| Member's Car Journals Car journals by our members. |
#337 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Amazon Catch Can
Added a catch can today. These are all over amazon for ~$20. Has a measuring stick to check level. I cant see spending $200 for one of these things like the name brand ones.
Got yellow hoses to match engine bay 1.3 lbs for the kit as is ![]() Didnt use the provided black hose bought some yellow ones ![]() Combined ~1.5 lbs added to the passenger front ![]() NEW WEIGHT 2437 LBS |
| The Following User Says Thank You to SuperTom For This Useful Post: | KMA KiCKz (09-21-2025) |
#338 |
Side skirts underplates
Made smooth panels to cover all that turbulent area between the TRD side skirts and JDM panels. Basically the whole pinch weld area except kept space to fit jack stands.
This panel was cut in half to make Two 4'x1' pieces. 5.3lbs These were used in the middle. ![]() Then Two smaller Pieces to finish the rear and connect to the JDM gas covers and almost meet the Verus suspension covers. 1.9lbs ![]() then used .04" Aluminum to make the front. This is a little thicker and sturdier than the .02" I was using but still bendable. I designed this to block off as much air entranceways on the rear of the front fenderwell. The only hole is for the jack stands. .9lbs ![]() ![]() Attached all good with alum rivnets added about 8.5lbs total if you include screws. ![]() ![]() new weight 2445.5 LBS Journey to complete bottom smoothness almost complete hoping I don't go over 2450lbs |
| The Following User Says Thank You to SuperTom For This Useful Post: | Stonehorsw (09-26-2025) |
#339 |
Final Smooth Underbody
Finished my smooth underbody today.
-Made a cover for the transmission area to replace the fiberglass one -a plate the covers most of the area for the rear diff. Left a square opening since I use it as a jacking point frequently. Prototype transmission plate thin aluminum attacthed to stock fiberglass removed 3lbs ![]() mY new plate with 1.5mm or .062" aluminum with intake vents (got a little crazy banging out the vents) Adds 6lbs ![]() ![]() ![]() INstalled fully smooth underbody after the front skid plate!! ![]() Rear DIff Cover This covers the rear diff and connects all the Verus pieces and my alumalite center plate all together This has a square cut to fit my jack on the diff +2lbs ![]() ![]() ![]() Installed ![]() And that wraps up the smooth underbody! |
| The Following User Says Thank You to SuperTom For This Useful Post: | KMA KiCKz (10-03-2025) |
| mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 05:30 PM |
| White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 02:04 PM |
| white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 01:25 AM |
| Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 07:47 PM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-01-2013 11:45 PM |
