#337 | |
Road-hole
Drives: 2013 Whiteout FR-S
twincharging is a unique animal...
If you're doing a compound boost versus a take over, you need to be aware that the turbo will need to be capable of providing the airflow you need at the boost levels that the turbo alone will be running at. So for instance if you're running the supercharger at 9 psi and want a final boost level of 24 psi, let's say, the turbo will max at about 10 psi, so if you want a top end power level of say 500hp, then you need a turbo that can push 50lbs/min at 10 psi. a GTX 3076r doesn't provide enough air at that level. The reason a lot of people don't compound boost is that you'd have better top end power by using a turbo alone. With a smaller displacement engine like a 2.0l though the torque curve is so much better that it becomes well worth it if you get it working right and size the turbo appropriately. Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | DustinS (06-27-2016) |
#338 | |
Drives: 2013 Ultramarine FR-S
I was wanting somewhere in the mid 400s on a low setting and close to 600 on a high setting, but it looks like I may not have THAT much control over boost, due to the way the system works. I want a highish power level, with a great torque curve that starts low in the RPM range. It seems I may just have to live with the GTX3076R and possibly buy a new twin scroll manifold to get a better low end.
#339 | |
Road-hole
well you definitely want a positive displacement blower.
The other good thing about a compound boost setup is that the S/C is providing more fuel and air so there are more exhaust gases sooner to spool up the turbo. yeah with a low boost setting about 400, and a high boost setting around 600-650, that's what I'm looking at eventually doing as well. I was looking at doing it at about 30 psi for high boost and 22 on low boost. There are charts that show you what a compound boost setup would look like as far as how much boost you'd be getting from each power adder device. at 12 psi on the turbo I don't know that even a 3576 would be enough, you'd probably need a 3582 to get where you want to be. At first glance that would seem like overkill because if you're running 30 psi on a 3582 alone you'd be making about 700hp although you'd be pushing efficiency. but in a compound boost setup you'll be closer to a 1.8 as opposed to a 3.0 so you max out power at about 600 still slightly pushing efficiency. a 3576 wouldn't be able to push the air you need to hit 600 in a compound boost setup. Jaden p.s. one other benefit to note on a compound boost setup. If you were running a 3582 alone on a fa20, you wouldn't hit max boost until about 5500 rpm, where as in a compound boost setup, you'll likely hit the 12-15 psi by about 3500 rpm, plus you'll be closer to max boost much sooner because of the compounding of boost. |
#340 | |
#341 | |
Long Post, but seems I need to find the VE and BSFC of the FA20 with a 10:1 Compression (Going Element Tuning Big Valve Head)
| The Following User Says Thank You to DustinS For This Useful Post: | Jaden (06-27-2016) |
#342 | |
Road-hole
yeah and all boost control is done via the turbo.
so it would probably be best to have a lower wastegate spring, say 5-6 psi and then an electronic boost controller to allow higher boost. That way you have more control over boost levels. Jaden |
#343 |
Road-hole
remember that the long one with all the maths you quoted...
That long post about all the maths is referencing compounded turbos. What we're talking about here is much simpler because of a relatively static P/R that positive displacement S/Cs provide.
Jaden |
#344 | ||
Almost Wondering if the Cosworth Supercharger Might still work. It is a PD Charger with extremely efficient Air to Water Intercoolers. The Sprintex intercooler apparently isn't the Best. From Cosworth Quote:
#345 | |
Road-hole
The size of the S/C isn't too big of a concern...
The main thing to consider is the efficiency at the p/r you'll be running. You don't have to worry about air flow because that comes from the turbo. Since you won't likely even need or want a high boost pulley and will only want to run around 9 or 10 psi out of the s/c, the tvs 900 should be plenty efficient at those levels. Jaden |
#346 | |
I am talking with the Street Attack Racing Guys in Hawaii who also have a twin charged FRS. They are looking for 1000whp out of their set-up though. I know they are running the new-ish Sprintex SPS 335. It is significantly more efficient than the regular 335. They were running a 35r, but have since upgraded to a larger turbo. Still waiting to see if they don't mind sharing their findings when running the 35R. They told me the SPS335 would net me ~450whp and tiny bit of nitrous could be used to get me up over the 500whp hump. That just didn't seems as fun ![]() http://www.facebook.com/superstreetm...4678384492907/
#347 | |
Road-hole
I was looking at a t76
The T76 at a 1.8 p/r keeps me in the 75-78% efficiency range at 60-70lbs/min of air flow. besides it becomes much cheaper as I can get an ebay t76 and a replacement center cartridge for less than a $1000 total...absolute best bang for buck. I'm building up the motor now and then I'll go from there, but I'll be looking at ~15K(12K and 16K after supprting mods really because I don't count my used engine and tranny buy that I spent $3200 on since I had to buy them anyways) total after built motor, e-force and turbo. ~20K when all supporting mods are said and done... I'm just lucky I have an extra tranny in my shop lol once I have that much power. I'll also be doing things piece meal. First thing is....actually that's under wraps for now. First thing is getting my original motor built up. Jaden Yeah, a 650whp 2800lb car for a total of a little over 40K...pretty tough to beat...lol |
#348 |
Drives: 2JZ FRS
i don't ever see 1000whp coming out of an fa20. im at 666whp at 28psi on a 6766 currently. maxed the di and pi (90% duty) with 1650's. switched to id2000's with 60psi base pressure and will be continuing thursday to 35-40psi. Id need 12 injectors to get to 1000whp on ethanol lol.
| The Following User Says Thank You to spitfire481 For This Useful Post: | DustinS (06-27-2016) |
#349 | |
#350 | |
Road-hole
Yeah...
that's over 300hp per litre...lol... Jaden |
| The reason I'm always broke - Dustin's Supercharged 86 | Dustin | Member's Car Journals | 211 | 11-08-2015 11:57 AM |
| Help! New Car Engine Blew Up. What are my rights? | Obsidiank | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 12-11-2014 12:43 PM |
| Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) | Kuzuri | Great Lakes | 20 | 02-16-2014 06:23 PM |
| Engine Warm-up Time | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 01-10-2014 01:03 AM |
| So my engine blew up.... | alliedcam1 | Engine, Exhaust, Transmission | 57 | 12-28-2013 03:50 PM |
