Old 10-29-2012, 11:37 AM   #3403
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by sportsguy83 View Post
To anyone who wants to know how "Loud" is Nameless, please take a look at xjohn's video. It is not Loud at ALL.
Also note that's the non-offset axle back.
xjohnx is offline
The Following User Says Thank You to xjohnx For This Useful Post:
Sportsguy83 (10-29-2012)
Old 10-29-2012, 12:42 PM   #3404
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
Anybody having any luck fixing the fuel gauge problem? Tried battery cable disconnect with no luck. Is it a EcuTek issue and should I email them? Anybody know?
Roadstercycle is offline
Old 10-29-2012, 01:00 PM   #3405
Yruyur
Yruyur's Avatar
John is most likely working with ecutek.
Sent from my flux capacitor using Taptalk
Yruyur is offline
Old 10-29-2012, 01:02 PM   #3406
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Originally Posted by xjohnx View Post
I dyno'd it last weekend but I was an idiot and left TCS on which will cause the car to pull throttle, but I still put down 180 to the wheels, even with TCS on. I don't have a baseline for comparison, but a new GTI with a flash put down 200 for comparison sake. ]
What mode would you normally put the car in to defeat this? Just hold down the trac for 3 seconds or something else?
TomR
ABQautoxer is offline
Old 10-29-2012, 01:19 PM   #3407
Opposed
Drives: 2013 Asphalt FR-S
It is still being tweaked, but definitely an improvement of power over the pump gas tune based on the butt-dyno.
Hmmm, I have never heard of the TCS causing lower dyno numbers, unless you were spinning on the dyno, do we have proof of this? Also, was this on E85? I put down 180whp on the 93 tune with completely stock exhaust on a dynojet.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 10-29-2012, 01:20 PM   #3408
xjohnx
Grip>Slip
xjohnx's Avatar
I was thinking that, or pulling the ABS fuse which should disable the TCS computer as well.
What's your recommendation, @Visconti ? Also, where's the easiest place to pick up RPM signal?
xjohnx is offline
Old 10-29-2012, 01:53 PM   #3409
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You long press the Trac off button for some amount of seconds and two lights will come on in the dash showing all Aids are off.
Sportsguy83 is offline
Old 10-29-2012, 01:54 PM   #3410
ABQautoxer
ABQautoxer's Avatar
Even doing this you'll still light up the ABS and traction lights once the dyno starts, at least mine did.
TomR
Old 10-29-2012, 02:00 PM   #3411
Gregory Gawaran
Drives: 2018 Subaru BRZ tS
Got my cable in john! I have the file I am not suppose to flash so I will be sending you a form soon. In the options though its only E85 and 100 octane do I just choose the 100 octane one?
If I installed deltadash so I need to reinstall without it checked?
I also cannot find my license update file, looked everywhere I think it might be.
Looked through the screenshots when it goes to License download i am getting (Remote folder not found)
Gregory Gawaran is offline
Old 10-29-2012, 02:39 PM   #3412
DSTL
Drives: 2013 BRZ Limited 6MT
Re RPM signal
http://www.ft86club.com/forums/showthread.php?t=10292
Edit: Here's the quote from Don@Accelerated on this, different thread than the one above that is closed now so can't quote it "I had similar issues on my Dynojet pickup as well. I changed to using the pickup w/ the ground and just clamping the harness bundle behind rear cylinder on passenger side. Never had any issues from there forward."
DSTL is offline
The Following User Says Thank You to DSTL For This Useful Post:
xjohnx (10-29-2012)
Old 10-29-2012, 04:29 PM   #3413
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Don't change anything... Your Rollin the dice like you wouldn't believe
826 will lock up your Ecu !
I'm really confused, then... I should just keep the 'broken' 826 on my car? How (and when) should I fix this?
Emailed you a couple times, John. Would you prefer that I call you?
Symbiont is offline
Old 10-29-2012, 04:37 PM   #3414
cnk
Drives: '13 DGM BRZ Limited
If the tune is already on the ECU, you are fine. You can flash the stock ROM or the 10895 tune without issues. The problem is if you try to flash any of the older tune files, you run the risk of locking up your ECU.
cnk is offline
Old 10-29-2012, 04:41 PM   #3415
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Thank you for the clarification; flashing to stock (appointment for dealer service in a couple days)
Symbiont is offline
Old 10-29-2012, 04:44 PM   #3416
cnk
Just don't flash back to a tuned file until you get the latest file.
cnk is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
