#3375 | |
Senior Citizen
Drives: Scion FR-S
![]() Shall I take evolutionism off the table as well? How about I lock in the my television to FOX News, while we are at it? |
#3376 | |
Drives: 2014 FR-S 6MT
Can you stop crapping up the thread now? |
#3377 | |
Drives: Series 10 FRS
Camber envy is a bitch... |
#3378 |
DBC Racing
well that was fun to read through lol
but in all honestly @ChrisV you telling @simpleisbest to "stop acting and saying that you know anything for certain" goes both ways. unless you are a rep for koni or the engineer who was in charge of the design for the koni full replacements, then by all means go ahead and preach that the koni is an exact 1 for 1 OEM replacement. however in the end, it doesn't matter if the variances are off by 1mm or even 1 micron since now you are getting a competitive advantage. in my eyes you guys both don't know so you guys are both entitled to your opinions just my 2 cents.
#194 SM
#3379 | |
Senior Citizen
Drives: Scion FR-S
While I am not afraid of forking up the cash for any justified protest, just doing it to prove a point and waste other peoples trip out there is not my thing. |
#3380 |
Drives: Toyobaru FRZ
simpleisbest isn't thread crapping, he is asking a reasonable question.
If the Konis full replacements are based on exact OEM specifications, then they should provide the same amount of camber as the OEM part. If the amount of camber does differ from the OEM strut, then something is different about the Konis which raises questions about their legality. As it stands, it is premature to call them illegal and I don't expect a protest to hold up without some type of proof that they differ from OEM specs. He said he is going to acquire a strut and test it himself and I'm looking forward to what he finds out. It would be beneficial to the community to understand what parts are legal and what are not. |
#3381 | |
And I am getting almost -2 with stock struts and 2 legal camber bolts. There are manufacturers tolerances and build tolerances in each vehicle ( as well as different manufacturers of the stock parts that may have slight tolerance differences but within manufacturers specs that are legal since they come on the car. |
#3382 | |
Then KS Cone Killer posted his measurements. Then I got mine and measured them and they were identical to OEM. So yes, he is threadcrapping. The preponderance of evidence is that the yellows are dimensionally identical to OEM. The circumstantial evidence doesn't override the hard data. If someone knows something concrete, I want to know before I drive from NJ to Lincoln, but based on my calipers, other people's measurements, and a conversation with the guy at Koni that personally bought the OEM struts that's they replicated to build the yellows, I'm comfortable. Conjecture and speculation contradictory to evidence is not compelling. It's crapping. Sent from my SM-N910T using Tapatalk |
#3383 | |
DBC Racing
I am just waiting to see once we see a side by side comparison with parts in their hands so this can finally be put to rest.
#194 SM
#3384 | |
#3385 |
Drives: 2014 BRZ
I for one am highly against protesting such things and am all for people finding out the correct info prior to some ass hole ruining your event.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
#3386 | |
DBC Racing
okay then I want to hear from you how your Koni's have magically .2-.4 more negative camber compared to everyone else? and yes I have raced in a CS FRS previously so I am quite familiar with the amount of camber is obtainable in "stock" form. **side note this is why I race in SM**
#194 SM
#3387 | |
I've done the leg work. I'm compliant with the rules. |
#3388 |
Drives: 2014 BRZ
.2-.4? Nobody would even notice. The main reason this controversy started is because it took me all of 10 seconds notice the difference by visually seeing more camber on a koni replacement car. The owner was honest and the shop where the work is done is honest as well. It's more like 1+ degree. BTW that was a stock spring car, and he managed -2.2 as well. I just went back to my sheets and I was at -.9 and -1.2 with maxed out bolts and pulling(on the alignment rack). Then really throwing weight into it and moving the top hat bolts I got an additional .2-.3 (this was based of my home camber gauge (not the rack).
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
