Old 03-29-2016, 09:46 PM   #337
Iceman
Iceman's Avatar
Drives: GT86
Originally Posted by tato.valverde View Post
Can you point out where? All i can find is that they are Coleman Racing rotors, but nothing else
http://www.rr-racing.com/BRZ-FR-S-Fr...gt86fbr002.htm
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline
The Following User Says Thank You to Iceman For This Useful Post:
tato.valverde (03-30-2016)
Old 03-30-2016, 05:33 PM   #338
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Cockatoo View Post
Dang, I just ordered the Front Sport kit and this issue would annoy the crap outta me...
Just clean the rotor really well and use a good high heat spray paint to coat the rotor. You don't really have to worry too much about paint on the swept area, as it will be removed by the front of the pad. This will leave a nice clean rotor that shouldn't rust for quite awhile.
DustinS is offline
The Following 2 Users Say Thank You to DustinS For This Useful Post:
8R6 (03-30-2016), DocWalt (03-30-2016)
Old 03-30-2016, 06:08 PM   #339
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
FWIW Once you're on track that coating will become worthless anyway. My factory rotors look horrible after two days on track. The heat burns off any sort of coating pretty quickly.
DocWalt is offline
Old 03-30-2016, 06:34 PM   #340
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by frslee View Post
@8R6 Not the best pics, but here they are. Stopping power is great and consistent. I really like this kit for my usage. It's larger than stock rotor, so it fills up the wheel area really well. One slight issue I had during/after the install was once the shims were attached to the pads and installed, it was ridiculously tight and the pad would drag to the rotors. I tried to wear out the pad, but it was keep dragging and didn't want to glaze the rotor. Ended up removing the shims and applied brake grease for now. It's so far quiet on braking. It's no big deal to buy shim set and apply once pads are worn down, or purchase thinner pad (0.65" I think. This one is 0.80" thick).
Looks like you're using the old version of the sport performance kit since this one has a directional slot pattern but the newer ones use a DBA style slotting that is non-directional. The picture looks like the front drivers side but that rotor looks to me like it belongs on the front passengers side. It's not the end of the world but maybe you want to check it out.
Originally Posted by 8R6 View Post
thanks for the pics man! appreciate the tip about the brake pads too. yeah these are supposed to be 0.80" i wonder if that's just an issue with the pads or if the calipers. the calipers are supposed to take 0.80"
@Rafi@RR-racing - have you guys heard from other users of the Sport Performance kit having this issue with the pads being too thick? just wondering if this is a isolated case or a common issue but easy fix? thanks!
When I got my kit, I test fit my caliper to my rotor with the BP10 pads in it and there was a fair bit of wriggle room without the shims, fitting the shims shouldn't be a problem. I'll know for sure when I put the kit on my car in a few weeks.
Lynxis is offline
The Following User Says Thank You to Lynxis For This Useful Post:
8R6 (03-30-2016)
Old 03-30-2016, 06:53 PM   #341
Pat
Pat's Avatar
Drives: 2023 BRZ
One cannot determine the proper direction of rotation by looking at the slots on the face of the rotor. Direction of rotation is determined by the vanes inside the rotor, and how they would most effectively evacuate the air from the hub area.
Pat is offline
The Following 2 Users Say Thank You to Pat For This Useful Post:
8R6 (03-30-2016), frslee (03-30-2016)
Old 03-30-2016, 08:55 PM   #342
frslee
Just drive it
Drives: 13' FR-S
Rotors' vanes are straight, so slot directions don't matter in this case.
frslee is offline
The Following User Says Thank You to frslee For This Useful Post:
8R6 (03-30-2016)
Old 03-30-2016, 09:23 PM   #343
8R6
8R6's Avatar
Drives: FRS
cool! can you post up what you find out after your install please? im getting my set delivered in a few days but i wont be able to put them on until probably a month or so. thanks!
8R6 is offline
The Following User Says Thank You to 8R6 For This Useful Post:
Lynxis (03-30-2016)
Old 03-30-2016, 09:29 PM   #344
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
@Rafi@RR-racing comments?
EDIT:
Im not seeing this issue here:
On the newer design rotors we are extending the paint zone. This provides a measure of protection for a limited period of time.
As you guys know, whether you use e-coating or zinc, it all comes off once your brakes get really hot. If you track your car, it will probably come off in one day. If you use your car only on the street, it will last a while, but eventually will come off, depending on how much water/corrosion/heat your rotors are exposed to.
-Rafi
Rafi@RR-racing is offline
The Following 2 Users Say Thank You to Rafi@RR-racing For This Useful Post:
Cockatoo (03-31-2016), DustinS (03-31-2016)
Old 03-30-2016, 09:45 PM   #345
Lynxis
Lynxis's Avatar
Definitely will do.
Lynxis is offline
8R6 (03-30-2016)
Old 03-31-2016, 03:01 PM   #346
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
So close I can taste it!
Cockatoo is offline
The Following 2 Users Say Thank You to Cockatoo For This Useful Post:
8R6 (03-31-2016), Kostamojen (03-31-2016)
Old 04-02-2016, 04:16 PM   #347
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Alright, my brake squeel is coming from the driver side front and can be felt in the pedal. What should I be looking for to diagnose this?
Kostamojen is offline
Old 04-02-2016, 08:27 PM   #348
Kostamojen
Moar photos of my brakes!
The Following 5 Users Say Thank You to Kostamojen For This Useful Post:
8R6 (04-04-2016), brandonblt2 (05-23-2016), DocWalt (04-02-2016), drewbot (04-25-2016), Lynxis (04-07-2016)
Old 04-02-2016, 09:19 PM   #349
acro
Drives: GT-86
Very sexy
acro is offline
The Following User Says Thank You to acro For This Useful Post:
Kostamojen (04-02-2016)
Old 04-02-2016, 09:58 PM   #350
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Any signs of grooving on the rotor? Could just be the pads needing to be bedded in HARD.
DocWalt is offline
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 08:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 06:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 05:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 12:31 PM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
