Old 06-03-2013, 04:11 PM   #337
ap1mikeo
Drives: whiteout
This is a little more than you would expect to sneak past QC.
My best guess would be that in the development process not much time was devoted to testing 91 octane. Both the crickets and this detonation issue seem to originate from this oversight.
More importantly, can we verify the current us-Toyota Ecu flash solves this issue?
ap1mikeo is offline   Reply With Quote
Old 06-03-2013, 04:16 PM   #338
Stevo22
Stevo22's Avatar
Drives: GR86
Originally Posted by GTM_Challenge View Post
Just got back from the dealer - they flashed my car to the newest ROM, but sadly, it's not the same ROM they have overseas. Biggest issue the newest ROM fixes is a thermostat issue according to my dealer. :wtf:
Also printed off South Africa TSB and gave it to my service writer - he's going to look into it this week.
I assume his dealer is Toyota not Subaru.
Stevo22 is offline   Reply With Quote
Old 06-03-2013, 04:18 PM   #339
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Correct.
GTM_Challenge is offline   Reply With Quote
Old 06-03-2013, 04:20 PM   #340
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by xjohnx View Post
Right, but if the parameters of the STOCK ECU mapping allow (or CAUSE) that mechanical failure to happen, that CAN be eliminated.
This. The problem is caused by the ECU's behavior, nothing else. The ECU can easily be changed to get around this problem as already seen through data logs.
I know the OP will have an uphill battle just because this is the second time it's been in for this issue, but hell, there seems to be plenty of supporting evidence that fixing the ECU's program will prevent this from happening in the first place. Both from Toyota and others who have done datalogs and then modified their tunes to fix it.
Everything is a wear item, but I don't like my wear items to have accelerated wear due to shitty OEM ECU programming. I stuck with the OEM ECU/tune to avoid issues like this, until Subaru releases the corrected ROM to US customers it seems that I should get a tune that addresses this putting myself at risk from a warranty perspective while fixing this issue that "doesn't exist"....
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-03-2013, 04:35 PM   #341
wootwoot
Drives: FRS
^Amen.
wootwoot is offline   Reply With Quote
Old 06-03-2013, 04:38 PM   #342
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by DarkSunrise View Post
Has anyone confirmed whether any of the existing aftermarket tunes (Visconti, etc.) correct for this issue?
Visconti has stated in his most recent tune that the fix is in place. I'm currently running that tune. Spark tables have been updated to retard post 5.5k. I don't know if that lingo is correct as I'm no expert but just stating what I've read.
post_break is offline   Reply With Quote
Old 06-03-2013, 04:39 PM   #343
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I share the same frustration. It's a catch 22.
Old 06-03-2013, 04:39 PM   #344
dsgerbc
Drives: BRZ(sold), STI
I guess the bottom line is that for now we should be granny-shifting after all
dsgerbc is offline   Reply With Quote
Old 06-03-2013, 04:41 PM   #345
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Correct, and both Subaru and Toyota should not only provide the updated ECU flash but replacement of the impacted wear items, since that premature wear is caused by the faulty ECU in the first place.
I certainly hope this is getting the right attention with corporate and a solution is on the way to the states in rapid order.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 06-03-2013, 04:42 PM   #346
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Unless it happens outside of shifting too.. like Mike I also modulate throttle to get the car to do what I want on the track. I don't power shift it or anything like that, but I will be near redline, lift, then floor it to get rotation. That should pretty much do the same thing as the near-redline upshift being mentioned. Although .6 second shifts aren't that hard to do without power/quick shifts either
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-03-2013, 05:10 PM   #347
DarkSunrise
DarkSunrise's Avatar
Great, thanks! This might push me to get a tune after all.
2022 BRZ Build
2013 FR-S Build
Old 06-03-2013, 05:19 PM   #348
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
not to redline until reflash is done
hope Toyota and Subaru release TSB for this soon
Old 06-03-2013, 05:25 PM   #349
Carwhisperer
Drives: A lot of supercars.
With out how many people are starting to be affected by it, it will inevitably happen sooner than later. Me being a victim for the 2nd time. Same stock motor.
Carwhisperer is offline   Reply With Quote
Old 06-03-2013, 05:28 PM   #350
So we're not the only one to have this happen twice...
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Denied service... Chen Northwest 37 09-13-2013 08:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 11:17 AM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 08:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-07-2012 11:57 PM
