#33909 |
Yeah but will a router get you LAID!?
Sent from my SM-G920P using Tapatalk |
The Following User Says Thank You to p1l0t For This Useful Post: | Cole (07-28-2017) |
#33910 |
Junior Senior with Cheese
Drives: 15 BRZ
I mean... kinda?
#33911 |
Drives: frs
Im using badoo
#33912 |
#forSmash...
![]() Sent from my SM-G920P using Tapatalk |
#33913 | |
The electrons come into the room from the wall, via a wire, make the fan go round and round, then go, via another wire, back into the wall, they don't hang out in the room ....... ![]() humfrz |
#33914 | |
Hombre
Drives: 1994 Supra Turbo
"The electric motor on the fan will generate a small amount of added heat for the room air." Heat/thermal energy transfer that would not exist if the fan were turned off. ![]() Of course, the incremental amounts of heat and energy we are discussing are trivially insignificant - which is what old farts do! ![]()
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap? |
#33915 | |
![]() humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Silver Supra (07-27-2017) |
#33916 | ||
chicken tonight
A qualified engineering candidate would immediately recognize the question as a test for the grasp of a couple basic thermodynamic principles. Folks that have the courage to banter, especially with authority, are also my biggest stars. I'm a sucker for irreverence but in a professional setting, context and tact are equally important.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | krayzie (07-27-2017), ScoobsMcGee (07-27-2017) |
#33917 | |
chicken tonight
![]() I'd start by asking if it was appropriate to assume the room is not adiabatic and that we're starting at standard temp and pressure. You'd probably say "Oh, yeah, sure. blah blah..." Then I'd say given what I see in the photo, (I think the fan was running) it would cool the room until the water in the bowl came to thermal equilibrium with the room. Then, as the fan continued to run it would heat it again because motor inefficiency, stirring, all contributing to irreversibility, blah blah... Am I hired? I need to take the next couple weeks off.
#33918 | |
The good part is that there really is no one "right" answer but several possible replies that would give me great insight in how their brain works. 1) "Ummmm" followed by several seconds of silence then some random guess - Thanks for coming we will be in touch if we wish to proceed. 2) "I don't know the answer since there is not enough data about the heat produced vs the cooling effect. I would need more info to be able to say for sure what the impact would be" - Perfect for a product engineer where the tolerances are very low and data and specifications leave no room for assumptions. 3) "If we make some basic and relatively safe assumptions on the amount of heat created vs the cooling effect it is likely that the room will stay the same" - The ideal statement for a process engineer where many of the elements are known or can very safely be assumed. It leaves more room to be creative and thinking "outside the box" than the data driven product tasks. 4) "I would say it would stay the same but need to take some measurements and confirm my thoughts before I commit to a firm answer" - This mix of the other two would be the best of both worlds and would probably take my first vote as the successful candidate if I was looking to fill a general or plant services type engineering position (my assembly plants have engineers as the "maintenance" department). All in all it would not be their grasp of basic thermodynamic principles that I am interested in learning (they have an engineering degree I expect them to have a good grasp on the principles) but more how they approach a task or project. I have made a couple of very serious errors in placing engineers in positions because I misjudged their approach to things but have never screwed up picking one for their actual knowledge. I know I joke about the engineer stereotype sometimes but the reality is that I have only met a handful that were even a little bit good at banter and interaction. The ones that were good at it also the very best all round engineers I have ever worked with. Not sure if it is a schooling thing but I don't think that it is coincidence that most of those were guys that went into engineering later in life and not straight from high school to college. Again I realize it is a stereotype but most of the recent graduates or interns we bring in have the personality and sense of humour of a wet rock!
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#33919 | |
chicken tonight
![]() ...but I've literally had people say the open fridge would cool the room. You may not feel there is a particular right answer but there is definitely a wrong one. 2 and 3 are wrong too, btw. there is no cooling, only heat exchange. It has to go somewhere, don't forget about the coils on the back of, or underneath the fridge. ![]()
The Following User Says Thank You to Ultramaroon For This Useful Post: | cjd (07-27-2017) |
#33920 | |
See there, @Silver Supra , Ultramaroon agrees with me ..... so, you are out voted ...... ![]() humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (07-27-2017) |
#33921 |
Drive From Home
Drives: BRZ STI Performance
So which type of engineer gets paid the most? - Typical Asian Question
The Following 2 Users Say Thank You to krayzie For This Useful Post: | Tcoat (07-28-2017), Ultramaroon (07-27-2017) |
#33922 | |
helmholtz resonator
Drives: '15 ultramarine
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
