08-15-2014, 11:02 AM | #3431 | |
08-15-2014, 11:04 AM | #3432 |
Noob
Drives: FR-S Mammogram
Those Fumotos look super convenient. I may get one after my 3 oil changes, but I've been too worried about scraping/cracking it when I'm lower.
08-15-2014, 11:27 AM | #3433 |
It doesn't hang low enough at all. Your rear exhaust connections would hit a speed bump before the valve would. If your valve hits anything, you probably broke an axle. Even with my 1.6" drop, that valve will be fine.
08-15-2014, 11:29 AM | #3434 | |
Noob
But good point on the rear connections. I'll probably just go ahead and get one after my 3rd oil change anyway!
08-15-2014, 11:42 AM | #3435 | |
Drives: 2014 SWP BRZ Limited
Could do the top route as well if you go with the pump option, may do that for the apartment, slight cleaner, but more expensive. |
08-15-2014, 11:56 AM | #3436 |
I got the one with the nipple connection and the clear hose. Makes it a lot cleaner. Turn the valve and go back inside for an hour.
08-15-2014, 12:48 PM | #3437 |
Noob
I'm not a fan of extracting oil from the top - would prefer to let gravity do its thing in getting all the filament and shaving out. Plus, cheaper
08-15-2014, 01:21 PM | #3438 |
Drives: 2013 Red BRZ Limited
Carb Kit
What are you referring as "the carb kit"?
08-15-2014, 02:37 PM | #3439 |
Jackson Racing sells an off the shelf tuned kit that is CARB legal (emissions standard in California) that is an off the shelf "safe" tune, keeps stock exhaust components, and has a good amount of abuse by the counterspace garage guys. Obviously FI always has risks, but the kit so far hasn't had much in the way of problems, other than some small install issues that people have had. No Forced Induction is without problems, even their kit I'm sure. But so far it seems solid, and would meet any potential goals I'd be going for.
I am sad @frs-Matt isn't going to S/C still |
08-15-2014, 02:40 PM | #3440 | |
The Following User Says Thank You to FR-S Matt For This Useful Post: | Scottemad123 (08-15-2014) |
08-15-2014, 07:11 PM | #3443 | |
Troll Hunter
Drives: fr-s, tundra
not sure how much it sticks out on the Fr-s, but I got one for it too. only at 8k miles, so won't need it till probably the end of the year
The Following User Says Thank You to 86-tundra For This Useful Post: | Jyn (08-16-2014) |
08-16-2014, 11:57 AM | #3444 |
Troll Hunter
I'm moving to a house in cedar park next week, does that make me an old man?
I just wanted the garage :'(
