#337 | |
Drives: 2014 SWP BRZ Limited 6SP
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now. |
#338 | |
Drives: 18 BRZ tS, 27 GRMN 86
Were you using stock top hats or aftermarket top hats? If you are using stock top hats, did you use any camber bolts or re-use factory bolts? Mind sharing your alignment spec? Thanks! |
#339 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
-3.2 front and -2.5, -2.6 setup by Edgar Morales (@endlesspain) on this forum. He was instrumental in building the car, taking pyro readings, watching videos to finetune suspension etc. 0 toe all around. Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
| The Following User Says Thank You to lutfy For This Useful Post: | botbs (04-23-2018) |
#340 |
1:22.6 Summit Point NASA TTD
Lap Record for TTD (previously held by an E36 M3): http://timingscoring.drivenasa.com/N...20Classes).pdf
#342 |
Summit Point Main. Best time of 1:22.1
[ame="https://www.youtube.com/watch?v=M5CMoYWZc8Q&t=5s"]NASA Summit Point Fast Laps April 2018 - YouTube[/ame]
#343 | |
Pissin off regressives
Drives: They have engines.
I'm using Raceseng CasCam. My alignment really depends on track and tires I will be using. Since I do my own alignment, is beneficial for me. It can be anywhere from 3.1 to 3.5 front, 2.5-2.7 rear with maximum positive caster. |
#344 |
Drives: 2017 BRZ
[ame="https://www.youtube.com/watch?v=t5L_RW8bMmg"]https://www.youtube.com/watch?v=t5L_RW8bMmg[/ame]
NCCAR CCW - 1:45.8 |
#345 |
Drives: 17 BRZ Series.Yellow
Wish I got some video but I don't have a good in car set up right now. Ran NHMS (chicane/chicane) last weekend in the BRZ. The car is stock outside of camber bolts and Conti ExtremeContact Sports (225's). My fastest lap of the weekend was a 1:26.4 and it happened to be during the time trial.....always a plus.
This was my first event in the BRZ and I was very pleased with it's performance (my track car is a SpecE46/BMW 330). Sent from my Pixel using Tapatalk |
#346 |
Spent the weekend at Palmer Motorsport Park with my local time trial club, COMSCC. Brought the BRZ, obviously, and had an awesome weekend.
The car is still stock....with the exception of camber bolts and 225/45 Conti Sports. Saturday was extremely hot and humid. The best I could muster was a 2:01 (womp womp). Sunday was roughly 10-15 degrees cooler which lead to faster times all around. After continuing to learn the car and getting more and more comfortable, I was able to run a 1:57.1 during the TT. Overall I'm pretty happy with that given the "lack of tire" on the vehicle. For reference the fastest BRZ in the club (won his class last year - has Formula Ford history) ran a 1:52.x this weekend......on Toyo RR's......with camber plates, Ohlins and ~100lbs less than me. Sent from my Pixel using Tapatalk |
#347 |
Drives: 2015 Subaru BRZ Limited DGM
You mean Sash? Might want to check the times again when they post them. He got into the 1:50's. He was hauling.
I was in the Dark Grey #76. By process of elimination, were you the yellow 2017? I think we had a good back-and-forth in the morning practice sessions? |
#348 |
Drives: 2023 BRZ
#349 |
Yes, I was the yellow BRZ.
Wow!!!!.....I had no idea he ran a 1:50.xx! That's insanely fast for a T40 BRZ. Either way, kudos to Sash. This past weekend was a ton of fun. Congrats on getting your license! Sent from my Pixel using Tapatalk |
#350 |
Thanks! See you around.
| Can too much grip hurt track times? | ayau | Tracking / Autocross / HPDE / Drifting | 53 | 04-22-2013 11:28 AM |
| Top Gear (UK) track times | GeeTee86 | AFRICA | 29 | 02-15-2013 08:04 AM |
| Before/After Track Times (Sonoma Raceway) | CorteXracing | Tracking / Autocross / HPDE / Drifting | 5 | 11-26-2012 11:28 PM |
| POST YOUR FASTEST GT5 NURBURGRING TIMES.... | FT-86GOD | Other Vehicles & General Automotive Discussions | 96 | 07-15-2012 01:45 PM |
| GT5 - fastest Suzuka (full track) times | NESW20 | Other Vehicles & General Automotive Discussions | 11 | 04-03-2011 01:20 AM |
