Old 07-20-2017, 10:30 PM   #33643
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
LOL! Elon Musk is going to build this subway?
[ame="https://www.youtube.com/watch?v=Jlken5NO7Ew"]Escape From New York - 'Bank Robbery' (Deleted Scene) - YouTube[/ame]
krayzie is offline
Old 07-20-2017, 10:31 PM   #33644
Cole
Not a troll
Cole's Avatar
Cole is offline
Old 07-20-2017, 11:24 PM   #33645
krayzie
Drive From Home
krayzie's Avatar
Happy Birthday Chris Cornell
krayzie is offline
Old 07-21-2017, 12:35 AM   #33646
Phijkchu
Phijkchu's Avatar
Drives: Feet
Phijkchu is offline
The Following User Says Thank You to Phijkchu For This Useful Post:
Tcoat (07-21-2017)
Old 07-21-2017, 02:15 AM   #33647
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I am so bored. Help.
Sapphireho is offline
Old 07-21-2017, 02:28 AM   #33648
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Step 1.
http://lmgtfy.com/?q=I+am+bored
Step 2.
Share results.
Spuds is offline
Old 07-21-2017, 02:31 AM   #33649
humfrz
Make yourself an A/C .....
humfrz
humfrz is offline
Dadhawk (07-21-2017), Sapphireho (07-21-2017)
Old 07-21-2017, 08:31 AM   #33650
Make yourself an A/C ..... humfrz
Those are much more effective then you would think. In fact, a commercial version is available for about $600. I've seen it used in small aircraft. Works for about 3 hours and can knock the temperature down by up to 30 degrees.
Dadhawk is offline
humfrz (07-21-2017), Sapphireho (07-21-2017), Teseo (07-21-2017)
Old 07-21-2017, 09:21 AM   #33651
Teseo
Drives: frs
The cold air is dense, how it flow?
Teseo is offline
The Following User Says Thank You to Teseo For This Useful Post:
humfrz (07-21-2017)
Old 07-21-2017, 09:47 AM   #33652
The only drawback is that while they do cool the air they also add a shitload of humidity as the ice melts. Work great while they work but when they stop it can be far worse than when you started. We tried them in a small area at a heat treat plant I worked in and the guys loved and then very quickly hated the effect.
Tcoat is offline
Old 07-21-2017, 09:48 AM   #33653
There is a fan that blows the air across the ice and out the tube.
Tcoat is offline
Dadhawk (07-21-2017), Teseo (07-21-2017)
Old 07-21-2017, 10:07 AM   #33654
This unit uses a heat exchanger rather than blowing directly over the ice, so it doesn't add humidity. Adding humidity would be really bad in an aircraft (particularly a new one with all that electronic equipment). That also explains the $600 price. Of course, even in a small plane a certified AC unit can cost $25,000 so that price isn't as high as it sounds!
[ame="https://www.youtube.com/watch?v=wPEpTABfFEE"]Arctic Air Portable Airplane Air Conditioner from Sporty's - YouTube[/ame]
Dadhawk is offline
humfrz (07-21-2017), Tcoat (07-21-2017)
Old 07-21-2017, 10:27 AM   #33655
Ahhhh that makes more sense. We tried a heat exchanger one as well and burnt it out in about 2 hours. I have one of the heat exchanger type coolers that you plug into your car and it actually works pretty well as long as the car is running. Will suck a battery dry in about and hour if it isn't though.
Tcoat is offline
Old 07-21-2017, 11:52 AM   #33656
Teseo
Drives: frs
Seems legit. I would rather make it but with dry ice, less mess
Teseo is offline
