#337 |
Drives: 2014 Scion FR-S
I made it to the track again after installing the Jackson racing c38 kit. It took about 5 passes to figure out how to launch it. I was quite surprised how low i got the 60' times down to. stock wheels, tire size and pressures.
[IMG] FullSizeRender by shawn mcgettigan, on Flickr[/IMG]
#338 |
Drives: 2013 frs red
13.2? You know how to drive.
#339 |
#340 |
Drives: 2013 BRZ 1999 Subaru Impreza
Fun day at Cecil County Dragway in MD. It was the MD Subaru Club East Coast Shoot Out. Made a few passes today despite the somewhat cold day for the track conditions with base prep.
Temps were around 60. 2013 BRZ visconti stage 2 with 245/40R17 RE71R tires around 19 psi in the tires. Launching around 2-3k rpms without launch control. ![]() ![]() Sent from my SM-N960U using Tapatalk Sent from my SM-N960U using Tapatalk |
#341 |
A higher launch rpm and some clutch abuse would've been worth 3 tenths or so imo.
#342 |
Bringing this thread back from the dead
![]() Stock Brz with weight reduction -Spare Tire / jack removed/ trunk panels -Rear Seats removed -Pass Seat removed (Driver seat Bride bucket) -Ac Removed -Stereo system Removed -Curtain air bags removed -Alum Drive shaft -Whiteline Rear diff bushing inserts Stock HP throughout: -Stock Headers, cats, over pipe, front pipe & catback -Stock pullies -Stock Tune -Stock air box with inlet tube -Stock Fdr With all that being said I ran a bunch of 14.6's @ 97-98mph. I didn't want to break out during 14.50 index eliminations, so if I went faster than a 14.50 I would loose.. As the day went on and the track surface got better, I actually ran a couple 14.6's letting off top end @ 93mph to win the rounds and not worry about going below 14.5's. I feel It would of gone 14.5's for sure of better near the end. Being on the stock tire I did full stand still burnouts at 22psi in the tires. I was launching the car at 4500-4800 which I found to be the sweet spot of carrying wheel speed above 5000 rpms but spinning through first and squawking 2nd. It was a pro .400 tree so I was more concerned trying to catch a light while keeping the 4500 hanging there as I bumped into the beams. I was almost dumping the clutch just to make it consistent each round. The 60 foots were terrible 2.3's but the wheel speed to the 330 was fair for what I was doing. Once I get it down into the 1.8's-2.0's the Et should drop a ton. I was power shifting every gear driving it pretty hard. All in all it was a great first outing with the car & I plan to go to the next even in 3 weeks time. For the next round I will be swapping out to my light weight battery, disconnecting the front sway bar (Allowing a lot more weight travel) & probably bring my BBS wheels with the Drag radials to see how fast a Stock hp Brz can go with minimal parts. If I can crack a 14.3-14.4 on the stock tires and maybe a 13.99 with the drag radials.. I would be super happy ![]() Track was 35-40 C so super hot and about 34% humidity. If I remember correctly DA was 3200. More slips to come ![]() ![]()
#343 |
I somehow lost my 14.3 time slip, but here is one of my qualifying runs where I was letting off trying to hit a 14.5 for the 14.50 index class I run. On this run it felt so good! My method waspower shift 1st,2nd,3rd, 4th and as soon as I pull 4th I started playing with the throttle pedal and brakes.. I let off the most on this pass & still hit a 14.40 @ 86mph when it usually runs 96-98mph full out. I have only been going during elimination race days so when I get a chance next to just go full out in test & tune and not worry about 14.50 index racing.. I feel Deep 14's or a 13.99 coming with stock power / tune
![]() ![]() I know this thread has died off but I just want forum record of these posts as I was checking this thread a couple years ago without an 86
#344 |
^that's good mph for stock
#345 |
#346 | |
Drives: 2015 Scion frz
I have 235/45/17 Yokohama A052s on a 17x9 that I'm most likely going to use. |
#347 | |
#348 | |
oh and you think I should bother to do a burnout or just run em cold? |
#349 | |
![]() Another small tip is check the tire pressure cold.. So before the run in the lanes. Once you make a pass come back around give the tires 5-10 mins of cool off time before checking pressure again. You will see it bump 2-3 psi after a burnout / full pass usually. If you keep letting air out round after round of hot laps eventually when they cool off you could be down 5-8psi from your starting point for example. Bring a little compressor you can plug into your car outlet. I will do a run, let tires cool off. Add 1-2 psi and head to the lanes, just before the run drop them to desired pressure.
#350 |
Following up with this old post.. After the last race event I got to make a full out run without worrying about eliminations or breaking out of the 14.50 index. Decent burnout, 18 psi in the tires, 7200 Launch, Power shifting at 7200 So close!!! 14.00 @ 96 Track shut down after that pass. My buddy got a video of it so I will post when I get it uploaded. I might do one more test & tune day before the track shuts down. I want that 13.9 bad now ![]()
| Scion's free 2 year/25K mile maintenance plan? | whtchocla7e | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 06-06-2012 03:26 PM |
| La Times reviews BRZ | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 7 | 05-18-2012 11:11 AM |
| He lives his life 1 quarter mile at a time | ucla bruin | Other Vehicles & General Automotive Discussions | 8 | 12-21-2011 07:04 PM |
| $95 Track day at Willow Springs- Horse Thief Mile-Oct 16th | Louie | Southern California | 1 | 10-11-2011 12:31 AM |
| $85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal | Louie | Southern California | 2 | 03-20-2011 05:17 AM |
