Tracking / Autocross / HPDE / Drifting What these cars were built for! |
10-09-2021, 05:23 AM | #337 |
Drives: 2013 Scion FR-S (949 Racing)
Country: USA
State: California Track Name/Configuration: Sonoma Raceway Time: 1:48.847 NA/Forced Induction/Swap: NA Driver: Sonny Watanasirisuk Video: Xida 600/600 with 949 Racing billet coaxial mounts 22mm Perrin front sway, stock rear Renderos Racing 4-point roll bar DIY Alumanite front splitter APR GT250 wing + Singular endplates -5.0° front camber -2.5° rear camber 265/35R18 Goodyear SC3R (7 heat cycles) 18x10 +40 XXR CNC forged wheels Delicious tune, 186whp on E85 (sick motor, down from 205whp) |
10-14-2021, 02:13 AM | #338 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Country: Canada
State: ON Track Name/Configuration: Grand Bend Technical Time: 1:15.899 NA: Yes (Stock #1) Set up: Ohlins MP20 245/40/17 RS4 Gloc R12/R6 Bride Zeta IV Stock tune, stock drivetrain |
10-14-2021, 03:42 PM | #339 |
Drives: 16 FRS
Country: USA
State: California Track Name/Configuration: ACS Roval Time: 1:58.095 NA/Forced Induction/Swap: NA Driver: William Chen car mods: Tires: Advan A052 245/40-17 on 949racing 6UL 17x8 wheels. Tires are way too wide for the wheel, steering is unresponsive. Difficult to find tire limits. stock Sach suspension Perrin 22mm front and 19mm rear sway bars front camber plates rear Moog lower control arm Jackson Racing oil cooler DTC60 brake pads Tire pressure: 41psi front / 35psi rear hot Alignment: Camber: -3.2 front and -2.2 rear. zero toe front, tiny toe-in in the rear. Pyrometer says front needs more, close to 4 to be ideal, but that could affect braking. This was a super windy day, it would of been a 1:56s without wind. Video: Last edited by bellwilliam; 10-14-2021 at 07:23 PM. |
The Following User Says Thank You to bellwilliam For This Useful Post: | 949 Racing (10-14-2021) |
03-07-2022, 04:43 PM | #340 |
Drives: 2015 Scion FRS Release Series 1.0
I had a VERY similar time!!
FI 2015 Release Series 1.0 Automatic Track: Waterford Hills Michigan Time: 1:17.77 Driver: Omer Zafar Date: July 25th 2020 Mods: 17x9 RPF1s on RE71Rs, SBD turbo, Full Blown oil cooler, Spal fans, Bilstein shocks, Eibach springs, Verus plates, Winmax W4 pads, Verus diffuser, APR splitter, Seibon wing & vented hood, Whiteline bushings Video: |
03-07-2022, 04:45 PM | #341 |
Track: Nelson Ledges Ohio Time: 1:18.88 Driver: Omer Zafar Date: July 25th 2020 Mods: 18x8.5 MR140s on Michelin PSS’s, SBD turbo, Full Blown oil cooler, Spal fans, Bilstein shocks, Eibach springs, Verus plates, Winmax W4 pads, Verus diffuser, APR splitter, Seibon wing & vented hood, Whiteline bushings |
03-09-2022, 01:18 PM | #342 |
Track: Road America (with chicane) Time: 2:57.83 Driver: Omer Zafar Date: August 24th 2020 Mods: 17x9 RPF1s on RE71Rs, SBD turbo, Full Blown oil cooler, Spal fans, Bilstein shocks, Eibach springs, Verus plates, Winmax W4 pads, Verus diffuser, APR splitter, Seibon wing & vented hood, Whiteline bushings |
09-06-2022, 09:06 PM | #343 |
Drives: 2014 FR-S
USA/Colorado/High Plains Raceway/Full Course/2:03.9/FI/Mike Gallucci/Turbo FA20
https://drive.google.com/file/d/1loO...?usp=drive_web |
09-13-2022, 10:48 AM | #344 |
Drives: Halo 860
Country - USA
State - Michigan Track Name and Configuration - Grattan Raceway Time - 1:29.732 NA, Forced Induction, Swap - NA Driver - David Best Setup - OFT Stage 2+ 93 Borla UEL header Tanabe Concept G catback Jackson Racing dual radiator/intercooler Fortune Auto 510 Coilovers (8k square, rebound at 20F 18R) SPL Rear LCA -4° front camber -2.2° rear camber 0° front toe 0.18° rear toe in ~5.15" ride height at pinch weld 245/40R17 Hankook RS4 17x9 +35 Enkei RPF1 CSG pads (C1 Front, C2 Rear) ----------------------------------------------- ========================== ----------------------------------------------- Country - USA State - Michigan Track Name and Configuration - Waterford Hills Time - 1:16.507 NA, Forced Induction, Swap - NA Driver - David Best Setup - OFT Stage 2+ 93 Borla UEL header Tanabe Concept G catback Jackson Racing dual radiator/intercooler Fortune Auto 510 Coilovers (8k square, rebound at 20F 18R) SPL Rear LCA -4° front camber -2.2° rear camber 0° front toe 0.18° rear toe in ~5.15" ride height at pinch weld 255/40R17 Falken RT660 17x9 +35 Enkei RPF1 CSG pads (C1 Front, C2 Rear) |
09-14-2022, 09:56 AM | #345 |
Track Day Junkie
Drives: 2022 BRZ Limited
Show the proof!
REALLY!
The WGI lap record, set recently, for a spec Miata is 2:14 The best I'm certain of is a buddy's 2:18, in a tuned (190HP) 2017 PP BRZ. I equaled that time, in a rolling lap, with my stock engine/stock exhaust 2022 BRZ on 8-29-2022.
Try this Jalapeno son! It ain't hot...
Scargo on IWSTI (Journal of STI track car) Scargod on NASIOC. Track Day Videos |
09-14-2022, 10:57 AM | #346 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
The Following User Says Thank You to lutfy For This Useful Post: | Scargod (09-14-2022) |
09-15-2022, 07:33 AM | #347 |
Track Day Junkie
[QUOTE=lutfy;3547076]Another fellow competitor did a 2:08.08 in a NA 86:
Whatever the weight, power and tires, that's amazing for TT5. Really fast for a NA BRZ, period!
09-15-2022, 09:42 AM | #348 | |
[QUOTE=Scargod;3547181]
Back to the drawing board Lutfy
Tags |
lap record, lap time, race track, track record |
Similar Threads | ||||
Anything going on with 86/brz platform? | Vr4gasmtt | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-12-2016 01:55 PM |
Indigo Dash cam that records you? | Packofcrows | Electronics | Audio | NAV | Infotainment | 3 | 08-23-2015 07:54 PM |
FS: 2004 Toyota Matrix - Dealer Serviced, Full Records! | that_guy | Canada Classifieds | 1 | 09-23-2014 10:43 AM |
Can Toyota use the 86/FR-S/BRZ platform for anything else? | gymratter | Scion FR-S / Toyota 86 GT86 General Forum | 83 | 04-24-2014 06:41 PM |
You don't break track records by settling! Custom Valved BC Coilvers and Carbotech XP | Element Tuning | Brakes, Suspension, Chassis | 24 | 07-23-2012 09:35 PM |
