08-13-2021, 03:51 AM | #337 |
Drives: Corolla GT
Awesome !!!
Speechless!!! Keep up the marvellous work that you are doing! I can't wait to see the front coilovers fitted. Phew! |
The Following User Says Thank You to Thefalls For This Useful Post: | DIY (08-13-2021) |
08-13-2021, 09:33 AM | #338 |
Drives: 2023 BRZ
I made a sandwich yesterday.
Director of Rocky Mountain 86CUP
08-13-2021, 12:04 PM | #340 |
Drives: 2018 Subaru BRZ Limited with PP
So awesome to see how you've advanced in your work. You seem to just breeze by with your welds now!
08-19-2021, 06:05 AM | #341 |
Drives: BRZ, WRX
I'll just leave this here...
The Following 17 Users Say Thank You to DIY For This Useful Post: | Ash_89 (08-19-2021), Busybee (08-21-2021), Code Monkey (08-19-2021), DustinS (08-20-2021), Dzmitry (08-20-2021), fika84 (08-19-2021), flippy (10-29-2021), Irace86.2.0 (08-23-2021), Jdmjunkie (08-19-2021), knapper (10-01-2021), MotoX16 (10-27-2021), NoHaveMSG (08-21-2021), pope (08-19-2021), RToyo86 (09-08-2021), StraightOuttaCanadaEh (08-26-2021), TheBoss77 (05-30-2022), tintumz22 (08-23-2021) |
08-21-2021, 02:15 AM | #342 |
Drives: BRZ, WRX
ok one more photo
The Following 15 Users Say Thank You to DIY For This Useful Post: | ACT86 (08-21-2021), Busybee (08-21-2021), Code Monkey (08-22-2021), DustinS (09-22-2021), Espi (10-07-2021), fika84 (08-23-2021), flippy (10-29-2021), Irace86.2.0 (08-23-2021), Jdmjunkie (08-21-2021), knapper (10-01-2021), MotoX16 (10-27-2021), new2subaru (08-21-2021), NoHaveMSG (08-21-2021), RToyo86 (09-08-2021), StraightOuttaCanadaEh (08-26-2021) |
08-21-2021, 05:59 AM | #343 |
Drives: English, French, Swedish & Japanese
Fat
08-21-2021, 11:09 PM | #344 |
Reminds of the scene from days of thunder when he walks around the tube chassis and talks sweet nothings to it
2013 Series 10 FRS #553
08-23-2021, 11:56 PM | #345 |
Drives: Q5 + BRZ + M796
Your K-swap looks better than mine.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | DIY (08-24-2021) |
09-01-2021, 09:43 PM | #346 |
Drives: BRZ, WRX
Heat Exchangers
My intercooler and radiator cores arrived yesterday. I got an amazing deal on these cores from CSF, although I personally believe PWR make the best heat exchangers money can buy.
The intercooler core is rated to 850hp and I am still trying to decide whether I should trim down the height of the radiator core a little before I weld on the end tanks. I have a reasonable amount of space in front of the engine to fit both heat exchangers. They are most likely going to be stacked together and fully ducted with the air venting out the hood. So I am just playing with the angle at the moment before I make some kind of support to hold them in place. My turbo is currently in transit from Full Race Motorsport in Arizona. I have to give a big thanks to Geoff from Full Race for helping me choose which turbo to get.
09-08-2021, 04:49 AM | #347 |
Drives: BRZ, WRX
Spooly Boi
My turbo has arrived!
It took me a long time to come to a decision on which turbo to get, it was either going to be Garrett or Borg Warner. Obviously both great options but in the end the EFR series from Borg Warner won me over. I've always been a fan of twin scroll housings and Garrett don't seem to be offering this on their newer G series turbos, they really do help to get a larger turbo making boost sooner. I was also attracted to the aluminium housing option that is only available with BW EFR for the weight savings and better thermal properties. EFR has a significantly lighter weight turbine wheel for better spool and transient response and a properly designed internal wastegate system for simplicity and better packaging. The IWG is not always perfect though and it will limit my top end power to some degree. Full Race Motorsport have just released a kit for the internally gated EFR that uses a Civic Type R electronic IWG actuator for ultimate boost control, so I have purchased this kit to prevent any potential issues.
The Following 6 Users Say Thank You to DIY For This Useful Post: | Ash_89 (09-08-2021), DustinS (09-10-2021), Dzmitry (09-08-2021), Irace86.2.0 (09-21-2021), Jdmjunkie (09-08-2021), RedReplicant (09-17-2022) |
09-17-2021, 12:33 AM | #348 |
Drives: BRZ, WRX
I've spent a lot of time going back and forth with turbo position this week.
