Old 03-08-2017, 02:19 PM   #337
ajc209
Drives: GT86 Cosworth
Originally Posted by Sleepypistonracing View Post
Yeah they are supposed to go with the oem top mounts so anything that's supposed to go on the oem strut should fit them. I use mine with velox adjustable top mounts in the front and oem bearing in the rear. Öhlins are using some spacecraft grade bearings in their top mounts and they are not worth the money (500ish a pop).
Skickat från min iPad med Tapatalk
Why are they not worth the money if they are spacecraft grade?
ajc209 is offline   Reply With Quote
Old 03-08-2017, 02:21 PM   #338
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 03-08-2017, 02:22 PM   #339
Sleepypistonracing
Sleepypistonracing's Avatar
Drives: GT86 Road legal time attack car.
Get them if you want to pay double for the kit. Öhlins themselves recommended me to get something else
Sleepypistonracing is offline   Reply With Quote
Old 03-08-2017, 02:27 PM   #340
ajc209
I've got the mi20 kit which came with the top mounts. Here in the uk the mp20 is £1750 and top mounts add £600 iirc. Are you saying they are 500 per corner?
Old 03-08-2017, 02:43 PM   #341
Sleepypistonracing
Wow that's crazy. In Sweden they are about 400£/corner. They seem to be priced similar on modbargains in the us with 1500$ for all four. I'm testing new spring rates for them during this years season too btw!
Old 03-08-2017, 02:52 PM   #342
ajc209
Ive seen you on the 86 track car FB group 👍
Old 03-08-2017, 02:53 PM   #343
Sleepypistonracing
Nice! I've started a project thread here yesterday. I will post any and all updates on the Ohlins there whenever I have something new to tell
Old 03-08-2017, 02:56 PM   #344
ajc209
It is interesting they dropped the rates claiming they were faster on their local circuit in sweden. I was under the impression the mi20 kit was developed at the nurburgring which is bumpy to say the least.... and they settled on 60N/mm on all corners...
Old 03-08-2017, 03:03 PM   #345
Sleepypistonracing
Agreed. My contact at Öhlins is saying that 6/6 was undrivable. It's strange though considering our tracks are a lot better than the ring and competitors are running much higher rates. However, the ohlins dampers are extremely advanced. They are very similar to the TTX dampers (a kit starts at about 10000£). They are also running with a lot of pretension on the springs. About 30mm. This is also quite different than competitors. I know that they are very conservative in their spring rates on all their Porsche kits as well but still they are beating others. It's gonna be very interesting to try them out on track soon
Old 03-08-2017, 03:22 PM   #346
ajc209
I was also told the DFV is very advanced too. Ive seen the piston design somewhere. It has three oil paths so the transition is smoother than the classic digressive knee. This makes for a smoother ride but also more grip becuase the damping doesn't suddenly stop increasing.
Anyway I tried 70N/mm at the back and found it quite tail happy with -2.5 front and -2deg at the back. I am Cosworth supercharged too though so the extra 25kg at the front also contributed. I switched back to 60N/mm and its mote to my liking. The extra power makes it easy to rotate the back. Perhaps a more skilled driver might like more rear spring by 60N/mm all round is nice.
Regarding the mp20. They are the same dampers as the mi20 just differnt valve rates. According to my spreadsheet they absolutely must run preload or else they will be running on the bumpstops under the weight of the car.
Old 03-08-2017, 03:26 PM   #347
Sleepypistonracing
Yes. I was told the 4/3 is for performance tires and that on R-compounds I could increase 1-2 both front and rear without having to revalve the dampers. Hence I don't think there is any difference at all between the dampers in the two kits. I'll ask them next time I talk to them though
Old 03-08-2017, 03:59 PM   #348
ajc209
I think the consensus is up to 25% deviation is okay on the mi20 kit.
I am sure the low speed damping will be different. Critical damping for a 60N spring vs a 30N spring is quite a difference.
Old 03-08-2017, 04:11 PM   #349
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I think that the mi20 kit with the 60N/mm rate was based on feedback from the Japan office. There wasn't a development at the Nurburgring.
Old 03-08-2017, 04:14 PM   #350
Sleepypistonracing
Originally Posted by nikitopo View Post
I think that the 60N/mm rate was based on feedback from the Japan office.
This is correct! I remember them saying that testing the Japanese spring rates here was pure drifting.
I will let you guys know about the valving after I speak to them again!
Skickat från min iPhone med Tapatalk
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
