#3473 |
Drives: 2018 BRZ tS
#3474 |
Drives: 2014 Subaru BRZ
Correct, the modifications over the stock/base car would all count the same as if they were non-OEM parts installed by you, so you'd have to remove stuff like the wing and different springs would automatically put you in STX.
| The Following User Says Thank You to 14stu For This Useful Post: | Scala (09-10-2018) |
#3475 |
Drives: 2018 BRZ tS
Thank you. I guess I'll have to see how competitive it can be in STX and how much it'll cost to get it there.
#3476 |
Drives: 2013 FRS
Any news on it yet? I'm curious how it's working out/possibly interested in one once they're available. My driving style likes front roll stiffness.
#3477 |
Drives: 18 BRZ tS
#3478 | |
Drives: 2024 GR86/ 2015 FRS
Day 2, the car was loose and I should have made a change after my 1st run.....instead I stiffened one side of the bar after my 2nd run and it was really good for my 3rd run( I coned away 4th place) I was able to make the bar adjustments between runs even with being a 2 driver car. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
| The Following 2 Users Say Thank You to Simmons For This Useful Post: | DocWalt (09-11-2018), strat61caster (09-10-2018) |
#3479 |
| The Following User Says Thank You to 14stu For This Useful Post: | strat61caster (09-10-2018) |
#3480 |
Drives: 18 BRZ tS
Just read September Fastrack... tS is in C-Street at least
https://www.scca.com/pages/fastrack-news |
| The Following User Says Thank You to 86prime For This Useful Post: | strat61caster (09-10-2018) |
#3481 |
Drives: 18 BRZ tS
#3482 |
Drives: BRZ 2017 Pure Red, MT
#3483 |
4 holes....plus you can just do 1 hole instead of both sides.
Simmons
| The Following User Says Thank You to Simmons For This Useful Post: | nico_rsx (09-11-2018) |
#3484 |
Drives: 2016 Scion FRS
Brian also pieced together a rear bar (ND arms maybe?) and said we can expect a production version at some point.
Beautiful pieces and if you've ever dealt with one of these style bars along with a stock designed bar that might tend to bind, it is a must have... |
| The Following User Says Thank You to steverife For This Useful Post: | Simmons (09-12-2018) |
#3485 |
Drives: 15 BRZ
What's everyone at for ride height? Or is it really even worth taking it into consideration for these cars?
Delta/CENLA Region SCCA - DS
#3486 | |
Drives: 2013 Raven FR-S
I think it matters to some extent, but you don't have to be super low for STX. During Autocross season I set my ride height to 13" from hub center to fender. That's somewhere in the neighborhood of 1.5" to 1.75" lower than stock. |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
