Old 03-19-2021, 04:16 PM   #337
jflogerzi
jflogerzi's Avatar
Yup. They were made for the sti axle back but reports say they help for all exhausts. Must be ordered from japan
2013 Series 10 FRS #553
Old 07-10-2021, 01:26 AM   #338
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
These are my before and after dynos with the JDL 4-2-1 header on 93 octane:
The Following 3 Users Say Thank You to Mike_ZN6 For This Useful Post:
jflogerzi (07-10-2021), sato (11-20-2021), Stonehorsw (07-11-2021)
Old 07-10-2021, 01:37 AM   #339
jflogerzi
jflogerzi's Avatar
Gonna be scheduling time with Zach as CSG. Won't have before but I am sure they have a stock Dyno that we can add to compare. Will be getting 91 and e85 really dialed in
Old 07-10-2021, 01:38 AM   #340
jflogerzi
jflogerzi's Avatar
Wow what a perfect NA Dyno graph. Look at how flat it and pulls till redline
The Following User Says Thank You to jflogerzi For This Useful Post:
Mike_ZN6 (07-10-2021)
Old 07-10-2021, 04:20 AM   #341
gpvecchi
gpvecchi's Avatar
Who made the tune?
gpvecchi is offline   Reply With Quote
Old 07-10-2021, 09:40 AM   #342
Mike_ZN6
Mike_ZN6's Avatar
Originally Posted by gpvecchi View Post
Who made the tune?
The car was tuned in person at PTuning by their master tuner, Toan.
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
gpvecchi (07-11-2021)
Old 07-11-2021, 10:41 PM   #343
Mike_ZN6
Mike_ZN6's Avatar
I noticed today that the overpipe on my car has started banging against the front subframe when the engine shifts towards the passenger side. After the install of the JDL 4-2-1, PTuning pointed out the clearance to the subframe was very close and they said this may be an issue.
PTuning has suggested placing some shims under the passenger motor mount to get some additional clearance. I am also thinking I should probably get some stiffer motor mounts like the STi units.
Is this an install issue? Has anyone else had this problem?
Old 07-12-2021, 01:15 AM   #344
jflogerzi
jflogerzi's Avatar
Overpipes have always been a problem on this car. Is it stock or aftermarket?
Old 07-12-2021, 01:19 AM   #345
Mike_ZN6
Mike_ZN6's Avatar
It is a JDL 2.5" overpipe that was installed at the same time as the header.
Old 07-12-2021, 02:06 AM   #346
jflogerzi
jflogerzi's Avatar
Ahhh it's mostly aftermarket ones that can have clearance issues.
Old 07-12-2021, 05:06 AM   #347
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by solidONE View Post
Get it optimized then? What’s the issue? If I’m not mistaken cosworth uses this header.
Late reply but Nameless developed the headers used by Cosworth.
Old 07-12-2021, 05:37 AM   #348
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Better get some STI or TRD engine mounts ( Same stuff anyway)
Very minimal vibration (from the gearbox mount) which settles after a few thousand kms.
I installed the gearbox mount later and had the two front mounts first.
Thefalls is offline   Reply With Quote
The Following User Says Thank You to Thefalls For This Useful Post:
Mike_ZN6 (07-12-2021)
Old 07-12-2021, 10:15 AM   #349
jflogerzi
jflogerzi's Avatar
Go for the group N STI mounts.
Old 07-12-2021, 10:37 AM   #350
steverife
Drives: 2016 Scion FRS
Good luck getting the STi mounts. And if you find 2 sets, let me know!
I haven't noticed the issue with the subframe and I'm on stock mounts launch the car hard for autocross. My concern when I put the header onto the car is that there is only maybe 2 or 3 mm between the tubes and the radiator support. I was worried about melting my fans, but it hasn't proved to be an issue so far.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 03:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
