Old 05-13-2020, 11:49 AM   #337
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
I have a 2013 with 64kand bought it with 21k. I've had the car since 2015 and the battery finally died yesterday.I'll probably end up trading the car in before I hit 100k.
Th3rdSun is offline   Reply With Quote
Old 06-11-2020, 10:13 PM   #338
Polmtree
Drives: 2014 Scion FR-S
I have a 2014 FRS I bought at 59k miles. I’m at 119k miles now and I had to change my TOB at 100k. I changed the clutch and flywheel at the same time because exedy had a deal for all 3. The only other major repair I had was around 65k shortly after I bought it I had the check engine light go on and when I had it checked it was that P0045 code or something similar. I heard it had was a common issue. It was still under warranty so I took it to Toyota and they told me a cam gear had cracked and broke and they rebuilt it for me.
Polmtree is offline   Reply With Quote
Old 06-12-2020, 12:35 AM   #339
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Regular oil changes
3 clutch sets
4 sets of brake pads
1 battery
1 change of spark plugs
1 set of rear axles
1 starter
1 bespoke head unit
2 Front lca bushings
FRS13_ is offline   Reply With Quote
The Following 3 Users Say Thank You to FRS13_ For This Useful Post:
JD001 (06-13-2020), jordan7831 (06-12-2020), phm14 (08-10-2020)
Old 06-12-2020, 12:54 AM   #340
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Originally Posted by FRS13_ View Post
Regular oil changes
3 clutch sets
1 battery
1 set of rear axles
1 starter
1 bespoke head unit
Thats amazing. And man that seems like a lot of brakes and clutches haha. I'm guessing you went through countless sets of tires as well.
So the age old question, how hard is your car driven to achieve this mileage?
ItsReiko is offline   Reply With Quote
Old 06-12-2020, 01:08 AM   #341
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Probably pretty hard to go through brakes and clutches so fast.
I’m at 80K and on original brakes. Had the clutch replaced cause the TOB failed, but the clutch was still good.
Old 06-12-2020, 01:10 AM   #342
FRS13_
FRS13_'s Avatar
Oh yea and tires!
It’s my daily driver and a lot of those are highway miles, I actively try to keep it under 5k RPM when shifting. I do let it rip close to the red line sometimes but I’ve never over revved it. I like to think this has been key to keep the car running strong without any issues.
Or maybe just got lucky.
Old 06-12-2020, 01:15 AM   #343
FRS13_
FRS13_'s Avatar
I’m at 90k and on original brakes. Had the clutch replaced cause the TOB failed, but the clutch was still good.
The reason I replaced the clutch the first two times was because of the old defective TOB going bad, I chose to replace the clutch while I was in there both times. For the 3rd time I got the revised TOB and replaced the clutch and flywheel, that was 40k miles ago and both the TOB and clutch are still good.
Old 06-12-2020, 10:17 AM   #344
Yoshoobaroo
TRACKBREAD
Do you do track events? Original brake pads tend to last ~100k
(or even more for some people) on daily drivers.
Old 06-12-2020, 02:47 PM   #345
Th3rdSun
You must coast to a stop.
I bought my car with 21k mile on it,and have put about 42k on,and have gone through front and back pads once.Probably will have to replace both next year again. Rotors seem to be fine though.
Old 06-12-2020, 04:39 PM   #346
FRS13_
FRS13_'s Avatar
No tracking, a lot of spirited driving. I replace the brake pads every 40k miles, I do my own maintenance so it doesn’t cost much and I enjoy working on my car.
Old 06-12-2020, 04:41 PM   #347
FRS13_
FRS13_'s Avatar
Sounds about right to me.
Old 06-12-2020, 04:42 PM   #348
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
How's has your stock rotors held up compared to the pad life? Or did you swap them out every time. I'm about to change my stock brake pads at 30k miles, but don't really want to change the rotors.
Sent from my SM-G973U1 using Tapatalk
Oxyg3n is offline   Reply With Quote
Old 06-12-2020, 04:47 PM   #349
FRS13_
FRS13_'s Avatar
Rotors are fine but I did replace them at 20k with slotted/drilled rotors.
I doubt you would need to change your rotors at 30k. Unless of course because racecar.
The Following User Says Thank You to FRS13_ For This Useful Post:
ItsReiko (06-12-2020)
Old 06-12-2020, 07:46 PM   #350
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
I'm getting close to 90k on my 2013. If it weren't for the pandemic and driving a lot less as a result, I would have been pretty close to 100k this year. Last year I put about 20k miles on my car between daily driving and driving to various driving events, concerts, and road trips. It's June and I've only put maybe 4000 miles on my car since the year started.
My last Blackstone analysis at 79k miles showed pretty low wear metals, so I'm somewhat optimistic my motor is doing fine. It saw some track use last year and it's seen pretty consistent autox use since I bought it at 54k miles in 2018.
I replaced the clutch at 59k miles when my TOB failed and the disk still had plenty of life left in it. I had a small oil leak on the driver side valve cover that got fixed when the car had the valve spring recall done at 66k. I did the spark plugs at that time as well.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
The Following User Says Thank You to AngelGT86Racer For This Useful Post:
JesseG (06-22-2020)
How many miles on your car? Sitha@ft86club Scion FR-S / Toyota 86 GT86 General Forum 333 12-30-2015 06:49 PM
1st 86 400 miles 75 carrera Cars for Sale/Trade 0 11-25-2014 06:15 AM
2000 honda civic si 33k miles on body 3k miles with turbo kit Anthony7515 Cars for Sale/Trade 3 07-28-2014 10:10 AM
11k miles and I still.... bdanisi Scion FR-S / Toyota 86 GT86 General Forum 24 06-19-2013 02:24 PM
How many miles are on your BRZ? Jayde BRZ First-Gen (2012+) — General Topics 26 11-20-2012 05:10 PM
