#337 |
Drives: 13' DGM Built FBM BRZ
#339 | ||
Drives: Vortech Supercharged M6 FR-S UM
1. What problems or issues have you had post install? None here in house. Might be a good idea to check clearances after the first post-install drive, and again a day or two after initial install, but that would hold true with any kit. Other than that, you should be good to go. 2. Did you make any mistakes or should you have done anything different? What others have said about the drill portion of the intercooler install comes to mind. You'll need a powerful drill and good bits, or it can be a difficult task indeed. 3. How do you feel about the performance, anything strange in terms of noises sounds you hear at low RPM and higher RPM? Very linear, and quite exhilarating performance. The compressor can be heard at idle to some extent, and (of course) the bypass valve can be heard between shifts. 4. Where do you mount or hide the stainless steel drain line? Nothing in manual about it. Can either be left coiled and zip tied, or can be zip tied off to framerail or any other non-obstructive location. General Questions: 1. Is there a guide to changing SC oil? This: Quote:
3. Extra belts is it Gates Model: K060975? What about using Gates Green Stripe Micro-V Belt As long as the belt is a good quality belt in the correct length and size, any belt of your preference may be used. 4. Manual mentions you can't drive in temps below 25 degrees is that true, never heard that you cant drive it in winter before? It is a mechanical piece cooled by oil, just like any other similar device. Viscosity in temperature extremes would be a concern with any and all engine components, not just a Supercharger. We place the warning on the Supercharger because that is the part that we manufacture. Similarly to how steps must be taken in any turbo application to prevent the oil from getting too hot, leading to oil coking issues, steps must be taken to avoid the Supercharger oil from being too cold at the instant of initial startup. However, the warning relates only to initial startup in below 25 degree weather. Once the vehicle has been brought up to normal operating temperatures, everything will operate exactly as any other day. The same tolerances inside the unit that allow it to be quiet and super efficient, also have to be tight in order to be quiet and super efficient. Before initial startup (if the vehicle has been sitting for hours) in under 25 degree conditions, a block heater, heating blanket, or even a shop light on under the hood for enough time to raise the underhood temp above freezing is sufficient. Once the vehicle is at normal operating temperature, no other steps are required. |
| The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post: | Dezoris (05-24-2013), Sniper2606 (05-24-2013) |
#341 |
SLO NO MO
Noticed my boost not getting past 4.8 PSI. Checked for leaks and the coupler on the intercooler output side was partially popped off. I guess I didn't tighten it properly. Will work on it tonight or tomorrow.
Edit: All better now. Getting pushed back into my seat again, woot! Sent from my Nexus 4 using Tapatalk 2 Last edited by Foobar; 05-26-2013 at 09:27 PM. |
| The Following User Says Thank You to Foobar For This Useful Post: | ngabdala (05-28-2013) |
#342 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Uh oh, I was planning on running this in my year round frs (typically down to negative 40C/ negative 40F during winter ) hmm... this could be interesting...
Nolan
#343 |
Yeah there is certainly some issues with the kit that you have to ask the right questions to get answers.
#344 |
1337
Drives: 2013 BRZ WRB S/C
It's not anywhere as cold here in Ontario as it is for you in Edmonton, but I am definitely going to be below -4C for most of the winter. Block heater is an option when I'm at home, but not parked at work, it would be annoying to have to use it when the car wouldn't need it otherwise though.
#345 |
I'll take it to pm and post after if we can figure something out. I don't understand certain things about this temperature issue... don't want to clutter the thread with misinformation
Nolan
#346 |
Thupercharged
For anyone else looking to replace the plastic bypass valve with something a little more robust/louder, I found a bolt in replcement.
http://www.turbosmartusa.com/product...-universal-fit You want the 25mm version. ![]() It is a dual port, so you can retain the K&N filter on the dump port. Both ports are the same 1" as the plastic bosch unit. It simply replaces the bosch unit retaining the factory hose/K&N filter. For those who will argue that this may suck in un-filtered air through the "horn" port, the supercharger produces more airflow than the engine can ingest even at idle. Also, this valve only fully opens to dump air out of the "noisy" horn at high intake manifold vacuum/positive pressure in the charge pipe. Otherwise it only vents to the dump port with your K&N filter. This results in a valve that operates pretty much exactly like the included plastic bosch valve, however at moderate/high boost it produces a nice deep "whoosh" sound like a traditional BOV. You can also block off the "horn" with the included blocking plate, then it will work exactly like the plastic bypass valve without any noise. Unnecessary? Probably. But it is fun, and I prefer aluminum over plastic. Perhaps Vortech can chime in if this is a bad idea, but I'm familiar with boost and this seems solid in operating theory with no chance of unfiltered air entering the system(My main concern).
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| The Following 3 Users Say Thank You to DJCarbine For This Useful Post: |
#347 | |
Small penis big dreams
Drives: '13 Scion FR-S
with all due respect, fuck that
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE 277hp 93 octane 370hp on E-85 |
#348 |
I Love custom Turbo kits
Drives: Limited BRZ
Good BOV's typically run 200-250. From DJCarbine's perspective, he just spent around 5K on a kit, what are 200 more to make it sound like he wants?
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | draggin_az (05-30-2013) |
#349 |
i guess but $200 just to change the way it sounds when you let off the gas or push in the clutch......i'll pass
| The Following User Says Thank You to draggin_az For This Useful Post: | Sportsguy83 (05-30-2013) |
#350 |
Drives: Forced Induction and LSx Swaps!
The last kits we've gotten have all had the new aluminum BOV's. I'll see if I have a pic, they're really nice - machined look, black finish, looks a lot like that Turbosmart one but with no branding on it. Certainly no need to buy a replacement.
| Vortech Supercharger | denverizzles | Forced Induction | 176 | 10-19-2013 07:48 PM |
| New Vortech Supercharging System Information... | Brian@Vortech | Forced Induction | 306 | 11-08-2012 06:49 PM |
| Supercharging the GT86 | Billy2224 | Engine, Exhaust, Transmission | 13 | 06-05-2012 04:58 PM |
| Turbo/Supercharging Your FRS | BoostJunkie | Engine, Exhaust, Transmission | 123 | 05-18-2012 07:26 PM |
| Supercharging: the forgotten form of FI | madfast | Engine, Exhaust, Transmission | 76 | 03-02-2012 06:06 PM |
