080p at 60FPS on high settings.
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
soundman98 (01-12-2022), Spuds (01-12-2022)
Old 01-12-2022, 07:09 PM   #3519
Spuds
The Dictater
Spuds's Avatar
Yeah, I was thinking of just getting/building a dedicated rig, not sure how beefy I would want it to be. How's the fold-up MSG? I have space for something a bit more solid myself but would be interested to hear your thoughts on that.
The csl-dd with the power boost is probably the wheel I'm going with, haven't looked at pedals yet, but my understanding is it really makes a difference in the experience to get good pedals.
My GTX 1080 is probably good for a start, it runs my 4k monitor at my desk pretty well with most games on highish graphics. I just need to get it back from my wife's PC lol.
The Following User Says Thank You to Spuds For This Useful Post:
Celica00 (01-12-2022)
Old 01-12-2022, 07:23 PM   #3520
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I was thinking of just getting/building a dedicated rig, not sure how beefy I would want it to be. How's the fold-up MSG? I have space for something a bit more solid myself but would be interested to hear your thoughts on that..
It's great if you are working with limited space. I would say much more comfortable then mounting to a desk, but not as good as a rig. It has a bit of play where the wheelbase mounts to the bar that holds it in place. The bar the wheelbase is mounted to also has a bit of play where it locks into the chair. The pedal base pivots for storage and if you get hard on the brakes in like a formula car you will rock the whole chair back a bit. The pedal mounting looks like it would shift, but it has not moved on me. I also wish there was a way to raise the pedals in relation to the seat base as it feels a bit too low for me. Overall it is comfortable and quite adjustable. I have had mine for as long as my wheel, about 3 years and it has held up well.
Spuds (01-12-2022)
Old 01-12-2022, 11:56 PM   #3521
cjd
cjd's Avatar
Drives: 2017 BRZ
I built a rig to tuck in the corner of the office...
The Following 5 Users Say Thank You to cjd For This Useful Post:
Captain Snooze (01-13-2022), NoHaveMSG (01-12-2022), spcmafia (01-13-2022), Spuds (01-13-2022), weederr33 (01-13-2022)
Old 01-13-2022, 01:02 AM   #3522
Spuds
The Dictater
Spuds's Avatar
Is that a dd1 or dd2?
Old 01-13-2022, 05:43 AM   #3523
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I am not saying that doesn't look awesome, because it does, but the right hand screen overlapping the center screen is causing me some agitation.
Old 01-13-2022, 08:34 AM   #3524
Helps eliminate the bezel between the monitors I suspect, and you wouldn't notice it as much straight on.
Old 01-13-2022, 10:24 AM   #3525
cjd
cjd's Avatar
Drives: 2017 BRZ
DD1,v3 pedals.
As noted, it improves how things look when in the rig, both geometry-wise and visually. Side panel surface lines up with the edge of the main active screen edge.
The Following 2 Users Say Thank You to cjd For This Useful Post:
Captain Snooze (01-13-2022), Spuds (01-13-2022)
Old 01-13-2022, 01:23 PM   #3526
Spuds
The Dictater
Spuds's Avatar
DD1,v3 pedals.
Ok, question on the wheel. What % of the torque do you actually use? Why would someone pick the dd1/2 over the csl dd now that the latter is available? Is 8nm just not enough torque for some folks?
Old 01-13-2022, 04:21 PM   #3527
cjd
cjd's Avatar
Drives: 2017 BRZ
43% though a bit lower at the moment due to some health issues... but had been looking toward 45% and feeling my way around any more or less.
I got the DD1 because I wanted a direct-drive setup and it was among the most affordable (and supported) bases available. I'm not sure I'd get it over the CSL DD base were I shopping now, but that wasn't available when I got this.
The Following User Says Thank You to cjd For This Useful Post:
Spuds (01-13-2022)
Old 01-13-2022, 04:23 PM   #3528
Any of the racing games support VR headsets? Flight Simulator supports them. To me it makes a huge difference in the "feel" once you get used to not being able to see your controls.
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 05:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 07:37 PM