My original intention was to low-mount it just behind the shock and run the dump pipe inside the cockpit just in front of the pedal box behind a steel box enclosure then out the side. This turbo is much larger than I thought so it does not fit in that position. I then tried to high-mount it and I did manage to make it fit but it goes against everything I've been trying to achieve with this build. The main goal is to move all the weight as low as possible and toward the center of the car. The only remedy is to move the shocks. It will be a lot of extra work and I will have to cut off the shock mounts that I have already spent a considerable amount of time making. This photo shows the rough position of the turbo and also the rough position the shocks will be moved to. You can see the weight is low and back, the tradeoff is the shocks are now mounted higher up but they are also further back which is good. The shocks weigh 2.6kg (5.7lbs) each and the turbo weighs only 11.15kg (24.6lbs) with its aluminium core so there is benefit to mounting the turbo lower than the shocks. Generally speaking a low-mount turbo is also better for heat management. This new shock arrangement should also allow me to mount the front swaybar behind the engine. I have been waiting on some things to arrive before I could settle on a final mounting position for the turbo as there are potential clearance issues with the steering intermediate shaft. I bought a complete steering column from a wrecked 86 and I will be running a motorsport sytle collapsible column from the EPAS unit up to the steering wheel which is moved a long way back from the stock position. I have already trimmed all the unnecessary bits of the EPAS. The other consideration is the turbo manifold which I am going to try build myself. I ordered a really nice 347ss DIY manifold kit from Hypertune which also includes a beautifully made T4 twin scroll cast collector to suit the IWG turbo. The collector is a critical part and sees the most extreme conditions so buying one like this seems the best way to go. Since Hypertune don't support Honda engines the kit is actually for a Evo but I can grab any extra bends I need from them if required, they are not too far from my house. I also had to grab a head flange from Mazworx for this reason, its CNC ported already so the holes go from oval to round. I don't have a lot of time to work on the car right now as we just had a baby girl but I'm collecting all the parts for when I do get more time.
The Following 8 Users Say Thank You to DIY For This Useful Post: | Ash_89 (09-27-2021), Busybee (09-17-2021), Code Monkey (09-17-2021), DustinS (09-22-2021), Dzmitry (09-17-2021), Irace86.2.0 (09-21-2021), Jdmjunkie (09-17-2021), NoHaveMSG (09-23-2021) |
09-23-2021, 06:56 AM | #349 |
Drives: BRZ, WRX
I've finished moving the inboard suspension. The shocks have been moved from the original position to make space for low-mounting the turbo. Many new positions were trialed before settling on this final position.
This is where the shocks will sit now You can clearly see the space that is now open for the turbo I was able to use the knowledge gained from the original design to make this a relatively quick process. I went through the whole process again that was previously described in this thread to build a mock up shock and measure the wheel travel versus shock travel and calculate the rising rate of the suspension. This video shows the new design in action https://www.instagram.com/p/CUHmYInP..._web_copy_link The original shock mounts were cut off once I was happy the new design would work. Now I have been able to properly low-mount the turbo with plenty of clearance to make my turbo manifold and no more issues with the steering intermediate shaft being in the way. I am both excited and nervous to make my very first turbo exhaust manifold now.
The Following 11 Users Say Thank You to DIY For This Useful Post: | Ash_89 (09-27-2021), Busybee (09-26-2021), Code Monkey (09-23-2021), DustinS (09-23-2021), Dzmitry (09-23-2021), Irace86.2.0 (10-10-2021), Jdmjunkie (09-23-2021), jflogerzi (09-27-2021), MrSkubi (09-23-2021), NoHaveMSG (09-23-2021), RedReplicant (09-17-2022) |
09-27-2021, 02:48 AM | #350 |
Drives: BRZ, WRX
I'm thinking of changing the thread title from low budget to mid budget
I've just hit $25k AUD ($18k USD) total spend which is honestly more than I thought this project would cost. Some of the recent purchases like the turbo for example were very expensive and blew out the budget and I still have quiet a few big ticket items to purchase before I'm done.
The Following 7 Users Say Thank You to DIY For This Useful Post: | ACT86 (10-07-2021), Busybee (09-27-2021), Dzmitry (09-27-2021), Irace86.2.0 (10-10-2021), Jdmjunkie (09-27-2021), RedReplicant (09-17-2022), villainous_frx (09-29-2021) |
