#3389 | |
DBC Racing
you should of seen STX last year. Lets just say that v1 of a certain arm used a spherical bearing that pretty much every STX driver had on the FRS/BRZ. Had a clarification not been put out there would have been more than 70% of the STX competitors who have been DSQ'd. Point being, despite how adamant that @ChrisV is that the Koni's are legal within the letter of the rule book, I personally wouldn't want to make the long trek to Lincoln with any possibility that the Koni's are not 100% legal. Thread crapping or not there is still a point that wants to be clarified and why not have it clarified. If Chris ends up being correct, then great since now everyone can be rest assured that their suspension is 100% legal. If not, well then aren't you glad we had this conversation?
#194 SM
| The Following User Says Thank You to itzmik3 For This Useful Post: | Jawnathin (06-30-2015) |
#3390 |
Drives: Toyobaru FRZ
And that is exactly what he plans on trying to find out. He stated he felt the measurements were incomplete and that is why he is questioning their legality. Maybe he'll confirm that they are legal or maybe he will find something concrete that suggests otherwise.
You say you are operating on facts and he's operating on conjecture, but isn't possible you have an incomplete set of facts? Any variations in camber from OEM will raise questions about their legality, especially since there is a competitive advantage. It is understandable that people want to understand why and how. The more data we have around the topic, the better it is for the community. I don't have a dog in the fight, I just want to know whether they are legal or not. If they are, then great, I have a legal option of getting some more camber than I have today. If they are not legal, then I know I can just stick with what I've got. |
| The Following 2 Users Say Thank You to Jawnathin For This Useful Post: | itzmik3 (06-30-2015), simpleisbest (06-30-2015) |
#3391 |
Drives: 2014 FR-S 6MT
Koni and two posters here confirm dimensions based on actual measurements.
Some guy who's never held the parts is certain they're illegal. And you think he's the correct one. You guys are a trip. Sent from my SM-N910T using Tapatalk |
#3392 | |
DBC Racing
#194 SM
#3393 | |
Drives: 2014 BRZ
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
#3394 | |
Drives: Series 10 FRS
Everyone should want the "truth" before Nationals... |
#3395 | |
The Stig's German cousin
Dude. Did you not see the side by side comparison I reposted? They are identical to a tolerance far below the width of a human hair. If you think the width of a human hair is a competitive advantage then I'd like to remind you that you are dodging cones in parking lots at 30 miles per hour. |
#3396 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
Amateur racing for a $3 plastic trophy is always the most cutthroat. It was like that when I raced almost 20 years ago and still is. This thread IS entertaining however.
So many modders have more cents than sense!
| The Following 3 Users Say Thank You to Rampage For This Useful Post: |
#3397 | |
Drives: 2014 BRZ
#3398 |
Drives: Subaru BRZ
Holy cow. I'm away from the internet for two days, and look what happens!
I don't want to muddy things, but I will say that my measurements were of the hole diameters as well as their distances from the shock body and perch (someone suggested that it was only the hole sizes themselves). This verifies that the holes were no larger than OEM and in the same locations as on the OEM strut. On my car (a BRZ), I was able to get 1.5 degrees of camber on the OEM suspension with crash bolts, and swapping the Konis gained no additional camber. I am 100% sure that they should be considered dimensionally identical to OEM. I have had both units in hand, and I would have no hesitation about using these for C Street. As for people who are getting more camber, I don't have any suggestions other than manufacturing tolerances. I've seen some people post that they get just over 1 degree of camber with crash bolts, and some people are getting 1.7-1.8 with crash bolts and the TRD springs. solort even posted that he is seeing 1.8 degrees on stock springs and struts; what do you think will happen when he puts on the TRD springs? I'll bet he sees over 2 degrees. And he is coming from years of running Neons that have similar front suspensions and factory crash bolts options. As has been mentioned, I hope it gets cleared up before Nationals. If you're running these struts, I'd recommend having a stock strut on hand for comparison. If you've done that and they measure the same, let people throw paper if they choose. |
| The Following User Says Thank You to ksconekiller For This Useful Post: | DocWalt (07-01-2015) |
#3399 | |
At one point I was contemplating about running Kumho V710 in the 215/40/16 dimension in order to get a gearing advantage and luckily decided to run on wider 17s R-comps instead (R-comps are legal where I run). Btw, as far as protesting goes: The protest-fee-deposit at our slaloms is approx. $500, so people only protest if they have a very valid point. |
#3400 | |
Drives: 2014 FR-S
So subaru bolts in the FRS are legal. Hell, save yourself the 6 bucks or so a bolt and go to an industrial hardware store and buy 14mmx60 flange bolts that are the same grade for under a buck each, completely legal. Oh, my clarification came out in this last fast track, notice that 13.10(c) has now been changed in the rulebook to specify last catalytic converter. So no over-pipe, cat-less front pipe and cat-back setups. So, now what about beating Fenter and Harvey, any aliens in our crowd? I'm going to El Toro July 11th to try my luck against the fast norcal guys. Debating on nationals, I think I may be good enough to trophy, or at least put myself in the upper half of the field which would be 17th or better. Mark |
#3401 | |
Drives: 2014 BRZ
#3402 | |
We've got a good shot at getting our own run group like STX did last year. |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
